  2. GuruxDLMSClient Facing Memory Shortage While Reading Data From GuruxDLMSServerExample2
GuruxDLMSClient facing memory shortage while reading data from GuruxDLMSServerExample2
By sekar , 19 November, 2024
Gurux DLMS for ANSI C
1. how to solve this issue occurred at reading OBIS code client to server
ReadObject failed Not enough memory available.
Failed to read object 0.0.66.0.1.255 rows by entry
ReadObject failed Invalid parameter.
Invalid parameter.
2. What is Command format for particular OBIS code read from server.
1 year 6 months ago
Hi, Are you using Java ME or…
Are you using Java ME or did you just select that group?
2. DLMS is not that simple protocol. You need to establish the connection to the meter and then you can read data from the meter. DLMS is standard and it's described in multiple documents.
https://gurux.fi/DLMSCOSEMFAQ
sekar
1 year 6 months ago
I am Using ANSI C
I am Using ANSI C
sekar
1 year 6 months ago
i want to read and change…
i want to read and change server password in GuruxDLMSServerExample2
1 year 6 months ago
Hi, I did get the latest…
I did get the latest version from the server and client from GitHub and ran tests and everything worked without problems.
I noticed that you tried to read 0.0.66.0.1.255. So you have added new objects. You need to check your code and make sure that you are handling profile generic objects correctly on the server side.
