  2. Shenzhen CLOU Electronics Meter Initial Settings
Shenzhen CLOU electronics meter Initial settings
Profile picture for user oulahsensaid
By oulahsensaid , 4 September, 2024
Hi Mr Kurumi, please what's the initial settings for Shenzhen CLOU electronics meter.
Thank you for your help.
1 year 9 months ago
Hi, You can see the correct…
You can see the correct settings if you select "Shen Zhen Clou Electronics Co Ltd" as the manufacturer in GXDLMSDirector.
oulahsensaid
1 year 8 months ago
Hi, Mr. Kurumi. After…
Hi, Mr. Kurumi.
After hundred attempts, I steal not able to connect to the meter.
GXDLMSDirector 9.0.2409.2501
Log created 12:12:00
12:12:01 Initializing serial connection.
12:12:02 IEC Sending:/?!<CR><LF>
12:12:03 HDLC received: /CLE5\2<CR><LF>
12:12:03 BaudRate is : 9600
12:12:03 Moving to mode E.
06 32 35 32 0D 0A
12:12:06 Send SNRM request.
7E A0 07 03 07 93 EC 76 7E
12:12:06
7E A0 20 07 03 73 91 4D 81 80 14 05 02 02 00 06 02 02 00 07 04 00 00 00 01 08 04 00 00 00 01 6F EF 7E
12:12:06 Parsing UA reply succeeded.
12:12:06 Send AARQ request.
7E A0 7B 03 07 10 0E 0D E6 E6 00 60 6D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 F7 52 02 39 91 11 11 11 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 22 80 20 5B 0D 75 40 52 0A 77 29 3C 1B 2A 0D 15 3B 3B 38 14 41 16 28 19 0C 0D 1F 19 54 2D 59 2F 3D 62 5C BE 23 04 21 21 1F 31 00 00 00 00 A3 09 FE 73 59 EE 89 D8 21 AB 1F FF F1 0A 7A F4 05 7E 4D 95 F3 A1 0F C3 28 71 99 0C 7E
12:12:11 Data send failed. Try to resend 1/3
12:12:11
7E A0 07 07 03 31 F5 F4 7E
12:12:11 Disconnect request
12:12:11
System.Exception: Frame is not fully received.
à Gurux.DLMS.GXDLMSClient.ParseAAREResponse(GXByteBuffer reply)
à GXDLMSDirector.GXDLMSCommunicator.ParseAAREResponse(GXByteBuffer data)
à GXDLMSDirector.GXDLMSCommunicator.InitializeConnection(Boolean force)
à GXDLMSDirector.GXDLMSDevice.InitializeConnection()
à GXDLMSDirector.MainForm.Connect(Object sender, GXAsyncWork work, Object[] parameters)
1 year 8 months ago
Hi, You have try to connect…
You have try to connect with secured connection. I don't know if your meter supports a ciphered connection. Can you try to connect without authentication or secured connection?
Create a new meter and don't change anything else than serial port settings. Can you connect?
oulahsensaid
1 year 8 months ago
Thank you for your quick…
Thank you for your quick response.
Yes, I can connect without any authentication, with all association view objects, but when I try to read an object it shows access denied.
13:53:49 Initializing serial connection.
13:53:50 IEC Sending:/?!<CR><LF>
13:53:51 HDLC received: /CLE5\2<CR><LF>
13:53:51 BaudRate is : 9600
13:53:51 Moving to mode E.
06 32 35 32 0D 0A
13:53:54 Send SNRM request.
7E A0 07 03 21 93 0F 01 7E
13:53:54
7E A0 20 21 03 73 73 98 81 80 14 05 02 02 00 06 02 02 00 07 04 00 00 00 01 08 04 00 00 00 01 6F EF 7E
13:53:54 Parsing UA reply succeeded.
13:53:54 Send AARQ request.
7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 1E 5D FF FF 88 55 7E
13:53:54
7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 10 02 40 00 07 DA AE 7E
13:53:54 Parsing AARE reply succeeded.
13:53:59 --- Collecting objects. ---
13:53:59 Collecting objects
7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 41 00 0F 00 00 28 00 00 FF 02 00 8A C1 7E
13:53:59
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 01 00 82 02 1F 01 82 15 02 02 04 12 00 01 11 00 09 06 00 00 00 09 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 00 09 02 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 00 09 05 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2A 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2B 01 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2B 01 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 02 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 04 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 05 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 06 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 09 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 0A FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 C9 1D 7E
13:53:59 Get next frame.
7E A0 07 03 21 51 11 E4 7E
13:53:59
7E A0 37 21 03 54 4E 59 00 01 11 00 09 06 00 00 60 01 0B FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 0C DA 5E 7E
13:53:59 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 01 04 34 7E
13:54:00
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 02 00 82 02 1F FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 02 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 02 0D FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 04 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 04 04 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 04 05 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 04 06 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 04 80 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 05 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 05 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 05 02 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 05 03 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 05 04 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 05 05 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 05 80 FF 02 02 01 02 02 03 D1 86 7E
13:54:00 Get next frame.
13:54:00 Collecting objects
7E A0 07 03 21 91 1D 22 7E
13:54:00
7E A0 37 21 03 78 20 B2 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 02 EE 7E
13:54:00 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 02 9F 06 7E
13:54:01
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 03 00 82 02 1F 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 02 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 03 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 04 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 05 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 06 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 07 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 08 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 09 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 15 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0A 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0A 03 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0A 04 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0A 05 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 17 20 7E
13:54:01 Get next frame.
13:54:01 Collecting objects
7E A0 07 03 21 D1 19 60 7E
13:54:01
7E A0 37 21 03 9C 0A 13 01 11 00 09 06 00 00 60 0B 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 02 FF 6B 3A 7E
13:54:01 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 03 16 17 7E
13:54:01
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 04 00 82 02 1F 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 03 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 04 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 05 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 06 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 07 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 08 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 09 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 0A FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0B 0D FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0D 86 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0D 87 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0D 88 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0D 89 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0D 8A FF 02 02 01 02 02 03 0F 03 D8 7E
7E A0 07 03 21 11 15 A6 7E
13:54:01
7E A0 37 21 03 B0 64 F8 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0D 8B FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 31 6B 7E
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 04 A9 63 7E
13:54:02
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 05 00 82 02 1F 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0D 8C FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0D 8D FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0E 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0E 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0E 09 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0F 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0F 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0F 02 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0F 03 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0F 04 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0F 05 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0F 06 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 14 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 14 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 C0 30 7E
13:54:02 Get next frame.
13:54:02 Collecting objects
13:54:02
7E A0 37 21 03 D4 46 DD 11 00 09 06 00 00 60 14 05 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 14 06 FF 02 72 64 7E
13:54:02 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 05 20 72 7E
13:54:03
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 06 00 82 02 1F 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 14 0F FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 14 19 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 32 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 32 03 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 32 04 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 32 16 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 32 20 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 32 24 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 32 25 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 02 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 03 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 04 FF 02 02 01 02 02 03 0F 01 50 8C 7E
13:54:03 Get next frame.
13:54:03 Collecting objects
13:54:03
7E A0 37 21 03 F8 28 36 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 05 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 5C 92 7E
13:54:03 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 06 BB 40 7E
13:54:03
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 07 00 82 02 1F 00 02 04 12 00 01 11 00 09 06 00 00 60 33 06 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 07 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 08 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 0A FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 0B FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 0C FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 0D FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 0E FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 0F FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 10 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 11 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 12 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 13 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 18 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 91 98 7E
13:54:03
7E A0 37 21 03 1C 02 97 00 09 06 00 00 60 33 1B FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 1C FF 02 02 FC CB 7E
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 07 32 51 7E
13:54:04
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 08 00 82 02 1F 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 1D FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 1F FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 23 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 24 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 33 28 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 36 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 3C 03 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 3C 04 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 48 02 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 48 03 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 5B 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 5B 09 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 5B 0B FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 5B 0C FF 02 02 01 02 02 03 0F 01 16 EE 42 7E
13:54:04 Get next frame.
13:54:04 Collecting objects
13:54:04
7E A0 37 21 03 30 6C 7C 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 5B 81 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 F1 FC 7E
13:54:04 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 08 C5 A9 7E
13:54:05
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 09 00 82 02 1F 02 04 12 00 01 11 00 09 06 00 01 00 02 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 01 60 01 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 01 60 01 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 01 60 0A 03 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 01 60 0B 04 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 01 60 32 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 01 60 32 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 01 60 32 02 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 01 60 32 03 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 01 60 32 04 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 01 60 33 0C FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 01 60 33 0D FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 01 60 33 0E FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 01 60 33 0F FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 0D 46 7E
13:54:05 Get next frame.
13:54:05 Collecting objects
13:54:05
7E A0 37 21 03 54 4E 59 09 06 00 02 60 01 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 02 60 01 01 FF 02 02 01 39 AC 7E
13:54:05 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 09 4C B8 7E
13:54:05
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 0A 00 82 02 1F 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 02 60 0A 03 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 02 60 0B 04 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 03 60 01 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 03 60 01 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 03 60 0A 03 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 03 60 0B 04 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 04 60 01 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 04 60 01 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 04 60 0A 03 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 04 60 0B 04 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 01 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 01 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 01 02 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 02 00 FF 02 02 01 02 02 03 0F 01 16 00 37 88 7E
13:54:05
7E A0 37 21 03 78 20 B2 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 02 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 F4 B3 7E
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 0A D7 8A 7E
13:54:06
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 0B 00 82 02 1F 04 12 00 01 11 00 09 06 01 00 00 02 08 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 02 7F FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 02 80 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 03 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 03 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 04 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 04 03 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 04 05 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 04 06 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 0B 80 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 0B 81 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 0B 82 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 0B 83 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 0B 84 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 D8 45 7E
13:54:06 Get next frame.
13:54:06 Collecting objects
13:54:06
7E A0 37 21 03 9C 0A 13 06 01 00 20 20 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 00 20 24 00 FF 02 02 01 02 8D B9 7E
13:54:06 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 0B 5E 9B 7E
13:54:07
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 0C 00 82 02 1F 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 00 34 20 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 00 34 24 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 00 48 20 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 00 48 24 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 01 00 02 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 01 00 02 08 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 02 00 02 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 02 00 02 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 02 00 02 03 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 01 11 00 09 06 01 02 00 02 08 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 03 11 00 09 06 00 00 00 01 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 06 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 07 0F FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 59 41 7E
13:54:07 Get next frame.
13:54:07 Collecting objects
13:54:07
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 07 10 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 12 AC 7E
13:54:07 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 0C E1 EF 7E
13:54:07
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 0D 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 07 11 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 07 12 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 07 13 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 07 14 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 07 81 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 08 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 08 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 08 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 08 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 A3 60 7E
13:54:08
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 00 00 60 08 0B FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 8A 5A 7E
13:54:08 Get Next Data block.
13:54:08 Collecting objects
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 0D 68 FE 7E
13:54:08
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 0E 00 82 02 1F 02 04 12 00 03 11 00 09 06 00 00 60 08 13 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 08 80 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 08 81 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 08 82 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 08 84 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 08 85 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 08 86 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 08 87 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 08 88 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 08 89 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 08 8D FF 02 02 59 3F 7E
13:54:08 Get next frame.
13:54:08
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 09 00 FF AC 86 7E
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 0E F3 CC 7E
13:54:09
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 0F 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 14 81 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 14 83 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 14 84 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 3C 28 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 5B 08 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 00 60 5B 0E FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 00 01 60 06 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 00 06 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 00 06 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 00 06 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 3D 55 7E
13:54:09 Get next frame.
13:54:09 Collecting objects
13:54:09
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 00 06 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 37 24 7E
13:54:09 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 0F 7A DD 7E
13:54:09
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 10 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 00 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 00 07 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 00 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 00 08 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 00 09 0B FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 00 09 0C FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 97 43 7E
13:54:10
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 01 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 6C 21 7E
13:54:10 Get Next Data block.
13:54:10 Collecting objects
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 10 0C 35 7E
13:54:10
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 11 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 01 8F B9 7E
13:54:10 Get next frame.
13:54:10
7E A0 37 21 03 54 4E 59 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 43 3D 7E
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 11 85 24 7E
13:54:11
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 12 00 82 02 1F 08 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 01 BE 7E
13:54:11 Get next frame.
13:54:11 Collecting objects
13:54:11
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 C5 68 7E
13:54:11 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 12 1E 16 7E
13:54:12
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 13 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 58 45 7E
13:54:12 Get next frame.
13:54:12 Collecting objects
13:54:12
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 22 BA 7E
13:54:12 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 13 97 07 7E
13:54:12
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 14 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 E7 05 7E
13:54:12
7E A0 37 21 03 B0 64 F8 01 08 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 C6 EF 7E
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 14 28 73 7E
13:54:13
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 15 00 82 02 1F 01 00 01 08 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 04 6D 02 02 01 03 02 03 0F 01 16 00 00 D1 3C 7E
13:54:13 Get next frame.
13:54:13 Collecting objects
13:54:13
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 04 6E 02 02 01 03 02 03 0F 01 16 07 49 7E
13:54:13 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 15 A1 62 7E
13:54:14
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 16 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 08 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 ED 21 7E
13:54:14 Get next frame.
