  3. Push Setup Object
push setup object
By Shanmukhi , 23 October, 2024
After reading the current association, when I try to read the instant push setup object in the push setup, GURUX throws an error index. why?
Shanmukhi
2 years ago
we are using push setup…
we are using push setup version is 1.
2 years ago
Hi, There are multiple…
There are multiple reasons. It might be that your push setup object is not in the association view. Can you add the hex trace so I can check what might be the reason?
You can get the hex trace if you select "View", "Log" and "View Log".
Clear the log before you read the push object so unneeded traces are removed.
