  2. Don't Use EEPROM In Arduino Client Example
Don't use EEPROM in Arduino client example
By vladoam , 20 December, 2024
Hi, is there option to exclude writing to EEPROM on ESP32 boards? I want to reduce memory wear on ESP board. Thanks.
1 year 5 months ago
Hi, Update to the latest…
Update to the latest version and define ignore serializer like this:
#define DLMS_IGNORE_SERIALIZER
vladoam
1 year 5 months ago
I'll give it a try. Thanks.
vladoam
1 year 5 months ago
Once I ignore serializer I…
Once I ignore serializer I probably need to remove all EEPROM code from client example. So GXTRACE(GET_STR_FROM_EEPROM("Start reading"), NULL);
becom GXTRACE(("Start reading"), NULL);? Do I need to add some new temporary storage for data to replace EEPROM? Sorry if this is stupid question.
1 year 5 months ago
Hi, Yes, you must remove the…
Yes, you must remove the EEPROM code if you don't use it.
You don't need to handle the EEPROM if you don't want to save the values.