13:54:14 Collecting objects
13:54:14
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 03 42 7E
13:54:14 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 16 3A 50 7E
13:54:14
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 17 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 97 EF 7E
13:54:14
7E A0 37 21 03 1C 02 97 06 01 00 01 09 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 11 DE 7E
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 17 B3 41 7E
13:54:15
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 18 00 82 02 1F 00 09 06 01 00 01 09 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 02 68 02 02 01 03 02 03 0F 01 BB 8A 7E
13:54:15 Get next frame.
13:54:15 Collecting objects
13:54:15
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 02 69 02 02 01 03 02 03 0F DF 7E
13:54:15 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 18 44 B9 7E
13:54:16
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 19 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 40 5D 7E
13:54:16 Get next frame.
13:54:16 Collecting objects
13:54:16
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 64 3A 7E
13:54:16 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 19 CD A8 7E
13:54:16
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 1A 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 16 0B 7E
13:54:16
7E A0 37 21 03 78 20 B2 11 00 09 06 01 00 01 09 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 2B 5D 7E
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 1A 56 9A 7E
13:54:17
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 1B 00 82 02 1F 00 03 11 00 09 06 01 00 01 09 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 04 70 02 02 01 03 02 DD 41 7E
13:54:17 Get next frame.
13:54:17 Collecting objects
13:54:17
7E A0 37 21 03 9C 0A 13 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 04 65 02 02 01 86 BD 7E
13:54:17 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 1B DF 8B 7E
13:54:18
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 1C 00 82 02 1F 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 09 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 22 B8 7E
13:54:18 Get next frame.
13:54:18 Collecting objects
13:54:18
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 B9 7B 7E
13:54:18 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 1C 60 FF 7E
13:54:18
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 1D 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 10 38 7E
13:54:19
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 01 00 01 13 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 A8 D6 7E
13:54:19 Get Next Data block.
13:54:19 Collecting objects
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 1D E9 EE 7E
13:54:19
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 1E 00 82 02 1F 02 04 12 00 03 11 00 09 06 01 00 01 13 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 02 6B 02 02 9A 0F 7E
13:54:19 Get next frame.
13:54:19
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 02 6C 95 64 7E
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 1E 72 DC 7E
13:54:20
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 1F 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 AF 4D 7E
13:54:20 Get next frame.
13:54:20 Collecting objects
13:54:20
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 56 61 7E
13:54:20 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 1F FB CD 7E
13:54:20
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 20 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 EE 8D 7E
13:54:21
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 01 13 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 2A C4 7E
13:54:21 Get Next Data block.
13:54:21 Collecting objects
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 20 8F 04 7E
13:54:21
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 21 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 13 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 1B 00 4A 74 7E
13:54:21 Get next frame.
7E A0 07 03 21 51 11 E4 7E
13:54:21
7E A0 37 21 03 54 4E 59 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 CA 4F 7E
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 21 06 15 7E
13:54:22
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 22 00 82 02 1F 1D 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 1D 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 1D 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 1D 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 1D 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 1E 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 1E 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 1E 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 1E 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 1E 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F DA 34 7E
13:54:22 Get next frame.
13:54:22 Collecting objects
7E A0 07 03 21 91 1D 22 7E
13:54:22
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 01 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 7A FF 7E
13:54:22 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 22 9D 27 7E
13:54:23
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 23 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 F7 3C 7E
13:54:23 Get next frame.
13:54:23 Collecting objects
7E A0 07 03 21 D1 19 60 7E
13:54:23
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 A7 D3 7E
13:54:23 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 23 14 36 7E
13:54:23
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 24 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 88 AE 7E
7E A0 07 03 21 11 15 A6 7E
13:54:23
7E A0 37 21 03 B0 64 F8 02 08 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 6A A1 7E
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 24 AB 42 7E
13:54:24
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 25 00 82 02 1F 01 00 02 08 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 02 6B 02 02 01 03 02 03 0F 01 16 00 00 99 80 7E
13:54:24 Get next frame.
13:54:24 Collecting objects
13:54:24
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 02 6C 02 02 01 03 02 03 0F 01 16 C9 EA 7E
13:54:24 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 25 22 53 7E
13:54:25
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 26 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 A2 44 7E
13:54:25 Get next frame.
13:54:25 Collecting objects
13:54:25
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 83 0C 7E
13:54:25 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 26 B9 61 7E
13:54:25
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 27 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 BB A3 7E
13:54:25
7E A0 37 21 03 1C 02 97 06 01 00 02 08 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 2C 25 7E
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 27 30 70 7E
13:54:26
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 28 00 82 02 1F 00 09 06 01 00 02 08 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 08 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 00 66 02 02 01 03 02 03 0F 01 B7 24 7E
13:54:26 Get next frame.
13:54:26 Collecting objects
13:54:26
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 00 67 02 02 01 03 02 03 28 26 7E
13:54:26 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 28 C7 88 7E
13:54:27
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 29 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 7E 6A 7E
13:54:27 Get next frame.
13:54:27 Collecting objects
13:54:27
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F D2 18 7E
13:54:27 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 29 4E 99 7E
13:54:27
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 2A 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 4A B9 7E
13:54:27
7E A0 37 21 03 78 20 B2 11 00 09 06 01 00 02 09 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 C8 05 7E
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 2A D5 AB 7E
13:54:28
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 2B 00 82 02 1F 00 03 11 00 09 06 01 00 02 09 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 02 6E 02 02 01 03 02 89 09 7E
13:54:28 Get next frame.
13:54:28 Collecting objects
13:54:28
7E A0 37 21 03 9C 0A 13 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 02 6F 02 02 01 DE F2 7E
13:54:28 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 2B 5C BA 7E
13:54:29
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 2C 00 82 02 1F 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 4F 2A 7E
13:54:29 Get next frame.
13:54:29 Collecting objects
13:54:29
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 7D 7C 7E
13:54:29 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 2C E3 CE 7E
13:54:29
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 2D 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 62 45 7E
13:54:29
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 01 00 02 09 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 A2 4B 7E
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 2D 6A DF 7E
13:54:30
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 2E 00 82 02 1F 02 04 12 00 03 11 00 09 06 01 00 02 09 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 09 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 00 69 02 02 BC 28 7E
13:54:30 Get next frame.
13:54:30 Collecting objects
13:54:30
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 00 6A DE 17 7E
13:54:30 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 2E F1 ED 7E
13:54:31
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 2F 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 51 5E 7E
13:54:31 Get next frame.
13:54:31 Collecting objects
13:54:31
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 B3 E8 7E
13:54:31 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 2F 78 FC 7E
13:54:31
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 30 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 84 5A 7E
13:54:32
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 02 13 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 4C 9A 7E
13:54:32 Get Next Data block.
13:54:32 Collecting objects
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 30 0E 14 7E
13:54:32
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 31 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 02 CC 63 7E
13:54:32 Get next frame.
13:54:32
7E A0 37 21 03 54 4E 59 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 05 19 7E
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 31 87 05 7E
13:54:33
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 32 00 82 02 1F 13 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 84 AA 7E
13:54:33 Get next frame.
13:54:33 Collecting objects
13:54:33
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 D8 E0 7E
13:54:33 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 32 1C 37 7E
13:54:33
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 33 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 45 B1 7E
13:54:34
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 C0 90 7E
13:54:34 Get Next Data block.
13:54:34 Collecting objects
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 33 95 26 7E
13:54:34
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 34 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 13 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 1D 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 1D 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 1D 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 1D 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 1D 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 28 7C 7E
13:54:34 Get next frame.
13:54:34
7E A0 37 21 03 B0 64 F8 02 1E 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 CC AC 7E
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 34 2A 52 7E
13:54:35
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 35 00 82 02 1F 01 00 02 1E 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 1E 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 1E 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 1E 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 02 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 B1 C6 7E
13:54:35 Get next frame.
13:54:35 Collecting objects
13:54:35
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 00 6A 02 02 01 03 02 03 0F 01 16 94 AC 7E
13:54:35 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 35 A3 43 7E
13:54:35
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 36 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 7E 09 7E
13:54:36
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 DA 58 7E
13:54:36 Get Next Data block.
13:54:36 Collecting objects
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 36 38 71 7E
13:54:36
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 37 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 90 7B 7E
13:54:36 Get next frame.
13:54:36
7E A0 37 21 03 1C 02 97 06 01 00 03 08 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 65 41 7E
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 37 B1 60 7E
13:54:37
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 38 00 82 02 1F 00 09 06 01 00 03 08 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 02 65 02 02 01 03 02 03 0F 01 D8 D2 7E
13:54:37 Get next frame.
13:54:37 Collecting objects
13:54:37
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 02 FF 02 02 01 03 02 03 A5 A1 7E
13:54:37 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 38 46 98 7E
13:54:38
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 39 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 0F B0 7E
13:54:38 Get next frame.
13:54:38 Collecting objects
13:54:38
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 0C EA 7E
13:54:38 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 39 CF 89 7E
13:54:38
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 3A 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 5A 82 7E
13:54:38
7E A0 37 21 03 78 20 B2 11 00 09 06 01 00 03 08 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 C1 D2 7E
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 3A 54 BB 7E
13:54:39
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 3B 00 82 02 1F 00 03 11 00 09 06 01 00 03 08 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 08 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 00 6C 02 02 01 03 02 70 F6 7E
13:54:39 Get next frame.
13:54:39 Collecting objects
13:54:39
7E A0 37 21 03 9C 0A 13 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 00 6D 02 02 01 F5 42 7E
13:54:39 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 3B DD AA 7E
13:54:40
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 3C 00 82 02 1F 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 81 CB 7E
13:54:40 Get next frame.
13:54:40 Collecting objects
13:54:40
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 18 10 7E
13:54:40 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 3C 62 DE 7E
13:54:40
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 3D 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 92 DE 7E
13:54:40
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 01 00 03 09 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 D1 7C 7E
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 3D EB CF 7E
13:54:41
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 3E 00 82 02 1F 02 04 12 00 03 11 00 09 06 01 00 03 09 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 03 67 02 02 CC A7 7E
13:54:41 Get next frame.
13:54:41 Collecting objects
13:54:41
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 03 68 F0 F4 7E
13:54:41 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 3E 70 FD 7E
13:54:42
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 3F 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 79 16 7E
13:54:42 Get next frame.
13:54:42 Collecting objects
13:54:42
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 41 B7 7E
13:54:42 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 3F F9 EC 7E
13:54:42
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 40 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 59 8C 7E
13:54:42
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 03 09 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 09 02 7E
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 40 89 67 7E
13:54:43
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 41 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 09 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 00 16 FE 7E
13:54:43 Get next frame.
13:54:43 Collecting objects
7E A0 07 03 21 51 11 E4 7E
13:54:43
7E A0 37 21 03 54 4E 59 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 25 45 7E
13:54:43 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 41 00 76 7E
13:54:44
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 42 00 82 02 1F 13 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 47 1E 7E
13:54:44 Get next frame.
13:54:44 Collecting objects
7E A0 07 03 21 91 1D 22 7E
13:54:44
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 4A F9 7E
13:54:44 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 42 9B 44 7E
13:54:44
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 43 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 BF E0 7E
7E A0 07 03 21 D1 19 60 7E
13:54:44
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 5D C7 7E
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 43 12 55 7E
13:54:45
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 44 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 82 98 7E
13:54:45 Get next frame.
13:54:45 Collecting objects
7E A0 07 03 21 11 15 A6 7E
13:54:45
7E A0 37 21 03 B0 64 F8 03 13 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 D9 B9 7E
13:54:45 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 44 AD 21 7E
13:54:46
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 45 00 82 02 1F 01 00 03 13 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 04 68 02 02 01 03 02 03 0F 01 16 00 00 2E EC 7E
13:54:46 Get next frame.
13:54:46 Collecting objects
13:54:46
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 04 69 02 02 01 03 02 03 0F 01 16 72 1E 7E
13:54:46 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 45 24 30 7E
13:54:46
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 46 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 13 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 F7 9B 7E
13:54:47
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 1D 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 55 FD 7E
13:54:47 Get Next Data block.
13:54:47 Collecting objects
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 46 BF 02 7E
13:54:47
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 47 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 1D 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 1D 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 1D 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 1D 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 1E 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 1E 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 1E 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 1E 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 1E 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 03 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 8C 56 7E
13:54:47 Get next frame.
13:54:47
7E A0 37 21 03 1C 02 97 06 01 00 03 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 52 46 7E
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 47 36 13 7E
13:54:48
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 48 00 82 02 1F 00 09 06 01 00 04 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 00 6F 02 02 01 03 02 03 0F 01 90 E7 7E
13:54:48 Get next frame.
13:54:48 Collecting objects
13:54:48
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 00 70 02 02 01 03 02 03 D6 F1 7E
13:54:48 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 48 C1 EB 7E
13:54:48
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 49 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 1F 69 7E
13:54:49
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F D4 A4 7E
13:54:49 Get Next Data block.
13:54:49 Collecting objects
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 49 48 FA 7E
13:54:49
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 4A 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 E1 D0 7E
13:54:49 Get next frame.
13:54:49
7E A0 37 21 03 78 20 B2 11 00 09 06 01 00 04 08 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 4B 62 7E
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 4A D3 C8 7E
13:54:50
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 4B 00 82 02 1F 00 03 11 00 09 06 01 00 04 08 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 03 6A 02 02 01 03 02 64 FF 7E
13:54:50 Get next frame.
