I am trying to establish connection between Microstar/ Bluestar A2000/ P2000-D three phase energy meter, and GXDLMSDirector software, but i am failing to. All i need is to make connection, then refresh to retrieve available OBIS Codes.
Please see attached my connection settings using "Gurux" manufacturer type.
If anyone has ever managed to make connection to these meters, please assist. Thank you in advance.
The meter should reply with default settings. There was one issue in GXDLMSDirector version 8.2.2011.0601 that might affect you, Try to restart GXDLMSDirector and update it to version 8.2.2011.1001.
If the meter doesn't reply, try to change HDLC to HdlcWithModeE and check is meter replying anything. If not, check your cables.
I downloaded the new version, changed from HDLC to HDLCWITHMODEE and i double checked my cabling as well; actually the same wiring worked on another meter i was working. For some reason it still doesn't want to reply back to my requests. These are the logs i get :
18:18:28 Initializing serial connection.
18:18:29 IEC Sending:/?!<CR><LF>
18:18:39 Failed to receive reply from the device in given time.
18:18:56 Initializing serial connection.
18:18:57 IEC Sending:/?!<CR><LF>
18:19:07 Failed to receive reply from the device in given time.
18:19:46 Initializing serial connection.
18:19:47 IEC Sending:/?!<CR><LF>
18:19:57 Failed to receive reply from the device in given time.
and attached below is the pinout on the meter itself. I have my converter's A to pin 24 on the meter, B to pin 25
Your settings are now correct. There is an issue with the meter. It doesn't send an object list as an array and this is wrong. You need to ask the meter manufacturer if there is a new firmware available that fixes this. Let me know If there is no update available and we can modify bytes and generate device template so you can read the values.
It's hard to fix meter issues with the GXDLMSDirector.
If you know what you want to read, it's possible to add COSEM objects manually.
You can try to add a clock object if you select "Edit" and "Add Object".
Then select clock and press OK.
I really appreciate your support. It just was that I did, and fortunatelly it works.
But now, I am trying to read generic energy profiles on the meter, but even if I add manually the OBIS for it, I got a message "Capture objects not read",
do you have any advice in order to correctly access to this kind of data?
Perharps, I am doing something wrong, could you give me an example how to request a generic profile for a specific variable with GXDLMSDirector?
After you have added the profile generic object select it and select "File" and "Refresh".
GXDLMSDirector will read capture objects when Profile generic is selected.
Actually, I have added a load profile object (1.0.99.1.0.255) and as a capture object I added as a target sum active energy (1.1.1.8.0.255) with the attribute index 2 and data index 0. I was requesting data form 30/10/2024 1:00PM to 30/10/2024 1:50PM. But the only answer I got is the capture period, in this case is 900 (which means the capture period is each 15 minutes). However, when I try to read data I got a message "the number of columns does not macth".
An additional information about my test, in order to explain more or less my actual benchmark. I have the meter connected directly to my PC by RS485 port, and the meter is working in static conditions, so It does not have load. I mean, the meter is working just with a phase connected in order to communicate, but not measuring anything.
Sorry if my question is to basic, but is there a possibility that the meter does not return any load profile due to the actual connection status, without load?
Serial Settings :
Serial Settings :
Baud Rate : 9600
Data Bits : 8
Parity : None
Stop Bits : One
Flow Control :None
This image below is the
This image below is the communication settings one needs in order to successfully communicate with the meter :
If you are using an optical probe, change the start protocol from HDLC to HdlcWithModeE.
Hi Kurumi,
Hi Kurumi,
Noted sir, however i am not using Optical probe for now. I am directly connected on the RS485 line.
Would i still be able to
Would i still be able to connect to the meter?
When i change the client ID
When i change the client ID to 18 i get this :
19:00:13 Initializing serial connection.
19:00:14 Send SNRM request.
7E A0 20 03 23 93 CD EA 81 80 14 05 02 03 F2 06 02 03 F2 07 04 00 00 00 01 08 04 00 00 00 01 0A 75 7E
19:00:14
7E A0 1E 23 03 73 7B CF 81 80 12 05 01 F8 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 48 0E 7E
19:00:14 Parsing UA reply succeeded.
19:00:14 Send AARQ request.
