I hope you had or are having a very good holiday season if you celebrate.
I need to develop a c/cpp Linux program that will Connect to/Read Object/Disconnect from a Holley DLMS meter using HLS-5/GMAC.
I was able to perform these functions successfully with DLMSDirector, as described in thread https://www.gurux.fi/node/25689.
Do you have a good skeleton c/cpp example program that will perform at least the Connect (HLS-5/GMAC) function that I can use to start my development?
I assume that DLMSDirector source code is not available?
Thank you!
HI, You can use the client…
HI,
You can use the client example to connect and read your meter. GXDLMSDirector shows the command line parameters when you select the meter.
https://github.com/Gurux/GuruxDLMS.c/tree/master/GuruxDLMSClientExample
Thanks, Mikko. The Windows…
Thanks, Mikko.
The Windows version of DLMDirector works with this meter.
And, I was able to build gurux.dlms.client.bin on Linux.
But, when I run gurux.dlms.client.bin with the command line found in DLMSDirector, it just returns the help screen and no error message, and does not work.
Any idea how I can run gurux.dlms.client.bin to Connect and Read Object?
This is what I tried:
(Note that the serial connection in Linux is "/dev/ttyUSB0" and not COM1.)
joe@joe-virtual-machine:~/GuruxDLMS.c/GuruxDLMSClientExample/bin$ sudo ./gurux.dlms.client.bin -S /dev/ttyUSB0:9600:8NoneOne -c 32 -s 156 -a HighGMAC -C AuthenticationEncryption -T 73797374656D7469 -A 00000000000000000000000000000000 -B 00000000000000000000000000000000 -v 0.0.43.1.2.255 -w 1 -f 128 -t Verbose
[sudo] password for joe:
GuruxDlmsSample reads data from the DLMS/COSEM device.
GuruxDlmsSample -h [Meter IP Address] -p [Meter Port No] -c 16 -s 1 -r SN
-h host name or IP address.
-p port number or name (Example: 1000).
-u UDP is used. -S serial port.
-a Authentication (None, Low, High, HighMd5, HighSha1, HighGmac, HighSha256).
-P Password for authentication.
-c Client address. (Default: 16)
-s Server address. (Default: 1)
-n Server address as serial number.
-r [sn, sn] Short name or Logican Name (default) referencing is used.
-w WRAPPER profile is used. HDLC is default.
-t Trace messages.
-g Get selected object(s) with given attribute index. Ex -g "0.0.1.0.0.255:1; 0.0.1.0.0.255:2"
-C Security Level. (None, Authentication, Encrypted, AuthenticationEncryption)
-v Invocation counter data object Logical Name. Ex. 0.0.43.1.1.255
-I Auto increase invoke ID
-o Cache association view to make reading faster. Ex. -o C:\device.bin -T System title that is used with chiphering. Ex -T 4775727578313233
-A Authentication key that is used with chiphering. Ex -A D0D1D2D3D4D5D6D7D8D9DADBDCDDDEDF
-B Block cipher key that is used with chiphering. Ex -B 000102030405060708090A0B0C0D0E0F
-b Broadcast Block cipher key that is used with chiphering. Ex -b 000102030405060708090A0B0C0D0E0F -D Dedicated key that is used with chiphering. Ex -D 00112233445566778899AABBCCDDEEFF
-i Used communication interface. Ex. -i WRAPPER. -m Used PLC MAC address. Ex. -m 1. -R Data is send as a broadcast (UnConfirmed, Confirmed).Example:
Read LG device using TCP/IP connection.
GuruxDlmsSample -r SN -c 16 -s 1 -h [Meter IP Address] -p [Meter Port No]
Read LG device using serial port connection.
GuruxDlmsSample -r SN -c 16 -s 1 -sp COM1 -i
Read Indian device using serial port connection.
GuruxDlmsSample -S COM1 -c 16 -s 1 -a Low -P [password]
Thank you!