13:54:50 Collecting objects
13:54:50
7E A0 37 21 03 9C 0A 13 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 03 6B 02 02 01 90 D7 7E
13:54:50 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 4B 5A D9 7E
13:54:51
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 4C 00 82 02 1F 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0A C4 7E
13:54:51 Get next frame.
13:54:51 Collecting objects
13:54:51
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 6A F5 7E
13:54:51 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 4C E5 AD 7E
13:54:51
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 4D 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 08 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 20 0A 7E
13:54:51
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 01 00 04 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 18 2B 7E
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 4D 6C BC 7E
13:54:52
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 4E 00 82 02 1F 02 04 12 00 03 11 00 09 06 01 00 04 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 00 FF 02 02 FA AF 7E
13:54:52 Get next frame.
13:54:52 Collecting objects
13:54:52
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 01 66 1F 79 7E
13:54:52 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 4E F7 8E 7E
13:54:53
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 4F 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 DB 38 7E
13:54:53 Get next frame.
13:54:53 Collecting objects
13:54:53
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 9F 9D 7E
13:54:53 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 4F 7E 9F 7E
13:54:53
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 50 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 8B B5 7E
13:54:53
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 04 09 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F E9 1F 7E
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 50 08 77 7E
13:54:54
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 51 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 03 2F 8D 7E
13:54:54 Get next frame.
13:54:54 Collecting objects
13:54:54
7E A0 37 21 03 54 4E 59 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 47 27 7E
13:54:54 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 51 81 66 7E
13:54:55
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 52 00 82 02 1F 09 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 8E 0F 7E
13:54:55 Get next frame.
13:54:55 Collecting objects
13:54:55
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 C2 AE 7E
13:54:55 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 52 1A 54 7E
13:54:55
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 53 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 09 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 02 1A 7E
13:54:55
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 E6 C2 7E
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 53 93 45 7E
13:54:56
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 54 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 69 18 7E
13:54:56 Get next frame.
13:54:56 Collecting objects
13:54:56
7E A0 37 21 03 B0 64 F8 04 13 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 CF DA 7E
13:54:56 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 54 2C 31 7E
13:54:57
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 55 00 82 02 1F 01 00 04 13 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 02 66 02 02 01 03 02 03 0F 01 16 00 00 A4 55 7E
13:54:57 Get next frame.
13:54:57 Collecting objects
13:54:57
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 02 67 02 02 01 03 02 03 0F 01 16 BD 72 7E
13:54:57 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 55 A5 20 7E
13:54:57
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 56 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 FC 8D 7E
13:54:57
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 5F 72 7E
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 56 3E 12 7E
13:54:58
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 57 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 03 52 7E
13:54:58 Get next frame.
13:54:58 Collecting objects
13:54:58
7E A0 37 21 03 1C 02 97 06 01 00 04 13 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 79 B7 7E
13:54:58 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 57 B7 03 7E
13:54:59
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 58 00 82 02 1F 00 09 06 01 00 04 13 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 04 6E 02 02 01 03 02 03 0F 01 7A 9D 7E
13:54:59 Get next frame.
13:54:59 Collecting objects
13:54:59
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 04 6F 02 02 01 03 02 03 6C 1D 7E
13:54:59 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 58 40 FB 7E
13:54:59
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 59 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 13 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 1D 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 1D 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 1D 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 1D 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 1D 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 1E 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 2F AD 7E
13:55:00
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 1E 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F D9 9C 7E
13:55:00 Get Next Data block.
13:55:00 Collecting objects
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 59 C9 EA 7E
13:55:00
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 5A 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 1E 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 1E 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 1E 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 04 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 C1 7F 7E
13:55:00 Get next frame.
13:55:00
7E A0 37 21 03 78 20 B2 11 00 09 06 01 00 05 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 01 B4 7E
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 5A 52 D8 7E
13:55:01
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 5B 00 82 02 1F 00 03 11 00 09 06 01 00 05 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 01 68 02 02 01 03 02 B9 35 7E
13:55:01 Get next frame.
13:55:01 Collecting objects
13:55:01
7E A0 37 21 03 9C 0A 13 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 01 69 02 02 01 BB 67 7E
13:55:01 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 5B DB C9 7E
13:55:01
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 5C 00 82 02 1F 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 30 F5 7E
13:55:02
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 68 46 7E
13:55:02 Get Next Data block.
13:55:02 Collecting objects
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 5C 64 BD 7E
13:55:02
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 5D 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 58 B8 7E
13:55:02 Get next frame.
13:55:02
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 01 00 05 08 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 0C 28 7E
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 5D ED AC 7E
13:55:03
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 5E 00 82 02 1F 02 04 12 00 03 11 00 09 06 01 00 05 08 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 03 70 02 02 CC D4 7E
13:55:03 Get next frame.
13:55:03 Collecting objects
13:55:03
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 03 65 53 3E 7E
13:55:03 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 5E 76 9E 7E
13:55:04
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 5F 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 75 C8 7E
13:55:04 Get next frame.
13:55:04 Collecting objects
13:55:04
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 F7 E2 7E
13:55:04 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 5F FF 8F 7E
13:55:04
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 60 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 08 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 E0 31 7E
13:55:04
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 05 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 89 22 7E
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 60 8B 46 7E
13:55:05
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 61 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 01 C6 EF 7E
13:55:05 Get next frame.
13:55:05 Collecting objects
7E A0 07 03 21 51 11 E4 7E
13:55:05
7E A0 37 21 03 54 4E 59 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 A9 0D 7E
13:55:05 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 61 02 57 7E
13:55:06
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 62 00 82 02 1F 09 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 86 E4 7E
13:55:06 Get next frame.
13:55:06 Collecting objects
7E A0 07 03 21 91 1D 22 7E
13:55:06
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 51 33 7E
13:55:06 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 62 99 65 7E
13:55:06
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 63 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 89 67 7E
7E A0 07 03 21 D1 19 60 7E
13:55:06
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 C0 C1 7E
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 63 10 74 7E
13:55:07
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 64 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 B3 D8 7E
13:55:07 Get next frame.
13:55:07 Collecting objects
7E A0 07 03 21 11 15 A6 7E
13:55:07
7E A0 37 21 03 B0 64 F8 05 09 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 76 64 7E
13:55:07 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 64 AF 00 7E
13:55:08
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 65 00 82 02 1F 01 00 05 09 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 04 65 02 02 01 03 02 03 0F 01 16 00 00 D9 6F 7E
13:55:08 Get next frame.
13:55:08 Collecting objects
13:55:08
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 09 04 FF 02 02 01 03 02 03 0F 01 16 65 86 7E
13:55:08 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 65 26 11 7E
13:55:08
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 66 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 B3 25 7E
13:55:08
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 EB 3D 7E
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 66 BD 23 7E
13:55:09
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 67 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 50 3C 7E
13:55:09 Get next frame.
13:55:09 Collecting objects
13:55:09
7E A0 37 21 03 1C 02 97 06 01 00 05 13 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 EE 5B 7E
13:55:09 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 67 34 32 7E
13:55:10
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 68 00 82 02 1F 00 09 06 01 00 05 13 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 02 6C 02 02 01 03 02 03 0F 01 D4 1D 7E
13:55:10 Get next frame.
13:55:10 Collecting objects
13:55:10
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 02 6D 02 02 01 03 02 03 41 1B 7E
13:55:10 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 68 C3 CA 7E
13:55:10
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 69 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 31 17 7E
13:55:11
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F FC 1C 7E
13:55:11 Get Next Data block.
13:55:11 Collecting objects
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 69 4A DB 7E
13:55:11
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 6A 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 F6 27 7E
13:55:11 Get next frame.
13:55:11
7E A0 37 21 03 78 20 B2 11 00 09 06 01 00 05 13 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 37 DF 7E
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 6A D1 E9 7E
13:55:12
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 6B 00 82 02 1F 00 03 11 00 09 06 01 00 05 13 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 13 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 1D 00 FF 02 02 01 03 02 50 85 7E
13:55:12 Get next frame.
13:55:12 Collecting objects
13:55:12
7E A0 37 21 03 9C 0A 13 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 1D 01 FF 02 02 01 D9 94 7E
13:55:12 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 6B 58 F8 7E
13:55:12
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 6C 00 82 02 1F 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 1D 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 1D 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 1D 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 1E 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 1E 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 1E 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 1E 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 05 1E 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 61 7E 7E
13:55:13
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 23 03 7E
13:55:13 Get Next Data block.
13:55:13 Collecting objects
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 6C E7 8C 7E
13:55:13
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 6D 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 AF 92 7E
13:55:13 Get next frame.
13:55:13
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 01 00 06 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 8E F4 7E
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 6D 6E 9D 7E
13:55:14
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 6E 00 82 02 1F 02 04 12 00 03 11 00 09 06 01 00 06 08 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 01 70 02 02 A3 5D 7E
13:55:14 Get next frame.
13:55:14 Collecting objects
13:55:14
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 01 65 2E 28 7E
13:55:14 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 6E F5 AF 7E
13:55:15
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 6F 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 A6 B0 7E
13:55:15 Get next frame.
13:55:15 Collecting objects
13:55:15
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 1F 3F 7E
13:55:15 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 6F 7C BE 7E
13:55:15
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 70 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 FA 63 7E
13:55:15
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 06 08 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 2B 09 7E
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 70 0A 56 7E
13:55:16
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 71 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 04 89 2D 7E
13:55:16 Get next frame.
13:55:16 Collecting objects
13:55:16
7E A0 37 21 03 54 4E 59 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 32 3F 7E
13:55:16 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 71 83 47 7E
13:55:17
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 72 00 82 02 1F 08 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 08 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F DF 14 7E
13:55:17 Get next frame.
13:55:17 Collecting objects
13:55:17
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 A4 54 7E
13:55:17 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 72 18 75 7E
13:55:17
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 73 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 22 51 7E
13:55:17
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 FE 7C 7E
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 73 91 64 7E
13:55:18
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 74 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 D9 31 7E
13:55:18 Get next frame.
13:55:18 Collecting objects
13:55:18
7E A0 37 21 03 B0 64 F8 06 09 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 6C E4 7E
13:55:18 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 74 2E 10 7E
13:55:19
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 75 00 82 02 1F 01 00 06 09 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 02 65 02 02 01 03 02 03 0F 01 16 00 00 05 EE 7E
13:55:19 Get next frame.
13:55:19 Collecting objects
13:55:19
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 02 FF 02 02 01 03 02 03 0F 01 16 E5 7D 7E
13:55:19 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 75 A7 01 7E
13:55:19
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 76 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 FA 76 7E
13:55:19
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 1E 12 7E
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 76 3C 33 7E
13:55:20
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 77 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 C8 7B 7E
13:55:20 Get next frame.
13:55:20 Collecting objects
13:55:20
7E A0 37 21 03 1C 02 97 06 01 00 06 09 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 1D 14 7E
13:55:20 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 77 B5 22 7E
13:55:21
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 78 00 82 02 1F 00 09 06 01 00 06 09 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 09 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 00 6C 02 02 01 03 02 03 0F 01 7E B4 7E
13:55:21 Get next frame.
13:55:21 Collecting objects
13:55:21
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 00 6D 02 02 01 03 02 03 47 64 7E
13:55:21 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 78 42 DA 7E
13:55:21
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 79 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 B0 9D 7E
13:55:21
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F F2 0B 7E
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 79 CB CB 7E
13:55:22
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 7A 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 F8 EC 7E
13:55:22 Get next frame.
13:55:22 Collecting objects
13:55:22
7E A0 37 21 03 78 20 B2 11 00 09 06 01 00 06 13 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 FA 2B 7E
13:55:22 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 7A 50 F9 7E
13:55:23
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 7B 00 82 02 1F 00 03 11 00 09 06 01 00 06 13 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 03 67 02 02 01 03 02 D9 E8 7E
13:55:23 Get next frame.
13:55:23 Collecting objects
13:55:23
7E A0 37 21 03 9C 0A 13 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 03 68 02 02 01 73 AA 7E
13:55:23 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 7B D9 E8 7E
13:55:23
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 7C 00 82 02 1F 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 97 11 7E
13:55:24
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 37 71 7E
13:55:24 Get Next Data block.
13:55:24 Collecting objects
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 7C 66 9C 7E
13:55:24
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 7D 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 13 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 B5 BD 7E
13:55:24 Get next frame.
13:55:24
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 01 00 06 13 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 11 4E 7E
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 7D EF 8D 7E
13:55:25
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 7E 00 82 02 1F 02 04 12 00 03 11 00 09 06 01 00 06 13 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 1D 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 1D 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 1D 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 1D 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 1D 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 1E 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 1E 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 1E 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 1E 03 FF 02 02 99 CD 7E
13:55:25 Get next frame.
13:55:25 Collecting objects
13:55:25
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 06 1E 04 FF 09 3E 7E
13:55:25 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 7E 74 BF 7E
13:55:25
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 7F 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 7D 5F 7E
13:55:26
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 48 8C 7E
13:55:26 Get Next Data block.
13:55:26 Collecting objects
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 7F FD AE 7E
13:55:26
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 80 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 46 D3 7E
13:55:26 Get next frame.