7E A0 2B 03 23 10 4B 9C E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
19:00:14
7E A0 36 23 03 30 6F D5 E6 E7 00 61 28 A1 09 06 07 60 85 74 05 08 01 00 A2 03 02 01 01 A3 05 A1 03 02 01 0D BE 10 04 0E 08 00 06 5F 04 00 00 18 18 00 F0 00 07 78 B0 7E
19:00:14 Disconnect request
19:00:14
Gurux.DLMS.GXDLMSException: Connection is permanently rejected. The application context name is not supported.
19:01:29 Initializing serial connection.
19:01:30 Send SNRM request.
7E A0 20 03 25 93 1D BE 81 80 14 05 02 03 F2 06 02 03 F2 07 04 00 00 00 01 08 04 00 00 00 01 0A 75 7E
19:01:30
7E A0 1E 25 03 73 A2 19 81 80 12 05 01 F8 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 48 0E 7E
19:01:30 Parsing UA reply succeeded.
19:01:30 Send AARQ request.
7E A0 2B 03 25 10 9B C8 E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
19:01:35 Data send failed. Try to resend 1/3
19:01:35
7E A0 36 25 03 30 B6 03 E6 E7 00 61 28 A1 09 06 07 60 85 74 05 08 01 00 A2 03 02 01 01 A3 05 A1 03 02 01 0D BE 10 04 0E 08 00 06 5F 04 00 00 18 18 00 F0 00 07 78 B0 7E
19:01:35 Disconnect request
19:01:35
Seems like i made connection
Seems like i made connection but cannot retrieve objects when i press F5
19:08:08 Data send failed. Try to resend 1/3
19:08:08
7E A8 B1 21 03 B8 F8 48 02 04 12 00 04 11 00 09 06 01 01 03 06 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 03 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 03 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 A8 9A 7E
19:08:08 Get next frame.
19:08:08 Collecting objects
7E A0 07 03 21 B1 1F 03 7E
19:08:09
7E A8 B1 21 03 BA EA 6B 02 04 12 00 04 11 00 09 06 01 01 04 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 04 06 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 04 06 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 36 6F 7E
19:08:09 Get next frame.
19:08:09 Collecting objects
7E A0 07 03 21 D1 19 60 7E
19:08:14 Data send failed. Try to resend 1/3
19:08:14
7E A8 B1 21 03 BC DC 0E 02 04 12 00 04 11 00 09 06 01 01 04 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 04 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 05 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 B0 D9 7E
19:08:14 Get next frame.
19:08:14 Collecting objects
7E A0 07 03 21 F1 1B 41 7E
19:08:19 Data send failed. Try to resend 1/3
19:08:19
7E A8 B1 21 03 BE CE 2D 02 04 12 00 04 11 00 09 06 01 01 05 06 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 05 06 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 05 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 D9 C0 7E
19:08:19 Get next frame.
19:08:19 Collecting objects
7E A0 07 03 21 11 15 A6 7E
19:08:20
7E A8 B1 21 03 B0 B0 C4 02 04 12 00 04 11 00 09 06 01 01 05 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 08 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 08 06 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 6D 42 7E
19:08:20 Get next frame.
19:08:20 Collecting objects
7E A0 07 03 21 31 17 87 7E
19:08:25 Data send failed. Try to resend 1/3
19:08:30 Data send failed. Try to resend 2/3
19:08:30
7E A8 B1 21 03 B2 A2 E7 02 04 12 00 04 11 00 09 06 01 01 08 06 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 08 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 08 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 46 1C 7E
19:08:30 Get next frame.
19:08:30 Collecting objects
7E A0 07 03 21 51 11 E4 7E
19:08:30
7E A8 B1 21 03 B4 94 82 02 04 12 00 04 11 00 09 06 01 01 06 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 06 06 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 06 06 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 57 8D 7E
7E A0 07 03 21 71 13 C5 7E
19:08:30
7E A8 B1 21 03 B6 86 A1 02 04 12 00 04 11 00 09 06 01 01 06 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 06 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 07 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 D1 3B 7E
7E A0 07 03 21 91 1D 22 7E
19:08:35 Data send failed. Try to resend 1/3
19:08:36
7E A8 B1 21 03 B8 F8 48 02 04 12 00 04 11 00 09 06 01 01 07 06 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 07 06 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 07 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 B8 22 7E
19:08:36 Get next frame.