Same results with this…
Same results with this command:
joe@joe-virtual-machine:~/GuruxDLMS.c/GuruxDLMSClientExample/bin$ sudo ./gurux.dlms.client.bin -S /dev/ttyUSB0 -c 32 -s 156 -a HighGMAC -C AuthenticationEncryption -T 73797374656D7469 -A 00000000000000000000000000000000 -B 00000000000000000000000000000000 -v 0.0.43.1.2.255 -w 1 -f 128 -t Verbose
It did not like the "-w 1 -f…
It did not like the "-w 1 -f 128" options.
Now I'm getting "InvocationCounterError".
joe@joe-virtual-machine:~/GuruxDLMS.c/GuruxDLMSClientExample/bin$ sudo ./gurux.dlms.client.bin -S /dev/ttyUSB0 -c 32 -s 156 -a HighGMAC -C AuthenticationEncryption -T 73797374656D7469 -A 00000000000000000000000000000000 -B 00000000000000000000000000000000 -v 0.0.43.1.2.255 -t Verbose
updateInvocationCounter
TX: 7E A0 08 02 39 21 93 52 92 7E
RX: 7E A0 1F 21 02 39 73 07 AF 81 80 12 05 01 C8 06 01 C8 07 04 00 00 00 01 08 04 00 00 00 01 AC B3 7E
TX: 7E A0 2C 02 39 21 10 40 69 E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 1D FF FF E7 25 7E
RX: 7E A0 38 21 02 39 30 D5 8F E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 12 1C 01 90 00 07 7E 7B 7E
TX: 7E A0 1A 02 39 21 32 19 84 E6 E6 00 C0 01 C1 00 01 00 00 2B 01 02 FF 02 00 0B B6 7E
RX: 7E A0 16 21 02 39 52 E8 CE E6 E7 00 C4 01 C1 00 06 79 73 74 67 FA 54 7E
Invocation counter: 2037609576 (0x79737468)
TX: 7E A0 08 02 39 21 53 5E 54 7E
InitializeConnection
TX: 7E A0 08 02 39 41 93 07 F7 7E
RX: 7E A0 1F 41 02 39 73 E3 36 81 80 12 05 01 C8 06 01 C8 07 04 00 00 00 01 08 04 00 00 00 01 AC B3 7E
TX: 7E A0 6C 02 39 41 10 37 CD E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 73 79 73 74 65 6D 74 69 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 30 79 73 74 68 72 F4 4F 79 5E 4A 36 DB 38 4A 15 79 20 5B 18 13 BF D1 3C BC CA F8 E5 87 38 E0 A8 BF 7E
RX: 7E A0 78 41 02 39 30 13 D7 E6 E7 00 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 48 4F 4C 00 0C EC 4F 83 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 12 80 10 67 09 30 4C 8B 3C 72 2E 8B C8 3F 27 3C 18 88 51 BE 23 04 21 28 1F 30 00 00 00 D6 9D 0A DE 3C 13 0B 55 B2 10 B0 86 5C 2C 81 53 AF 44 55 6A 46 13 C4 F0 67 A4 2A 5F 4A 7E
TX: 7E A0 49 02 39 41 32 E2 89 E6 E6 00 DB 08 73 79 73 74 65 6D 74 69 31 30 79 73 74 6B B0 E0 0A 58 16 C8 59 F6 ED DE 95 80 C1 E9 5A DD 61 F6 A2 C6 A6 D0 A3 68 CE 37 48 93 3E D4 82 1D BF A8 A5 BF C9 65 B9 D8 94 58 32 6F F9 AE 7E
RX: 7E A0 10 41 02 39 52 94 6C E6 E7 00 D8 01 06 83 37 7E
TX: 7E A0 08 02 39 41 53 0B 31 7E
Hi, Have you modified the…
Have you modified the source code? The invocation counter is increased too much. It should be increased only by one. I believe that is the reason for this.
Hi Mikko, No, I have not…
No, I have not modified the source code at all.
Thanks!
Hi, The invocation counter…
The invocation counter was increased twice. This works with other meters, but because this is an issue it's fixed. Get the latest version from GitHub.
> Get the latest version…
It is working now, Mikko.
Thank you!