13:55:26
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 07 08 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 32 B6 7E
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 80 85 A1 7E
13:55:27
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 81 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 02 AE 74 7E
13:55:27 Get next frame.
13:55:27 Collecting objects
7E A0 07 03 21 51 11 E4 7E
13:55:27
7E A0 37 21 03 54 4E 59 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 BB 2E 7E
13:55:27 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 81 0C B0 7E
13:55:28
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 82 00 82 02 1F 08 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 49 F5 7E
13:55:28 Get next frame.
13:55:28 Collecting objects
7E A0 07 03 21 91 1D 22 7E
13:55:28
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 A0 11 7E
13:55:28 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 82 97 82 7E
13:55:28
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 83 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 E8 54 7E
7E A0 07 03 21 D1 19 60 7E
13:55:28
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 FF 9C 7E
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 83 1E 93 7E
13:55:29
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 84 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 08 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 15 7E
13:55:29 Get next frame.
13:55:29 Collecting objects
7E A0 07 03 21 11 15 A6 7E
13:55:29
7E A0 37 21 03 B0 64 F8 07 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 95 63 7E
13:55:29 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 84 A1 E7 7E
13:55:30
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 85 00 82 02 1F 01 00 07 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 92 32 7E
13:55:30 Get next frame.
13:55:30 Collecting objects
13:55:30
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 00 FF 02 02 01 03 02 03 0F 01 16 6A D3 7E
13:55:30 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 85 28 F6 7E
13:55:30
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 86 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 26 14 7E
13:55:30
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 B1 4E 7E
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 86 B3 C4 7E
13:55:31
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 87 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 C1 A9 7E
13:55:31 Get next frame.
13:55:31 Collecting objects
13:55:31
7E A0 37 21 03 1C 02 97 06 01 00 07 09 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 18 25 7E
13:55:31 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 87 3A D5 7E
13:55:32
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 88 00 82 02 1F 00 09 06 01 00 07 09 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 03 6C 02 02 01 03 02 03 0F 01 07 7A 7E
13:55:32 Get next frame.
13:55:32 Collecting objects
13:55:32
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 03 6D 02 02 01 03 02 03 14 D9 7E
13:55:32 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 88 CD 2D 7E
13:55:32
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 89 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 B7 8B 7E
13:55:32
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F D9 51 7E
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 89 44 3C 7E
13:55:33
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 8A 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 09 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 46 D6 7E
13:55:33 Get next frame.
13:55:33 Collecting objects
13:55:33
7E A0 37 21 03 78 20 B2 11 00 09 06 01 00 07 13 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 41 78 7E
13:55:33 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 8A DF 0E 7E
13:55:34
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 8B 00 82 02 1F 00 03 11 00 09 06 01 00 07 13 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 01 67 02 02 01 03 02 DC 41 7E
13:55:34 Get next frame.
13:55:34 Collecting objects
13:55:34
7E A0 37 21 03 9C 0A 13 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 01 68 02 02 01 2E 23 7E
13:55:34 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 8B 56 1F 7E
13:55:34
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 8C 00 82 02 1F 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 C5 6B 7E
13:55:34
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 BC 0B 7E
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 8C E9 6B 7E
13:55:35
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 8D 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 AB 3F 7E
13:55:35 Get next frame.
13:55:35 Collecting objects
13:55:35
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 01 00 07 13 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 D8 DA 7E
13:55:35 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 8D 60 7A 7E
13:55:36
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 8E 00 82 02 1F 02 04 12 00 03 11 00 09 06 01 00 07 13 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 03 6F 02 02 3B AE 7E
13:55:36 Get next frame.
13:55:36 Collecting objects
13:55:36
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 03 70 3A EC 7E
13:55:36 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 8E FB 48 7E
13:55:36
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 8F 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 AB 2E 7E
13:55:37
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 9C 4A 7E
13:55:37 Get Next Data block.
13:55:37 Collecting objects
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 8F 72 59 7E
13:55:37
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 90 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 13 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 1D 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 1D 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 1D 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 1D 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 1D 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 DA 76 7E
13:55:37 Get next frame.
13:55:37
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 07 1E 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F FB 4B 7E
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 90 04 B1 7E
13:55:38
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 91 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 1E 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 1E 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 1E 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 07 1E 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 00 D9 FB 7E
13:55:38 Get next frame.
13:55:38 Collecting objects
13:55:38
7E A0 37 21 03 54 4E 59 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 4C D6 7E
13:55:38 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 91 8D A0 7E
13:55:39
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 92 00 82 02 1F 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F C3 F7 7E
13:55:39 Get next frame.
13:55:39 Collecting objects
13:55:39
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 F3 0E 7E
13:55:39 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 92 16 92 7E
13:55:39
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 93 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 A0 7E 7E
13:55:39
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 13 C8 7E
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 93 9F 83 7E
13:55:40
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 94 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 84 CE 7E
13:55:40 Get next frame.
13:55:40 Collecting objects
13:55:40
7E A0 37 21 03 B0 64 F8 08 08 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 03 32 7E
13:55:40 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 94 20 F7 7E
13:55:41
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 95 00 82 02 1F 01 00 08 08 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 03 65 02 02 01 03 02 03 0F 01 16 00 00 03 B1 7E
13:55:41 Get next frame.
13:55:41 Collecting objects
13:55:41
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 03 FF 02 02 01 03 02 03 0F 01 16 A7 9D 7E
13:55:41 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 95 A9 E6 7E
13:55:41
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 96 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 6E 23 7E
13:55:41
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 34 C6 7E
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 96 32 D4 7E
13:55:42
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 97 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 08 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 B4 3F 7E
13:55:42 Get next frame.
13:55:42 Collecting objects
13:55:42
7E A0 37 21 03 1C 02 97 06 01 00 08 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 F9 71 7E
13:55:42 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 97 BB C5 7E
13:55:43
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 98 00 82 02 1F 00 09 06 01 00 08 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 01 6C 02 02 01 03 02 03 0F 01 EF B0 7E
13:55:43 Get next frame.
13:55:43 Collecting objects
13:55:43
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 01 6D 02 02 01 03 02 03 A7 7F 7E
13:55:43 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 98 4C 3D 7E
13:55:43
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 99 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 C6 93 7E
13:55:43
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F E5 43 7E
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 99 C5 2C 7E
13:55:44
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 9A 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 0E 19 7E
13:55:44 Get next frame.
13:55:44 Collecting objects
13:55:44
7E A0 37 21 03 78 20 B2 11 00 09 06 01 00 08 09 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 54 88 7E
13:55:44 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 9A 5E 1E 7E
13:55:45
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 9B 00 82 02 1F 00 03 11 00 09 06 01 00 08 09 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 04 67 02 02 01 03 02 88 A2 7E
13:55:45 Get next frame.
13:55:45 Collecting objects
13:55:45
7E A0 37 21 03 9C 0A 13 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 04 68 02 02 01 30 77 7E
13:55:45 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 9B D7 0F 7E
13:55:45
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 9C 00 82 02 1F 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 09 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 4B CF 7E
13:55:45
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 1C 99 7E
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 9C 68 7B 7E
13:55:46
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 9D 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 17 BB 7E
13:55:46 Get next frame.
13:55:46 Collecting objects
13:55:46
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 01 00 08 13 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 A9 05 7E
13:55:46 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 9D E1 6A 7E
13:55:47
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 9E 00 82 02 1F 02 04 12 00 03 11 00 09 06 01 00 08 13 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 01 6F 02 02 EF 19 7E
13:55:47 Get next frame.
13:55:47 Collecting objects
13:55:47
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 01 70 73 6D 7E
13:55:47 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 9E 7A 58 7E
13:55:47
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 9F 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 F7 F4 7E
13:55:48
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 7E 70 7E
13:55:48 Get Next Data block.
13:55:48 Collecting objects
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 9F F3 49 7E
13:55:48
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 A0 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 21 CA 7E
13:55:48 Get next frame.
13:55:48
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 08 13 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F E1 4B 7E
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 A0 87 80 7E
13:55:49
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 A1 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 04 AF C1 7E
13:55:49 Get next frame.
13:55:49 Collecting objects
7E A0 07 03 21 51 11 E4 7E
13:55:49
7E A0 37 21 03 54 4E 59 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 2A 59 7E
13:55:49 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 A1 0E 91 7E
13:55:49
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 A2 00 82 02 1F 13 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 13 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 1D 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 1D 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 82 E8 7E
7E A0 07 03 21 91 1D 22 7E
13:55:50
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 1D 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 D1 C0 7E
13:55:50 Get Next Data block.
13:55:50 Collecting objects
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 A2 95 A3 7E
13:55:50
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 A3 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 1D 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 1D 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 1E 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 1E 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 1E 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 1E 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 08 1E 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 93 DD 7E
13:55:50 Get next frame.
7E A0 07 03 21 D1 19 60 7E
13:55:50
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 54 F7 7E
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 A3 1C B2 7E
13:55:51
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 A4 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 B8 A4 7E
13:55:51 Get next frame.
13:55:51 Collecting objects
7E A0 07 03 21 11 15 A6 7E
13:55:51
7E A0 37 21 03 B0 64 F8 09 08 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 FA B5 7E
13:55:51 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 A4 A3 C6 7E
13:55:52
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 A5 00 82 02 1F 01 00 09 08 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 01 65 02 02 01 03 02 03 0F 01 16 00 00 B3 20 7E
13:55:52 Get next frame.
13:55:52 Collecting objects
13:55:52
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 01 FF 02 02 01 03 02 03 0F 01 16 28 33 7E
13:55:52 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 A5 2A D7 7E
13:55:52
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 A6 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 F2 26 7E
13:55:52
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 E8 B7 7E
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 A6 B1 E5 7E
13:55:53
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 A7 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 90 BD 7E
13:55:53 Get next frame.
13:55:53 Collecting objects
13:55:53
7E A0 37 21 03 1C 02 97 06 01 00 09 08 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 F9 17 7E
13:55:53 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 A7 38 F4 7E
13:55:54
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 A8 00 82 02 1F 00 09 06 01 00 09 08 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 04 6C 02 02 01 03 02 03 0F 01 03 96 7E
13:55:54 Get next frame.
13:55:54 Collecting objects
13:55:54
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 04 6D 02 02 01 03 02 03 1C 89 7E
13:55:54 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 A8 CF 0C 7E
13:55:54
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 A9 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 08 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 E6 13 7E
13:55:54
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 1D 5C 7E
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 A9 46 1D 7E
13:55:55
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 AA 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 9B 8A 7E
13:55:55 Get next frame.
13:55:55 Collecting objects
13:55:55
7E A0 37 21 03 78 20 B2 11 00 09 06 01 00 09 09 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 EF DB 7E
13:55:55 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 AA DD 2F 7E
13:55:56
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 AB 00 82 02 1F 00 03 11 00 09 06 01 00 09 09 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 02 67 02 02 01 03 02 BB 0D 7E
13:55:56 Get next frame.
13:55:56 Collecting objects
13:55:56
7E A0 37 21 03 9C 0A 13 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 02 68 02 02 01 7D D3 7E
13:55:56 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 AB 54 3E 7E
13:55:56
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 AC 00 82 02 1F 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 CE 58 7E
13:55:56
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 F0 EA 7E
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 AC EB 4A 7E
13:55:57
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 AD 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 2A 29 7E
13:55:57 Get next frame.
13:55:57 Collecting objects
13:55:57
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 01 00 09 09 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 45 26 7E
13:55:57 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 AD 62 5B 7E
13:55:58
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 AE 00 82 02 1F 02 04 12 00 03 11 00 09 06 01 00 09 09 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 04 6F 02 02 59 CF 7E
13:55:58 Get next frame.
13:55:58 Collecting objects
13:55:58
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 04 70 9F F9 7E
13:55:58 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 AE F9 69 7E
13:55:58
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 AF 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 09 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 76 40 7E
13:55:59
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 29 C3 7E
13:55:59 Get Next Data block.
13:55:59 Collecting objects
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 AF 70 78 7E
13:55:59
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 B0 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 3C AE 7E
13:55:59 Get next frame.
13:55:59
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 09 13 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F F8 F4 7E
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 B0 06 90 7E
13:56:00
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 B1 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 02 FA C4 7E
13:56:00 Get next frame.
13:56:00 Collecting objects
13:56:00
7E A0 37 21 03 54 4E 59 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 A3 48 7E
13:56:00 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 B1 8F 81 7E
13:56:00
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 B2 00 82 02 1F 13 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 00 23 7E
13:56:01
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 28 58 7E
13:56:01 Get Next Data block.
13:56:01 Collecting objects
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 B2 14 B3 7E
13:56:01
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 B3 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 8F 22 7E
13:56:01 Get next frame.
13:56:01
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 C3 40 7E
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 B3 9D A2 7E
13:56:02
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 B4 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 13 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 E2 E9 7E
13:56:02 Get next frame.
13:56:02 Collecting objects
13:56:02
7E A0 37 21 03 B0 64 F8 09 13 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 23 28 7E
13:56:02 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 B4 22 D6 7E
13:56:03
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 B5 00 82 02 1F 01 00 09 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 1D 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 1D 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 1D 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 1D 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 1D 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 1E 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 1E 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 1E 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 1E 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 1E 04 FF 02 02 01 03 02 03 0F 01 16 00 00 C1 11 7E
13:56:03 Get next frame.
