  3. MQTT
MQTT
By Sreya , 30 October, 2024
Gurux.MQTT
I'm working with the Gurux application and using the "MQTT" option using "add a device", but I’m running into an error. Could you help me troubleshoot this issue? Any insights or advice would be greatly appreciated!
Thanks!
Sreya
2 years ago
Hi, I'm working with the…
Error : Connecting with MQTT server failed (NotAuthorized)
This is the error i've been receiving.
2 years ago
Hi, I believe that your MQTT…
I believe that your MQTT server requires authentication and client don't use it.
Try first with MQTT broker that doesn't use authentication.
  • BTN KC Menteng call/wa 0813-627-9539.
  • Money Changer Indorate Prima Javalas Itc Kuningan Telp/Wa 081930338564
  • Bank BTN Kantor Kas Jati Padang call/wa 0813-627-9539.
  • Bank BTN Otista call/wa 0813-627-9539.
  • Money Changer Valuta Artha Mas Telp/Wa 081930338564