19:08:36 Collecting objects
19:08:36
7E A8 B1 21 03 BA EA 6B 02 04 12 00 04 11 00 09 06 01 01 07 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 09 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 09 06 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 FF ED 7E
19:08:36
7E A8 B1 21 03 BC DC 0E 02 04 12 00 04 11 00 09 06 01 01 09 06 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 09 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 09 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 7E E9 7E
19:08:41 Data send failed. Try to resend 1/3
19:08:42
7E A8 B1 21 03 BE CE 2D 02 04 12 00 04 11 00 09 06 01 01 0A 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 0A 06 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 0A 06 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 33 D0 7E
19:08:42 Get next frame.
19:08:42 Collecting objects
19:08:42
7E A8 B1 21 03 B0 B0 C4 02 04 12 00 04 11 00 09 06 01 01 0A 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 0A 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 01 05 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 D2 3B 7E
19:08:42
7E A8 B1 21 03 B2 A2 E7 02 04 12 00 04 11 00 09 06 01 01 01 05 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 01 05 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 01 05 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 6D EC 7E
19:08:43
7E A8 B1 21 03 B4 94 82 02 04 12 00 04 11 00 09 06 01 01 01 05 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 02 05 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 02 05 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 A6 27 7E
19:08:43 Get next frame.
19:08:43 Collecting objects
19:08:43
7E A8 B1 21 03 B6 86 A1 02 04 12 00 04 11 00 09 06 01 01 02 05 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 02 05 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 02 05 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 F7 8F 7E
19:08:43
7E A8 B1 21 03 B8 F8 48 02 04 12 00 05 11 00 09 06 01 01 01 04 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 01 00 02 04 12 00 05 11 00 09 06 01 01 02 04 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 01 00 1E 6F 7E
19:08:44
7E A8 B1 21 03 BA EA 6B 02 04 12 00 05 11 00 09 06 01 01 03 04 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 01 00 02 04 12 00 05 11 00 09 06 01 01 04 04 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 01 00 88 B5 7E
19:08:44 Get next frame.
19:08:44 Collecting objects
19:08:44
7E A8 B1 21 03 BC DC 0E 02 04 12 00 03 11 00 09 06 01 01 0E 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 51 07 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 51 07 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 51 07 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 F1 03 7E
19:08:44
7E A8 B1 21 03 BE CE 2D 02 04 12 00 03 11 00 09 06 01 01 51 07 05 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 51 07 06 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 51 07 0F FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 51 07 1A FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 C8 24 7E
19:08:45
7E A8 B1 21 03 B0 B0 C4 02 04 12 00 03 11 00 09 06 01 01 0D 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 21 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 35 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 49 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 04 54 7E
19:08:45 Get next frame.
19:08:45 Collecting objects
19:08:45
7E A8 B1 21 03 B2 A2 E7 02 04 12 00 03 11 00 09 06 01 01 01 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 02 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 03 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 04 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 21 D9 7E
19:08:45
7E A8 B1 21 03 B4 94 82 02 04 12 00 03 11 00 09 06 01 01 29 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 2A 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 2B 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 2C 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 28 58 7E
19:08:46
7E A8 B1 21 03 B6 86 A1 02 04 12 00 03 11 00 09 06 01 01 31 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 32 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 3D 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 3E 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 06 E2 7E
19:08:46 Get next frame.
19:08:46 Collecting objects
19:08:46
7E A8 B1 21 03 B8 F8 48 02 04 12 00 03 11 00 09 06 01 01 3F 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 40 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 45 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 46 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 14 AB 7E
19:08:46
7E A8 B1 21 03 BA EA 6B 02 04 12 00 03 11 00 09 06 01 01 20 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 34 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 48 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 1F 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 AC AD 7E
19:08:51 Data send failed. Try to resend 1/3
19:08:52
7E A8 B1 21 03 BC DC 0E 02 04 12 00 03 11 00 09 06 01 01 33 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 47 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 0D 00 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 09 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 A0 9C 7E
19:08:52 Get next frame.
19:08:52 Collecting objects
19:08:52
7E A8 B1 21 03 BE CE 2D 02 04 12 00 03 11 00 09 06 01 01 0A 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 15 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 16 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 17 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 79 DF 7E
19:08:52
7E A8 B8 21 03 B0 D3 3D 02 04 12 00 03 11 00 09 06 01 01 18 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 1D 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 1E 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 15 11 00 09 06 01 01 20 23 00 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 00 9C 54 7E
19:08:53
7E A8 CD 21 03 B2 D3 2A 02 04 12 00 15 11 00 09 06 01 01 34 23 00 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 00 02 04 12 00 15 11 00 09 06 01 01 48 23 00 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 00 02 04 12 00 15 11 00 09 06 01 01 20 1F 00 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 00 02 04 12 00 15 11 00 09 06 01 01 34 1F 00 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 00 B2 E6 7E
19:08:53 Get next frame.