13:56:03 Collecting objects
13:56:03
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 33 00 FF 02 02 01 03 02 03 0F 01 16 D3 D5 7E
13:56:03 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 B5 AB C7 7E
13:56:03
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 B6 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 09 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 F0 89 7E
13:56:03
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 18 02 7E
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 B6 30 F5 7E
13:56:04
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 B7 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 CD 30 7E
13:56:04 Get next frame.
13:56:04 Collecting objects
13:56:04
7E A0 37 21 03 1C 02 97 06 01 00 0A 08 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 7E 8E 7E
13:56:04 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 B7 B9 E4 7E
13:56:05
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 B8 00 82 02 1F 00 09 06 01 00 0A 08 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 02 6A 02 02 01 03 02 03 0F 01 3F 8E 7E
13:56:05 Get next frame.
13:56:05 Collecting objects
13:56:05
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 02 6B 02 02 01 03 02 03 09 B8 7E
13:56:05 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 B8 4E 1C 7E
13:56:05
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 B9 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 9D 12 7E
13:56:05
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 35 C3 7E
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 B9 C7 0D 7E
13:56:06
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 BA 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 D7 7E
13:56:06 Get next frame.
13:56:06 Collecting objects
13:56:06
7E A0 37 21 03 78 20 B2 11 00 09 06 01 00 0A 08 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 D9 ED 7E
13:56:06 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 BA 5C 3F 7E
13:56:07
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 BB 00 82 02 1F 00 03 11 00 09 06 01 00 0A 08 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 08 04 FF 02 02 01 03 02 43 4E 7E
13:56:07 Get next frame.
13:56:07 Collecting objects
13:56:07
7E A0 37 21 03 9C 0A 13 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 00 66 02 02 01 D9 C3 7E
13:56:07 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 BB D5 2E 7E
13:56:07
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 BC 00 82 02 1F 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 EB F8 7E
13:56:07
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 27 CD 7E
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 BC 6A 5A 7E
13:56:08
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 BD 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 50 7A 7E
13:56:08 Get next frame.
13:56:08 Collecting objects
13:56:08
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 01 00 0A 09 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 B7 C7 7E
13:56:08 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 BD E3 4B 7E
13:56:09
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 BE 00 82 02 1F 02 04 12 00 03 11 00 09 06 01 00 0A 09 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 02 6D 02 02 3C 7B 7E
13:56:09 Get next frame.
13:56:09 Collecting objects
13:56:09
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 02 6E 7D 71 7E
13:56:09 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 BE 78 79 7E
13:56:09
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 BF 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 F2 B8 7E
13:56:09
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 DC AA 7E
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 BF F1 68 7E
13:56:10
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 C0 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 F4 A3 7E
13:56:10 Get next frame.
13:56:10 Collecting objects
13:56:10
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 76 9F 7E
13:56:10 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 C0 81 E3 7E
13:56:11
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 C1 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 09 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 00 8E AB 7E
13:56:11 Get next frame.
13:56:11 Collecting objects
7E A0 07 03 21 51 11 E4 7E
13:56:11
7E A0 37 21 03 54 4E 59 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A E5 6C 7E
13:56:11 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 C1 08 F2 7E
13:56:11
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 C2 00 82 02 1F 13 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 49 7E 7E
7E A0 07 03 21 91 1D 22 7E
13:56:12
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 5B 0F 7E
13:56:12 Get Next Data block.
13:56:12 Collecting objects
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 C2 93 C0 7E
13:56:12
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 C3 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 07 97 7E
13:56:12 Get next frame.
7E A0 07 03 21 D1 19 60 7E
13:56:12
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 D6 EA 7E
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 C3 1A D1 7E
13:56:13
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 C4 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 25 9D 7E
13:56:13 Get next frame.
13:56:13 Collecting objects
7E A0 07 03 21 11 15 A6 7E
13:56:13
7E A0 37 21 03 B0 64 F8 0A 13 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 31 98 7E
13:56:13 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 C4 A5 A5 7E
13:56:13
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 C5 00 82 02 1F 01 00 0A 13 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 03 6E 02 02 01 03 02 03 0F 01 16 00 00 D7 E2 7E
13:56:14
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 03 6F 02 02 01 03 02 03 0F 01 16 83 7E 7E
13:56:14 Get Next Data block.
13:56:14 Collecting objects
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 C5 2C B4 7E
13:56:14
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 C6 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 0E 31 7E
13:56:14 Get next frame.
13:56:14
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 89 5B 7E
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 C6 B7 86 7E
13:56:15
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 C7 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 13 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 1D 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 1D 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 1D 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 1D 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 EA 76 7E
13:56:15 Get next frame.
13:56:15 Collecting objects
13:56:15
7E A0 37 21 03 1C 02 97 06 01 00 0A 1D 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 1A ED 7E
13:56:15 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 C7 3E 97 7E
13:56:16
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 C8 00 82 02 1F 00 09 06 01 00 0A 1E 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 1E 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 1E 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 1E 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 1E 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0A 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0B 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0B 1F 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0B 23 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0B 2B 00 FF 02 02 01 03 02 03 0F 01 84 56 7E
13:56:16 Get next frame.
13:56:16 Collecting objects
13:56:16
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0B 2C 00 FF 02 02 01 03 02 03 3F 0B 7E
13:56:16 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 C8 C9 6F 7E
13:56:16
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 C9 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0B 2D 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0B 81 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0B 81 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0C 1F 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0C 20 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0C 23 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0C 24 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0C 27 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0C 2A 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0C 2B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 CA FF 7E
13:56:16
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0C 2C 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 6E 2C 7E
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 C9 40 7E 7E
13:56:17
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 CA 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0C 2D 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0C 81 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0C 81 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0C 82 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0D 00 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0D 00 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0D 00 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0D 00 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0D 00 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0D 00 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 49 30 7E
13:56:17 Get next frame.
13:56:17 Collecting objects
13:56:17
7E A0 37 21 03 78 20 B2 11 00 09 06 01 00 0D 00 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 72 07 7E
13:56:17 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 CA DB 4C 7E
13:56:18
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 CB 00 82 02 1F 00 03 11 00 09 06 01 00 0D 00 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0D 00 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0D 00 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0D 00 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0D 00 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0D 00 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0D 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0D 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0D 1F 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0D 2B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0D 33 00 FF 02 02 01 03 02 E5 F9 7E
13:56:18 Get next frame.
13:56:18 Collecting objects
13:56:18
7E A0 37 21 03 9C 0A 13 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0D 35 00 FF 02 02 01 49 E5 7E
13:56:18 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 CB 52 5D 7E
13:56:18
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 CC 00 82 02 1F 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0E 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 DB EA 7E
13:56:18
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 86 E1 7E
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 CC ED 29 7E
13:56:19
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 CD 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 A2 94 7E
13:56:19 Get next frame.
13:56:19 Collecting objects
13:56:19
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 01 00 0F 08 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 9E DA 7E
13:56:19 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 CD 64 38 7E
13:56:20
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 CE 00 82 02 1F 02 04 12 00 03 11 00 09 06 01 00 0F 08 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 02 6A 02 02 06 90 7E
13:56:20 Get next frame.
13:56:20 Collecting objects
13:56:20
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 02 6B 5B 12 7E
13:56:20 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 CE FF 0A 7E
13:56:20
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 CF 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 6F A6 7E
13:56:20
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 06 3A 7E
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 CF 76 1B 7E
13:56:21
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 D0 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 98 26 7E
13:56:21 Get next frame.
13:56:21 Collecting objects
13:56:21
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F BC 11 7E
13:56:21 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 D0 00 F3 7E
13:56:22
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 D1 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 04 C6 0B 7E
13:56:22 Get next frame.
13:56:22 Collecting objects
13:56:22
7E A0 37 21 03 54 4E 59 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F B4 A6 7E
13:56:22 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 D1 89 E2 7E
13:56:22
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 D2 00 82 02 1F 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F DE C6 7E
13:56:23
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 5B BF 7E
13:56:23 Get Next Data block.
13:56:23 Collecting objects
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 D2 12 D0 7E
13:56:23
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 D3 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 EA 86 7E
13:56:23 Get next frame.
13:56:23
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 74 DA 7E
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 D3 9B C1 7E
13:56:24
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 D4 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 99 A5 7E
13:56:24 Get next frame.
13:56:24 Collecting objects
13:56:24
7E A0 37 21 03 B0 64 F8 0F 09 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 21 E6 7E
13:56:24 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 D4 24 B5 7E
13:56:24
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 D5 00 82 02 1F 01 00 0F 09 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 03 6B 02 02 01 03 02 03 0F 01 16 00 00 2A 4D 7E
13:56:25
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 03 6C 02 02 01 03 02 03 0F 01 16 7C 04 7E
13:56:25 Get Next Data block.
13:56:25 Collecting objects
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 D5 AD A4 7E
13:56:25
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 D6 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 FA 1A 7E
13:56:25 Get next frame.
13:56:25
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 9A 82 7E
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 D6 36 96 7E
13:56:26
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 D7 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 09 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 60 96 7E
13:56:26 Get next frame.
13:56:26 Collecting objects
13:56:26
7E A0 37 21 03 1C 02 97 06 01 00 0F 13 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 3E 58 7E
13:56:26 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 D7 BF 87 7E
13:56:27
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 D8 00 82 02 1F 00 09 06 01 00 0F 13 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 01 66 02 02 01 03 02 03 0F 01 9D 33 7E
13:56:27 Get next frame.
13:56:27 Collecting objects
13:56:27
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 01 67 02 02 01 03 02 03 A1 49 7E
13:56:27 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 D8 48 7F 7E
13:56:27
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 D9 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 42 95 7E
13:56:27
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F CB 47 7E
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 D9 C1 6E 7E
13:56:28
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 DA 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 13 62 7E
13:56:28 Get next frame.
13:56:28 Collecting objects
13:56:28
7E A0 37 21 03 78 20 B2 11 00 09 06 01 00 0F 13 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 A9 E9 7E
13:56:28 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 DA 5A 5C 7E
13:56:29
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 DB 00 82 02 1F 00 03 11 00 09 06 01 00 0F 13 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 03 6E 02 02 01 03 02 18 E8 7E
13:56:29 Get next frame.
13:56:29 Collecting objects
13:56:29
7E A0 37 21 03 9C 0A 13 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 03 6F 02 02 01 6B BC 7E
13:56:29 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 DB D3 4D 7E
13:56:29
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 DC 00 82 02 1F 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 E6 D9 7E
13:56:29
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 11 BD 7E
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 DC 6C 39 7E
13:56:30
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 DD 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 13 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 1D 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 1D 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 1D 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 1D 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 14 43 7E
13:56:30 Get next frame.
13:56:30 Collecting objects
13:56:30
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 01 00 0F 1D 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 93 19 7E
13:56:30 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 DD E5 28 7E
13:56:31
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 DE 00 82 02 1F 02 04 12 00 03 11 00 09 06 01 00 0F 1E 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 1E 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 1E 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 1E 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 1E 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 26 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 26 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 0F 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 00 66 02 02 C2 5E 7E
13:56:31 Get next frame.
13:56:31 Collecting objects
13:56:31
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 00 67 DF 9A 7E
13:56:31 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 DE 7E 1A 7E
13:56:31
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 DF 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 A8 DA 7E
13:56:31
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 10 95 7E
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 DF F7 0B 7E
13:56:32
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 E0 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 F9 6A 7E
13:56:32 Get next frame.
13:56:32 Collecting objects
13:56:32
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 10 08 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 28 DD 7E
13:56:32 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 E0 83 C2 7E
13:56:33
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 E1 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 02 DF 65 7E
13:56:33 Get next frame.
13:56:33 Collecting objects
7E A0 07 03 21 51 11 E4 7E
13:56:33
7E A0 37 21 03 54 4E 59 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 59 E8 7E
13:56:33 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 E1 0A D3 7E
13:56:33
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 E2 00 82 02 1F 08 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 0A 19 7E
7E A0 07 03 21 91 1D 22 7E
13:56:33
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 28 1A 7E
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 E2 91 E1 7E
13:56:34
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 E3 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 80 0A 7E
13:56:34 Get next frame.
13:56:34 Collecting objects
7E A0 07 03 21 D1 19 60 7E
13:56:34
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 EE BE 7E
13:56:34 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 E3 18 F0 7E
13:56:35
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 E4 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 08 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 10 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 C7 A3 7E
13:56:35 Get next frame.
13:56:35 Collecting objects
7E A0 07 03 21 11 15 A6 7E
13:56:35
7E A0 37 21 03 B0 64 F8 15 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 5F 9A 7E
13:56:35 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 E4 A7 84 7E
13:56:35
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 E5 00 82 02 1F 01 00 15 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 0F 18 7E
13:56:36
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 09 00 66 02 02 01 03 02 03 0F 01 16 4A B7 7E
13:56:36 Get Next Data block.
13:56:36 Collecting objects
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 E5 2E 95 7E
13:56:36
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 E6 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 DE 7B 7E
13:56:36 Get next frame.
13:56:36
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 C7 C4 7E
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 E6 B5 A7 7E
13:56:37
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 E7 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 15 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 3C B5 7E
13:56:37 Get next frame.
