  3. I Am Trying To Read Meter By Using Your Python Sdk Facing Issues
I am trying to read meter by using your python sdk facing issues
By srikanthj , 12 September, 2024
Below error i am getting
root@arm:~/Gurux-reading/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python# python3 main.py -S /dev/ttymxc2:9600:8None1 -i WRAPPER -d India -t Verbose
gurux_dlms version: 1.0.158
gurux_net version: 1.0.19
gurux_serial version: 1.0.20
Authentication: 0
ClientAddress: 0x10
Standard: 1
TX: 14:05:00 00 01 00 10 00 01 00 1F 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 5D FF FF
RX: 14:05:15
File "/root/Gurux-reading/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/main.py", line 112, in main
File "/root/Gurux-reading/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 532, in readAll
self.initializeConnection()
File "/root/Gurux-reading/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 311, in initializeConnection
self.readDataBlock(self.client.aarqRequest(), reply)
File "/root/Gurux-reading/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 179, in readDataBlock
self.readDataBlock(it, reply)
File "/root/Gurux-reading/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 182, in readDataBlock
File "/root/Gurux-reading/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 118, in readDLMSPacket
File "/root/Gurux-reading/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 169, in readDLMSPacket2
raise e
File "/root/Gurux-reading/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 162, in readDLMSPacket2
raise TimeoutException("Failed to receive reply from the device in given time.")
gurux_common.TimeoutException.TimeoutException: Failed to receive reply from the device in given time.
2 years 1 month ago
Hi, Your settings are…
Your settings are different than the meter expects. Try with this:
python3 main.py -S /dev/ttymxc2:9600:8None1 -d India -t Verbose
srikanthj
2 years 1 month ago
Hi Mikko i tried with the…
Hi Mikko
i tried with the command what you suggested but sill the issue is same . You can see below logs
root@arm:~/Gurux-reading/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python# python3 main.py -S /dev/ttymxc2:9600:8None1 -d India -t Verbose
Authentication: 0
ClientAddress: 0x10
Standard: 1
TX: 13:21:37 7E A0 07 03 21 93 0F 01 7E
RX: 13:21:52
File "/root/Gurux-reading/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 306, in initializeConnection
raise e
Srikanth
2 years 1 month ago
Hi Srikanth, Check your baud…
Hi Srikanth,
Check your baud rate. The meter should reply if the baud rate is correct and your cable is connected correctly.
srikanthj
2 years 1 month ago
Hi Mikko with same baudrate…
Hi Mikko
with same baudrate i am getting response from gurux director. I am able to read all profiles.
srikanth
2 years 1 month ago
Hi Srikanth, You are now…
Hi Srikanth,
You are now using the Public Client and I believe that you need to change the client address and authentication level to see all profiles.
You can see the correct command line arguments when you select the meter in GXDLMSDirector.
srikanthj
2 years ago
Hii Mikko, Now, i am able to…
Hii Mikko,
Now, i am able to communicating meter with python SDK. SO after initializeConnection is there any feature in your SDK like whatever the OBIS code if we give from command line meter should responds to that particualr OBIS code.
Because here SDK is reading all parameters. So can you please help regarding this as soon as possible.
Srikanth
srikanthj
2 years ago
Hi Mikko, Any update…
Any update regarding above comment. I want to read particular particular OBIS code only .So what ever the OBIS i will give from commnad line meter should give response of that OBIS Code only. Please help regarding this.