19:08:53 Collecting objects
19:08:53
7E A8 CD 21 03 B4 E5 4F 02 04 12 00 15 11 00 09 06 01 01 48 1F 00 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 00 02 04 12 00 15 11 00 09 06 01 01 1F 23 00 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 00 02 04 12 00 15 11 00 09 06 01 01 33 23 00 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 00 02 04 12 00 15 11 00 09 06 01 01 47 23 00 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 00 E4 8F 7E
19:08:53
7E A8 C6 21 03 B6 E2 AC 02 04 12 00 15 11 00 09 06 01 01 1F 1F 00 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 00 02 04 12 00 15 11 00 09 06 01 01 33 1F 00 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 00 02 04 12 00 15 11 00 09 06 01 01 47 1F 00 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 00 02 04 12 00 03 11 00 09 06 00 00 60 01 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 78 25 7E
19:08:54
7E A8 D4 21 03 B8 4B BF 02 04 12 00 03 11 00 09 06 00 00 60 01 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 F0 19 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 00 04 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 00 04 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 00 01 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 3C 30 7E
19:08:54 Get next frame.
19:08:54 Collecting objects
19:08:54
7E A8 CD 21 03 BA 9B A6 02 04 12 00 03 11 00 09 06 00 00 61 61 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 2D 11 00 09 06 00 00 19 04 00 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 00 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 00 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 6E F4 7E
19:08:54
7E A8 B1 21 03 BC DC 0E 02 04 12 00 03 11 00 09 06 00 00 F0 1B 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 0F 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 84 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 85 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 72 98 7E
19:08:55
7E A8 F0 21 03 BE C2 27 02 04 12 00 29 11 00 09 06 00 00 19 00 00 FF 02 02 01 06 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 03 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 03 00 01 00 02 04 12 00 13 11 00 09 06 00 00 14 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 03 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 02 03 0F 09 16 03 00 01 00 02 04 12 00 13 11 00 09 06 00 00 14 00 01 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 03 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 02 03 0F 09 16 03 00 01 00 9B 44 7E
19:08:55 Get next frame.
19:08:55 Collecting objects
19:09:00 Data send failed. Try to resend 1/3
19:09:00
7E A8 B1 21 03 B0 B0 C4 02 04 12 00 17 11 01 09 06 00 00 16 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 01 00 02 04 12 00 03 11 00 09 06 00 00 60 02 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 00 00 60 02 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 A9 32 7E
19:09:00 Get next frame.
19:09:00 Collecting objects
19:09:00
7E A8 E9 21 03 B2 6C D7 02 04 12 00 03 11 00 09 06 00 00 60 03 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 00 00 60 03 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 00 00 F0 17 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 4E 58 11 00 09 06 00 00 F0 18 00 FF 02 02 01 0B 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 03 00 02 03 0F 04 16 03 00 02 03 0F 05 16 03 00 02 03 0F 06 16 03 00 02 03 0F 07 16 03 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 02 03 0F 0A 16 03 00 02 03 0F 0B 16 03 00 01 00 95 A4 7E
I get this error message
I get this error message every time i try to collect objects.
Hi Mikko, Regarding with…
Regarding with your last response. Do you have any upgrade for GXDLMSDirector in order to proper connect with Microstar meter?
I am still having the message "Cannot convert an object of type 'Gurux.DLMS.GXEnum' to type 'Gurux.DLMS.GXArray'"
I have not been answered by the meter manufacter. I will appreciate any support.
Hi, It's hard to fix meter…
You can now try to read the clock object.
Hi Mikko, I really…
Best regards,
Sebastian.
Hi, After you have added the…
Actually, I have added a…
Do you have any idea of what can I do?
Best regards,
Sebastian.
Hi Mikko, An additional…
Thank you in advance for your cooperation.
Best regards,
Sebastian.
HI Sebastian, The number of…
HI Sebastian,
The number of columns doesn't match the amount of capture objects that the meter returns.
Try to select the profile generic and select Refresh.