13:56:37 Collecting objects
13:56:37
7E A0 37 21 03 1C 02 97 06 01 00 16 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 3B 27 7E
13:56:37 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 E7 3C B6 7E
13:56:37
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 E8 00 82 02 1F 00 09 06 01 00 16 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 09 00 69 02 02 01 03 02 03 0F 01 ED DB 7E
13:56:38
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 09 00 6A 02 02 01 03 02 03 A9 6A 7E
13:56:38 Get Next Data block.
13:56:38 Collecting objects
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 E8 CB 4E 7E
13:56:38
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 E9 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 90 29 7E
13:56:38 Get next frame.
13:56:38
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 16 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F A3 4D 7E
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 E9 42 5F 7E
13:56:39
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 EA 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 DF E9 7E
13:56:39 Get next frame.
13:56:39 Collecting objects
13:56:39
7E A0 37 21 03 78 20 B2 11 00 09 06 01 00 17 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 D4 08 7E
13:56:39 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 EA D9 6D 7E
13:56:40
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 EB 00 82 02 1F 00 03 11 00 09 06 01 00 17 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 09 00 6D 02 02 01 03 02 6A DB 7E
13:56:40 Get next frame.
13:56:40 Collecting objects
13:56:40
7E A0 37 21 03 9C 0A 13 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 09 00 6E 02 02 01 87 BD 7E
13:56:40 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 EB 50 7C 7E
13:56:40
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 EC 00 82 02 1F 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 17 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 64 DA 7E
13:56:40
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 D9 11 7E
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 EC EF 08 7E
13:56:41
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 ED 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 07 AA 7E
13:56:41 Get next frame.
13:56:41 Collecting objects
13:56:41
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 01 00 18 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 7D 84 7E
13:56:41 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 ED 66 19 7E
13:56:42
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 EE 00 82 02 1F 02 04 12 00 03 11 00 09 06 01 00 18 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 09 00 65 02 02 3E C8 7E
13:56:42 Get next frame.
13:56:42 Collecting objects
13:56:42
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 09 00 FF 1A 3D 7E
13:56:42 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 EE FD 2B 7E
13:56:42
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 EF 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 18 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 54 43 7E
13:56:42
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 F9 2D 7E
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 EF 74 3A 7E
13:56:43
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 F0 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 C5 6B 7E
13:56:43 Get next frame.
13:56:43 Collecting objects
13:56:43
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 19 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 39 48 7E
13:56:43 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 F0 02 D2 7E
13:56:44
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 F1 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 19 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 08 00 B4 37 7E
13:56:44 Get next frame.
13:56:44 Collecting objects
13:56:44
7E A0 37 21 03 54 4E 59 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 02 F3 7E
13:56:44 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 F1 8B C3 7E
13:56:44
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 F2 00 82 02 1F 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 8D 7C 7E
13:56:44
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 D0 86 7E
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 F2 10 F1 7E
13:56:45
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 F3 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1A 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 05 73 7E
13:56:45 Get next frame.
13:56:45 Collecting objects
13:56:45
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 51 B2 7E
13:56:45 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 F3 99 E0 7E
13:56:46
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 F4 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 69 A8 7E
13:56:46 Get next frame.
13:56:46 Collecting objects
13:56:46
7E A0 37 21 03 B0 64 F8 1B 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 C4 25 7E
13:56:46 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 F4 26 94 7E
13:56:46
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 F5 00 82 02 1F 01 00 1B 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 E7 B1 7E
13:56:47
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 09 00 70 02 02 01 03 02 03 0F 01 16 4C BD 7E
13:56:47 Get Next Data block.
13:56:47 Collecting objects
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 F5 AF 85 7E
13:56:47
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 F6 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1B 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 75 47 7E
13:56:47 Get next frame.
13:56:47
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 52 37 7E
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 F6 34 B7 7E
13:56:48
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 F7 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 5A E8 7E
13:56:48 Get next frame.
13:56:48 Collecting objects
13:56:48
7E A0 37 21 03 1C 02 97 06 01 00 1C 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 AA 16 7E
13:56:48 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 F7 BD A6 7E
13:56:48
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 00 F8 00 82 02 1F 00 09 06 01 00 1C 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1C 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 08 00 69 02 02 01 03 02 03 0F 01 AA FF 7E
13:56:49
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 08 00 6A 02 02 01 03 02 03 14 3A 7E
13:56:49 Get Next Data block.
13:56:49 Collecting objects
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 00 F8 4A 5E 7E
13:56:49
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 00 F9 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 D6 3A 7E
13:56:49 Get next frame.
13:56:49
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F B7 F9 7E
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 00 F9 C3 4F 7E
13:56:50
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 00 FA 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 95 3A 7E
13:56:50 Get next frame.
13:56:50 Collecting objects
13:56:50
7E A0 37 21 03 78 20 B2 11 00 09 06 01 00 1D 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 82 1B 7E
13:56:50 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 00 FA 58 7D 7E
13:56:51
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 00 FB 00 82 02 1F 00 03 11 00 09 06 01 00 1D 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1D 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 08 00 6D 02 02 01 03 02 6D CE 7E
13:56:51 Get next frame.
13:56:51 Collecting objects
13:56:51
7E A0 37 21 03 9C 0A 13 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 08 00 6E 02 02 01 95 F8 7E
13:56:51 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 00 FB D1 6C 7E
13:56:51
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 00 FC 00 82 02 1F 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 74 17 7E
13:56:51
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 4E 94 7E
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 00 FC 6E 18 7E
13:56:52
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 00 FD 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1E 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 13 9C 7E
13:56:52 Get next frame.
13:56:52 Collecting objects
13:56:52
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 01 00 1F 07 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 FD 53 7E
13:56:52 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 00 FD E7 09 7E
13:56:53
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 00 FE 00 82 02 1F 02 04 12 00 03 11 00 09 06 01 00 1F 07 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 05 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 06 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 07 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 08 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 09 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 0A FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 0B FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 0C FF 02 02 F7 25 7E
13:56:53 Get next frame.
13:56:53 Collecting objects
13:56:53
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 0D FF 58 CA 7E
13:56:53 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 00 FE 7C 3B 7E
13:56:53
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 00 FF 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 0E FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 0F FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 10 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 11 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 12 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 13 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 14 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 15 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 16 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 17 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 7C AC 7E
13:56:53
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 18 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 91 42 7E
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 00 FF F5 2A 7E
13:56:54
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 00 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 19 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 1A FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 1B FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 1C FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 1D FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 1E FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 1F FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 20 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 07 7C FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 0C 81 7E
13:56:54 Get next frame.
13:56:54 Collecting objects
13:56:54
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 1F 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 98 F6 7E
13:56:54 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 00 55 3C 7E
13:56:55
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 01 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 1F 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 05 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 06 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 07 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 08 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 09 41 CC 7E
13:56:55 Get next frame.
13:56:55 Collecting objects
7E A0 07 03 21 51 11 E4 7E
13:56:55
7E A0 37 21 03 54 4E 59 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 41 7F 7E
13:56:55 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 01 DC 2D 7E
13:56:55
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 02 00 82 02 1F 07 0A FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 0B FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 0C FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 0D FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 0E FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 0F FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 10 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 11 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 12 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 13 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 14 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F B8 77 7E
7E A0 07 03 21 91 1D 22 7E
13:56:55
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 15 FF 02 02 01 03 02 03 0F 01 16 00 00 02 86 1E 7E
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 02 47 1F 7E
13:56:56
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 03 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 16 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 17 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 18 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 19 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 1A FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 1B FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 1C FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 1D FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 1E FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 1F FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 F0 57 7E
13:56:56 Get next frame.
13:56:56 Collecting objects
7E A0 07 03 21 D1 19 60 7E
13:56:56
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 20 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 51 AC 7E
13:56:56 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 03 CE 0E 7E
13:56:57
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 04 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 07 7C FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 22 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 26 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 20 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 21 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 21 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 21 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 21 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 E3 BF 7E
13:56:57 Get next frame.
13:56:57 Collecting objects
7E A0 07 03 21 11 15 A6 7E
13:56:57
7E A0 37 21 03 B0 64 F8 23 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 1A B2 7E
13:56:57 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 04 71 7A 7E
13:56:57
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 05 00 82 02 1F 01 00 23 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 4F 59 7E
13:56:57
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 08 00 65 02 02 01 03 02 03 0F 01 16 E8 B4 7E
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 05 F8 6B 7E
13:56:58
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 06 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 48 0A 7E
13:56:58 Get next frame.
13:56:58 Collecting objects
13:56:58
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 EA D0 7E
13:56:58 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 06 63 59 7E
13:56:59
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 07 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 23 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 24 E4 7E
13:56:59 Get next frame.
13:56:59 Collecting objects
13:56:59
7E A0 37 21 03 1C 02 97 06 01 00 24 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 BC B8 7E
13:56:59 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 07 EA 48 7E
13:56:59
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 08 00 82 02 1F 00 09 06 01 00 24 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 09 00 67 02 02 01 03 02 03 0F 01 06 CE 7E
13:57:00
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 09 00 68 02 02 01 03 02 03 BB 7B 7E
13:57:00 Get Next Data block.
13:57:00 Collecting objects
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 08 1D B0 7E
13:57:00
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 09 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 24 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 27 C1 7E
13:57:00 Get next frame.
13:57:00
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 6C A1 7E
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 09 94 A1 7E
13:57:01
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 0A 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 BC 85 7E
13:57:01 Get next frame.
13:57:01 Collecting objects
13:57:01
7E A0 37 21 03 78 20 B2 11 00 09 06 01 00 29 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 21 49 7E
13:57:01 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 0A 0F 93 7E
13:57:01
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 0B 00 82 02 1F 00 03 11 00 09 06 01 00 29 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 09 00 6E 02 02 01 03 02 9A AA 7E
13:57:02
7E A0 37 21 03 9C 0A 13 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 09 00 6F 02 02 01 57 F1 7E
13:57:02 Get Next Data block.
13:57:02 Collecting objects
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 0B 86 82 7E
13:57:02
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 0C 00 82 02 1F 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 29 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 98 E9 7E
13:57:02 Get next frame.
13:57:02
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 A4 9F 7E
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 0C 39 F6 7E
13:57:03
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 0D 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 7E 35 7E
13:57:03 Get next frame.
13:57:03 Collecting objects
13:57:03
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 01 00 2A 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 C3 A6 7E
13:57:03 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 0D B0 E7 7E
13:57:04
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 0E 00 82 02 1F 02 04 12 00 03 11 00 09 06 01 00 2A 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 09 00 FF 02 02 0A 33 7E
13:57:04 Get next frame.
13:57:04 Collecting objects
13:57:04
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 1B 00 FF B3 78 7E
13:57:04 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 0E 2B D5 7E
13:57:04
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 0F 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2A 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 21 11 7E
13:57:04
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 61 87 7E
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 0F A2 C4 7E
13:57:05
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 10 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 A6 F2 7E
13:57:05 Get next frame.
13:57:05 Collecting objects
13:57:05
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 2B 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 0C B5 7E
13:57:05 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 10 D4 2C 7E
13:57:06
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 11 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2B 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 07 00 3A C6 7E
13:57:06 Get next frame.
13:57:06 Collecting objects
13:57:06
7E A0 37 21 03 54 4E 59 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 2D B5 7E
13:57:06 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 11 5D 3D 7E
13:57:06
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 12 00 82 02 1F 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F F6 66 7E
13:57:06
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 51 26 7E
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 12 C6 0F 7E
13:57:07
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 13 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 A8 F5 7E
13:57:07 Get next frame.
13:57:07 Collecting objects
13:57:07
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 10 03 7E
13:57:07 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 13 4F 1E 7E
13:57:08
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 14 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2C 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 A9 B4 7E
13:57:08 Get next frame.
13:57:08 Collecting objects
13:57:08
7E A0 37 21 03 B0 64 F8 2D 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 D4 AC 7E
13:57:08 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 14 F0 6A 7E
13:57:08
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 15 00 82 02 1F 01 00 2D 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 EE 39 7E
13:57:08
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 09 00 69 02 02 01 03 02 03 0F 01 16 8E D8 7E
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 15 79 7B 7E
13:57:09
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 16 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2D 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 8D 5C 7E
13:57:09 Get next frame.
13:57:09 Collecting objects
13:57:09
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 B9 0F 7E
13:57:09 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 16 E2 49 7E
13:57:10
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 17 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 7C A6 7E
13:57:10 Get next frame.
13:57:10 Collecting objects
13:57:10
7E A0 37 21 03 1C 02 97 06 01 00 2E 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 6C E3 7E
13:57:10 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 17 6B 58 7E
13:57:10
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 18 00 82 02 1F 00 09 06 01 00 2E 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 09 00 70 02 02 01 03 02 03 0F 01 D3 E0 7E
13:57:11
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 09 00 65 02 02 01 03 02 03 93 64 7E
13:57:11 Get Next Data block.
13:57:11 Collecting objects
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 18 9C A0 7E
13:57:11
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 19 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2E 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 D7 EC 7E
13:57:11 Get next frame.
13:57:11
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 75 24 7E
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 19 15 B1 7E
13:57:12
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 1A 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 18 5B 7E
13:57:12 Get next frame.