Srikanth
srikanthj
2 years ago
Hello Mikko In GXDLMSReader…
Hello Mikko
In GXDLMSReader.py i included below piece of code that i got it from one of your forum.
def readAll(self, outputFile):
try:
read = False
# OBIS Clock
d = GXDLMSRegister("1.0.32.7.0.255")
self.read(d, 2)
self.getReadOut()
self.getProfileGenerics()
if outputFile:
self.client.objects.save(outputFile)
except (KeyboardInterrupt, SystemExit):
self.media = None
raise
finally:
self.close()
and in main.py i modified like below
settings.media.open()
reader.initializeConnection()
reader.readAll(settings.outputFile) -------- directly i am calling this then i am getting below logs
Authentication: 0
ClientAddress: 0x10
Standard: 1
TX: 13:23:46 00 01 00 10 00 01 00 1F 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 5D FF FF
RX: 13:23:51 00 01 00 01 00 10 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 02 00 00 07
Standard: 1
TX: 13:23:51 00 01 00 10 00 01 00 1F 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 5D 02 00
RX: 13:23:56 00 01 00 01 00 10 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 02 00 00 07
TX: 13:23:56 00 01 00 10 00 01 00 0D C0 01 C1 00 03 01 00 20 07 00 FF 02 00
RX: 13:24:01 00 01 00 01 00 10 00 05 C4 01 C1 01 0B
TX: 13:24:01 00 01 00 10 00 01 00 09 62 03 80 01 00 03 80 01 00
Data length is 5and there are 127 bytes.
RX: 13:24:06 00 01 00 01 00 10 00 05 63 03 80 01 00 00 01 00 01 00 40 00 72 DB 08 45 45 4D 30 30 30 30 33 67 20 00 00 01 1D B9 97 0C 21 9F 47 E1 98 C8 5F 34 F6 F7 9C B6 AA 3D E4 66 66 A9 A7 0A 6D 0C 34 B6 D4 38 5D 44 01 8E 74 C7 47 15 94 EB D0 C3 BE C7 B7 DF 62 DA 08 30 45 9D 40 5C A0 2B CB 1E B6 06 33 A5 10 21 71 43 26 F3 04 9A DF 92 44 77 A6 3A 80 8C 2E DF 14 5A B5 BA 12 C0 5A 21 C8 E2 F9 70 8F 97 9B 41 42 C8 D0
Access Error : Device reports a unavailable object.
so can you please help regarding this
2 years ago
Hi, You need to know what…
You need to know what COSEM objects your meter is implementing.
Reading association view you can get all the objects, but adding them manually is more effective way as you already discovered:
self.read(d, 2)
Read the value with GXDLMSDirector and then add the COSEM object that you want to read.
https://gurux.fi/Gurux.DLMS.Objects
srikanthj
1 year 11 months ago
Hii Mikko, I am receiving…
Hii Mikko,
I am receiving below packet
[[<gurux_dlms.GXDateTime.GXDateTime object at 0xb5ca7170>, 0.0, 0.0, 0.0, 0.0]]
can you help me how to convert this "<gurux_dlms.GXDateTime.GXDateTime>" to date and time . i need to print this as particualr date&time.
And one more thing i need in python Gurux DLMS SDK how to enable keep alive for initial connection.
Please respond for above mentioned issues as soon as possible .
Srikanth
Hi, You need to loop the…
You need to loop the buffer rows and columns. Check this example.
https://github.com/Gurux/Gurux.DLMS.Python/blob/f0424203b37d6e64e5231d1…
srikanthj
Hi Mikko, Thank you for…
Thank you for quick response. I got below output
07 E8 0B 0B 01 0B 2E 00 00 01 4A 00 | 1.0 | 0.0 | 0.0 | 0.0 | 0.0 | 0.0 | 0.0 | 0.0 | 0.0 | 0.0 | 0.0 | 0.0 | 0.0 | 0.0 | 0.0 | 0.0 | 0.0 | 0.0 | 0.0 | 0.0 | /99 18:30:00:000000 | 0.0 | /99 18:30:00:000000 | 75 | 0.0 | 0.0
reading with Gurux Dlms director tool getting exact time but with SDK it's 07 E8 0B 0B 01 0B 2E 00 00 01 4A 00 not a correct time .
and Give me any idea for KEEP ALIVE for initial connection
Srikanth
You need to loop the profile generic buffer and you can see the correct data.
Now you can see the date-time in bytes.
The keep alive is not needed if you read the data and close the connection. If you want to keep the connection up you must read something e.g. every 30 seconds.