13:57:12 Collecting objects
13:57:12
7E A0 37 21 03 78 20 B2 11 00 09 06 01 00 2F 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 B4 63 7E
13:57:12 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 1A 8E 83 7E
13:57:12
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 1B 00 82 02 1F 00 03 11 00 09 06 01 00 2F 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 2F 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 08 00 6B 02 02 01 03 02 11 25 7E
13:57:13
7E A0 37 21 03 9C 0A 13 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 08 00 6C 02 02 01 41 24 7E
13:57:13 Get Next Data block.
13:57:13 Collecting objects
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 1B 07 92 7E
13:57:13
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 1C 00 82 02 1F 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 62 56 7E
13:57:13 Get next frame.
13:57:13
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 6E E8 7E
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 1C B8 E6 7E
13:57:14
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 1D 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 30 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 13 20 7E
13:57:14 Get next frame.
13:57:14 Collecting objects
13:57:14
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 01 00 31 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 9A CB 7E
13:57:14 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 1D 31 F7 7E
13:57:15
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 1E 00 82 02 1F 02 04 12 00 03 11 00 09 06 01 00 31 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 08 00 FF 02 02 31 29 7E
13:57:15 Get next frame.
13:57:15 Collecting objects
13:57:15
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 09 00 66 62 42 7E
13:57:15 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 1E AA C5 7E
13:57:15
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 1F 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 D0 31 7E
13:57:15
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 C4 C7 7E
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 1F 23 D4 7E
13:57:16
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 20 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 31 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 AE 4C 7E
13:57:16 Get next frame.
13:57:16 Collecting objects
13:57:16
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 32 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F FD 0F 7E
13:57:16 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 20 57 1D 7E
13:57:17
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 21 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 09 00 E5 B9 7E
13:57:17 Get next frame.
13:57:17 Collecting objects
7E A0 07 03 21 51 11 E4 7E
13:57:17
7E A0 37 21 03 54 4E 59 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 48 5E 7E
13:57:17 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 21 DE 0C 7E
13:57:17
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 22 00 82 02 1F 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 8B CB 7E
7E A0 07 03 21 91 1D 22 7E
13:57:17
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 32 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 D2 8F 7E
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 22 45 3E 7E
13:57:18
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 23 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 05 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 06 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 07 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 08 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 09 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 34 1A 7E
13:57:18 Get next frame.
13:57:18 Collecting objects
7E A0 07 03 21 D1 19 60 7E
13:57:18
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 0A FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 D3 0C 7E
13:57:18 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 23 CC 2F 7E
13:57:19
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 24 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 0B FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 0C FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 0D FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 0E FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 0F FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 10 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 11 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 12 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 13 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 14 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3A A3 7E
13:57:19 Get next frame.
13:57:19 Collecting objects
7E A0 07 03 21 11 15 A6 7E
13:57:19
7E A0 37 21 03 B0 64 F8 33 07 15 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 73 D1 7E
13:57:19 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 24 73 5B 7E
13:57:19
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 25 00 82 02 1F 01 00 33 07 16 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 17 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 18 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 19 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 1A FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 1B FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 1C FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 1D FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 1E FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 1F FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 20 FF 02 02 01 03 02 03 0F 01 16 00 00 99 40 7E
13:57:19
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 07 7C FF 02 02 01 03 02 03 0F 01 16 BA 9B 7E
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 25 FA 4A 7E
13:57:20
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 26 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 33 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 05 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 06 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 13 D6 7E
13:57:20 Get next frame.
13:57:20 Collecting objects
13:57:20
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 07 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 FD 54 7E
13:57:20 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 26 61 78 7E
13:57:21
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 27 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 08 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 09 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 0A FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 0B FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 0C FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 0D FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 0E FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 0F FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 10 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 11 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 96 62 7E
13:57:21 Get next frame.
13:57:21 Collecting objects
13:57:21
7E A0 37 21 03 1C 02 97 06 01 00 34 07 12 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 C5 4E 7E
13:57:21 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 27 E8 69 7E
13:57:21
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 28 00 82 02 1F 00 09 06 01 00 34 07 13 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 14 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 15 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 16 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 17 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 18 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 19 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 1A FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 1B FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 1C FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 1D FF 02 02 01 03 02 03 0F 01 29 6D 7E
13:57:21
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 1E FF 02 02 01 03 02 03 85 ED 7E
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 28 1F 91 7E
13:57:22
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 29 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 1F FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 20 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 07 7C FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 22 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 26 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 34 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 35 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 35 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 28 30 7E
13:57:22 Get next frame.
13:57:22 Collecting objects
13:57:22
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 35 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F C7 1D 7E
13:57:22 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 29 96 80 7E
13:57:23
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 2A 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 35 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 96 2D 7E
13:57:23 Get next frame.
13:57:23 Collecting objects
13:57:23
7E A0 37 21 03 78 20 B2 11 00 09 06 01 00 37 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 DA 7D 7E
13:57:23 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 2A 0D B2 7E
13:57:23
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 2B 00 82 02 1F 00 03 11 00 09 06 01 00 37 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 09 00 6C 02 02 01 03 02 1C C7 7E
13:57:24
7E A0 37 21 03 9C 0A 13 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 09 00 6D 02 02 01 C9 FB 7E
13:57:24 Get Next Data block.
13:57:24 Collecting objects
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 2B 84 A3 7E
13:57:24
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 2C 00 82 02 1F 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 37 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 99 E4 7E
13:57:24 Get next frame.
13:57:24
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 FC C9 7E
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 2C 3B D7 7E
13:57:25
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 2D 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 D8 76 7E
13:57:25 Get next frame.
13:57:25 Collecting objects
13:57:25
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 01 00 38 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 1E 84 7E
13:57:25 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 2D B2 C6 7E
13:57:25
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 2E 00 82 02 1F 02 04 12 00 03 11 00 09 06 01 00 38 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 09 00 70 02 02 4E A6 7E
13:57:26
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 09 00 65 9A 89 7E
13:57:26 Get Next Data block.
13:57:26 Collecting objects
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 2E 29 F4 7E
13:57:26
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 2F 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 38 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 F3 F4 7E
13:57:26 Get next frame.
13:57:26
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 CC 12 7E
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 2F A0 E5 7E
13:57:27
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 30 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 17 C8 7E
13:57:27 Get next frame.
13:57:27 Collecting objects
13:57:27
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 3D 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F F8 27 7E
13:57:27 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 30 D6 0D 7E
13:57:28
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 31 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3D 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 08 00 02 25 7E
13:57:28 Get next frame.
13:57:28 Collecting objects
13:57:28
7E A0 37 21 03 54 4E 59 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 51 7B 7E
13:57:28 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 31 5F 1C 7E
13:57:28
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 32 00 82 02 1F 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 08 50 7E
13:57:28
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 A8 29 7E
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 32 C4 2E 7E
13:57:29
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 33 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 FC 7A 7E
13:57:29 Get next frame.
13:57:29 Collecting objects
13:57:29
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 27 09 7E
13:57:29 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 33 4D 3F 7E
13:57:30
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 34 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3E 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8F CB 7E
13:57:30 Get next frame.
13:57:30 Collecting objects
13:57:30
7E A0 37 21 03 B0 64 F8 3F 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 E1 0C 7E
13:57:30 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 34 F2 4B 7E
13:57:30
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 35 00 82 02 1F 01 00 3F 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 E5 72 7E
13:57:30
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 09 00 69 02 02 01 03 02 03 0F 01 16 04 89 7E
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 35 7B 5A 7E
13:57:31
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 36 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 D8 A9 7E
13:57:31 Get next frame.
13:57:31 Collecting objects
13:57:31
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 84 68 7E
13:57:31 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 36 E0 68 7E
13:57:32
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 37 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 3F 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 34 BD 7E
13:57:32 Get next frame.
13:57:32 Collecting objects
13:57:32
7E A0 37 21 03 1C 02 97 06 01 00 40 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 ED 9D 7E
13:57:32 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 37 69 79 7E
13:57:32
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 38 00 82 02 1F 00 09 06 01 00 40 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 09 00 6C 02 02 01 03 02 03 0F 01 9F E8 7E
13:57:32
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 09 00 6D 02 02 01 03 02 03 4A C6 7E
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 38 9E 81 7E
13:57:33
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 39 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 40 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 9E 8C 7E
13:57:33 Get next frame.
13:57:33 Collecting objects
13:57:33
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F A6 C1 7E
13:57:33 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 39 17 90 7E
13:57:34
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 3A 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 2E F1 7E
13:57:34 Get next frame.
13:57:34 Collecting objects
13:57:34
7E A0 37 21 03 78 20 B2 11 00 09 06 01 00 41 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 47 53 7E
13:57:34 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 3A 8C A2 7E
13:57:34
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 3B 00 82 02 1F 00 03 11 00 09 06 01 00 41 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 09 00 65 02 02 01 03 02 B6 DF 7E
13:57:35
7E A0 37 21 03 9C 0A 13 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 41 09 00 FF 02 02 01 F1 65 7E
13:57:35 Get Next Data block.
13:57:35 Collecting objects
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 3B 05 B3 7E
13:57:35
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 3C 00 82 02 1F 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 CB 98 7E
13:57:35 Get next frame.
13:57:35
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 6B 27 7E
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 3C BA C7 7E
13:57:36
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 3D 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 15 3C 7E
13:57:36 Get next frame.
13:57:36 Collecting objects
13:57:36
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 01 00 42 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 E1 8C 7E
13:57:36 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 3D 33 D6 7E
13:57:36
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 3E 00 82 02 1F 02 04 12 00 03 11 00 09 06 01 00 42 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 42 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 08 00 6C 02 02 DA B5 7E
13:57:37
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 08 00 6D 5E C5 7E
13:57:37 Get Next Data block.
13:57:37 Collecting objects
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 3E A8 E4 7E
13:57:37
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 3F 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 26 51 7E
13:57:37 Get next frame.
13:57:37
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 FE F9 7E
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 3F 21 F5 7E
13:57:38
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 40 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 43 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 DC 33 7E
13:57:38 Get next frame.
13:57:38 Collecting objects
13:57:38
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 44 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F C0 E9 7E
13:57:38 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 40 51 7E 7E
13:57:39
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 41 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 09 00 EE A3 7E
13:57:39 Get next frame.
13:57:39 Collecting objects
7E A0 07 03 21 51 11 E4 7E
13:57:39
7E A0 37 21 03 54 4E 59 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 EA 28 7E
13:57:39 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 41 D8 6F 7E
13:57:39
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 42 00 82 02 1F 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 44 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 95 1B 7E
7E A0 07 03 21 91 1D 22 7E
13:57:39
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 73 3E 7E
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 42 43 5D 7E
13:57:40
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 43 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 B4 9C 7E
13:57:40 Get next frame.
13:57:40 Collecting objects
7E A0 07 03 21 D1 19 60 7E
13:57:40
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 FB ED 7E
13:57:40 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 43 CA 4C 7E
13:57:41
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 44 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 AF 37 7E
13:57:41 Get next frame.
13:57:41 Collecting objects
7E A0 07 03 21 11 15 A6 7E
13:57:41
7E A0 37 21 03 B0 64 F8 45 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 D9 D8 7E
13:57:41 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 44 75 38 7E
13:57:41
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 45 00 82 02 1F 01 00 45 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 45 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 04 57 7E
13:57:41
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 08 00 69 02 02 01 03 02 03 0F 01 16 B5 A8 7E
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 45 FC 29 7E
13:57:42
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 46 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 BD 59 7E
13:57:42 Get next frame.
13:57:42 Collecting objects
13:57:42
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 BC 03 7E
13:57:42 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 46 67 1B 7E
13:57:43
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 47 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 11 31 7E
13:57:43 Get next frame.
13:57:43 Collecting objects
13:57:43
7E A0 37 21 03 1C 02 97 06 01 00 46 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 25 9F 7E
13:57:43 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 47 EE 0A 7E
13:57:43
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 48 00 82 02 1F 00 09 06 01 00 46 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 46 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 05 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 06 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 07 FF 02 02 01 03 02 03 0F 01 8F 14 7E
13:57:43
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 08 FF 02 02 01 03 02 03 B9 F0 7E
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 48 19 F2 7E
13:57:44
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 49 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 09 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 0A FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 0B FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 0C FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 0D FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 0E FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 0F FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 10 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 11 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 12 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 0E 8F 7E
13:57:44 Get next frame.
13:57:44 Collecting objects
13:57:44
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 13 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 4D 4C 7E
13:57:44 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 49 90 E3 7E
13:57:45
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 4A 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 14 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 15 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 16 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 17 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 18 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 19 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 1A FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 1B FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 1C FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 1D FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 A0 6B 7E
13:57:45 Get next frame.
13:57:45 Collecting objects
13:57:45
7E A0 37 21 03 78 20 B2 11 00 09 06 01 00 47 07 1E FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 D6 8D 7E
13:57:45 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 4A 0B D1 7E
13:57:45
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 4B 00 82 02 1F 00 03 11 00 09 06 01 00 47 07 1F FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 20 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 07 7C FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 47 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 04 FF 02 02 01 03 02 0F E6 7E
13:57:45
7E A0 37 21 03 9C 0A 13 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 05 FF 02 02 01 3E 3B 7E
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 4B 82 C0 7E
13:57:46
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 4C 00 82 02 1F 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 06 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 07 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 08 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 09 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 0A FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 0B FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 0C FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 0D FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 0E FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 0F FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 3B 03 7E
13:57:46 Get next frame.
13:57:46 Collecting objects
13:57:46
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 10 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 0E 17 7E
13:57:46 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 4C 3D B4 7E
13:57:47
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 4D 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 11 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 12 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 13 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 14 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 15 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 16 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 17 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 18 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 19 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 1A FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 5F 0E 7E
13:57:47 Get next frame.
13:57:47 Collecting objects
13:57:47
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 01 00 48 07 1B FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 2D DC 7E
13:57:47 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 4D B4 A5 7E
13:57:47
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 4E 00 82 02 1F 02 04 12 00 03 11 00 09 06 01 00 48 07 1C FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 1D FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 1E FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 1F FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 20 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 07 7C FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 22 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 26 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 48 35 00 FF 02 02 9D 37 7E
13:57:48
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 49 07 00 FF AC E4 7E
13:57:48 Get Next Data block.
13:57:48 Collecting objects
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 4E 2F 97 7E
13:57:48
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 4F 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 49 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 49 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 49 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 7E C4 7E
13:57:48 Get next frame.
13:57:48
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 56 09 7E
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 4F A6 86 7E
13:57:49
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 50 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 93 C9 7E
13:57:49 Get next frame.
13:57:49 Collecting objects
13:57:49
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 4B 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 26 CD 7E
13:57:49 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 50 D0 6E 7E
13:57:49
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 51 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4B 35 00 D2 5F 7E
13:57:50
7E A0 37 21 03 54 4E 59 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 2B D6 7E
13:57:50 Get Next Data block.
13:57:50 Collecting objects
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 51 59 7F 7E
13:57:50
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 52 00 82 02 1F 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F E0 C4 7E
13:57:50 Get next frame.
13:57:50
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 9B B2 7E
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 52 C2 4D 7E
13:57:51
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 53 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 AC 4B 7E
13:57:51 Get next frame.
13:57:51 Collecting objects
13:57:51
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 26 64 7E
13:57:51 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 53 4B 5C 7E
13:57:52
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 54 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 4C 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 51 07 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 51 07 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 51 07 0C FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 51 07 28 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 51 07 33 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 51 07 3E FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 EF 57 7E
13:57:52 Get next frame.
13:57:52 Collecting objects
13:57:52
7E A0 37 21 03 B0 64 F8 5A 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 A3 7E 7E
13:57:52 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 54 F4 28 7E
13:57:52
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 55 00 82 02 1F 01 00 5B 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 5B 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 5C 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 5A 3C 7E
13:57:52
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 00 6D 02 02 01 03 02 03 0F 01 16 34 A0 7E
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 55 7D 39 7E
13:57:53
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 56 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 44 0D 7E
13:57:53 Get next frame.
13:57:53 Collecting objects
13:57:53
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 40 27 7E
13:57:53 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 56 E6 0B 7E
13:57:54
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 57 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 E0 15 7E
13:57:54 Get next frame.
13:57:54 Collecting objects
13:57:54
7E A0 37 21 03 1C 02 97 06 01 00 80 08 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 09 FB 7E
13:57:54 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 57 6F 1A 7E
13:57:54
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 58 00 82 02 1F 00 09 06 01 00 80 08 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 03 67 02 02 01 03 02 03 0F 01 4C 7B 7E
13:57:54
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 03 68 02 02 01 03 02 03 49 02 7E
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 58 98 E2 7E
13:57:55
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 59 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 90 A1 7E
13:57:55 Get next frame.
13:57:55 Collecting objects
13:57:55
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F E8 44 7E
13:57:55 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 59 11 F3 7E
13:57:56
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 5A 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 08 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 35 23 7E
13:57:56 Get next frame.
13:57:56 Collecting objects
13:57:56
7E A0 37 21 03 78 20 B2 11 00 09 06 01 00 80 08 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 A5 D9 7E
13:57:56 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 5A 8A C1 7E
13:57:56
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 5B 00 82 02 1F 00 03 11 00 09 06 01 00 80 08 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 00 6F 02 02 01 03 02 7C 4C 7E
13:57:56
7E A0 37 21 03 9C 0A 13 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 00 70 02 02 01 A8 24 7E
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 5B 03 D0 7E
13:57:57
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 5C 00 82 02 1F 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 F3 04 7E
13:57:57 Get next frame.
13:57:57 Collecting objects
13:57:57
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 17 36 7E
13:57:57 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 5C BC A4 7E
13:57:58
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 5D 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 4A 96 7E
13:57:58 Get next frame.
13:57:58 Collecting objects
13:57:58
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 01 00 80 09 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 B6 76 7E
13:57:58 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 5D 35 B5 7E
13:57:58
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 5E 00 82 02 1F 02 04 12 00 03 11 00 09 06 01 00 80 09 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 03 6A 02 02 EE A5 7E
13:57:59
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 03 6B C8 CE 7E
13:57:59 Get Next Data block.
13:57:59 Collecting objects
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 5E AE 87 7E
13:57:59
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 5F 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 DB F7 7E
13:57:59 Get next frame.
13:57:59
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 77 10 7E
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 5F 27 96 7E
13:58:00
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 60 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 09 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 A8 B2 7E
13:58:00 Get next frame.
13:58:00 Collecting objects
13:58:00
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 80 13 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 3F B6 7E
13:58:00 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 60 53 5F 7E
13:58:00
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 61 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 00 45 1E 7E
7E A0 07 03 21 51 11 E4 7E
13:58:01
7E A0 37 21 03 54 4E 59 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 4B DA 7E
13:58:01 Get Next Data block.
13:58:01 Collecting objects
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 61 DA 4E 7E
13:58:01
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 62 00 82 02 1F 13 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F F9 95 7E
13:58:01 Get next frame.
7E A0 07 03 21 91 1D 22 7E
13:58:01
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 E1 64 7E
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 62 41 7C 7E
13:58:02
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 63 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 CF 85 7E
13:58:02 Get next frame.
13:58:02 Collecting objects
7E A0 07 03 21 D1 19 60 7E
13:58:02
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 52 4E 7E
13:58:02 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 63 C8 6D 7E
13:58:03
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 64 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 AB 09 7E
13:58:03 Get next frame.
13:58:03 Collecting objects
7E A0 07 03 21 11 15 A6 7E
13:58:03
7E A0 37 21 03 B0 64 F8 80 13 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 3A B8 7E
13:58:03 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 64 77 19 7E
13:58:03
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 65 00 82 02 1F 01 00 80 13 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 04 6B 02 02 01 03 02 03 0F 01 16 00 00 D0 37 7E
13:58:03
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 04 6C 02 02 01 03 02 03 0F 01 16 9C 4A 7E
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 65 FE 08 7E
13:58:04
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 66 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 13 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 1D 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 1D 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 1D 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 48 C4 7E
13:58:04 Get next frame.
13:58:04 Collecting objects
13:58:04
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 1D 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 A3 D1 7E
13:58:04 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 66 65 3A 7E
13:58:05
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 67 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 1D 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 1E 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 1E 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 1E 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 1E 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 1E 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 23 00 01 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 80 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 37 D4 7E
13:58:05 Get next frame.
13:58:05 Collecting objects
13:58:05
7E A0 37 21 03 1C 02 97 06 01 00 81 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 04 FA 7E
13:58:05 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 67 EC 2B 7E
13:58:05
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 68 00 82 02 1F 00 09 06 01 00 81 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 00 65 02 02 01 03 02 03 0F 01 68 EC 7E
13:58:05
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 00 FF 02 02 01 03 02 03 72 50 7E
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 68 1B D3 7E
13:58:06
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 69 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 28 F9 7E
13:58:06 Get next frame.
13:58:06 Collecting objects
13:58:06
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F DB D4 7E
13:58:06 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 69 92 C2 7E
13:58:07
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 6A 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 32 0F 7E
13:58:07 Get next frame.
13:58:07 Collecting objects
13:58:07
7E A0 37 21 03 78 20 B2 11 00 09 06 01 00 81 08 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 41 0D 7E
13:58:07 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 6A 09 F0 7E
13:58:07
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 6B 00 82 02 1F 00 03 11 00 09 06 01 00 81 08 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 03 6C 02 02 01 03 02 0A F7 7E
13:58:07
7E A0 37 21 03 9C 0A 13 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 03 6D 02 02 01 B4 EA 7E
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 6B 80 E1 7E
13:58:08
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 6C 00 82 02 1F 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 1C 8F 7E
13:58:08 Get next frame.
13:58:08 Collecting objects
13:58:08
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 54 DC 7E
13:58:08 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 6C 3F 95 7E
13:58:09
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 6D 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 08 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 CE 16 7E
13:58:09 Get next frame.
13:58:09 Collecting objects
13:58:09
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 01 00 81 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 23 C8 7E
13:58:09 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 6D B6 84 7E
13:58:09
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 6E 00 82 02 1F 02 04 12 00 03 11 00 09 06 01 00 81 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 01 67 02 02 E4 D5 7E
13:58:09
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 01 68 58 D3 7E
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 6E 2D B6 7E
13:58:10
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 6F 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 F4 99 7E
13:58:10 Get next frame.
13:58:10 Collecting objects
13:58:10
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 9B 01 7E
13:58:10 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 6F A4 A7 7E
13:58:11
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 70 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 02 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 02 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 3A 17 7E
13:58:11 Get next frame.
13:58:11 Collecting objects
13:58:11
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 81 09 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F D7 3E 7E
13:58:11 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 70 D2 4F 7E
13:58:11
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 71 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 03 27 4F 7E
13:58:12
7E A0 37 21 03 54 4E 59 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 3F E2 7E
13:58:12 Get Next Data block.
13:58:12 Collecting objects
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 71 5B 5E 7E
13:58:12
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 72 00 82 02 1F 09 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 0E FE 7E
13:58:12 Get next frame.
13:58:12
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 FF 27 7E
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 72 C0 6C 7E
13:58:13
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 73 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 04 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 04 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 09 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 A4 B8 7E
13:58:13 Get next frame.
13:58:13 Collecting objects
13:58:13
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 26 2B 7E
13:58:13 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 73 49 7D 7E
13:58:13
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 74 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 01 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 01 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 01 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 01 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 A6 DB 7E
13:58:14
7E A0 37 21 03 B0 64 F8 81 13 01 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 8E 38 7E
13:58:14 Get Next Data block.
13:58:14 Collecting objects
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 74 F6 09 7E
13:58:14
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 75 00 82 02 1F 01 00 81 13 01 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 01 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 01 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 01 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 01 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 01 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 01 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 02 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 02 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 02 68 02 02 01 03 02 03 0F 01 16 00 00 CA AA 7E
13:58:14 Get next frame.
13:58:14
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 02 69 02 02 01 03 02 03 0F 01 16 FD 26 7E
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 75 7F 18 7E
13:58:15
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 76 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 02 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 02 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 02 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 02 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 02 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 02 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 02 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 02 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 03 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 2B 5C 7E
13:58:15 Get next frame.
13:58:15 Collecting objects
13:58:15
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 03 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 B4 31 7E
13:58:15 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 76 E4 2A 7E
13:58:16
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 77 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 03 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 03 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 03 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 03 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 03 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 03 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 03 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 03 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 03 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 03 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 66 1C 7E
13:58:16 Get next frame.
13:58:16 Collecting objects
13:58:16
7E A0 37 21 03 1C 02 97 06 01 00 81 13 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 EB 40 7E
13:58:16 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 77 6D 3B 7E
13:58:16
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 78 00 82 02 1F 00 09 06 01 00 81 13 04 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 04 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 04 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 04 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 04 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 04 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 04 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 04 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 04 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 04 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 04 70 02 02 01 03 02 03 0F 01 F9 66 7E
13:58:16
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 04 65 02 02 01 03 02 03 76 CA 7E
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 78 9A C3 7E
13:58:17
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 79 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 13 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 1D 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 1D 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 1D 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 1D 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 1D 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 1E 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 1E 01 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 1E 02 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 23 78 7E
13:58:17 Get next frame.
13:58:17 Collecting objects
13:58:17
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 1E 03 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 6F BF 7E
13:58:17 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 79 13 D2 7E
13:58:18
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 7A 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 1E 04 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 81 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 EE 8D 7E
13:58:18 Get next frame.
13:58:18 Collecting objects
13:58:18
7E A0 37 21 03 78 20 B2 11 00 09 06 01 00 8A 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 F1 4F 7E
13:58:18 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 7A 88 E0 7E
13:58:18
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 7B 00 82 02 1F 00 03 11 00 09 06 01 00 8A 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 09 00 6A 02 02 01 03 02 BF 99 7E
13:58:18
7E A0 37 21 03 9C 0A 13 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 09 00 6B 02 02 01 4B CE 7E
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 7B 01 F1 7E
13:58:19
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 7C 00 82 02 1F 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8A 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 B4 A1 7E
13:58:19 Get next frame.
13:58:19 Collecting objects
13:58:19
7E A0 37 21 03 B0 64 F8 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 28 6F 7E
13:58:19 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 7C BE 85 7E
13:58:20
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 7D 00 82 02 1F 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 F4 72 7E
13:58:20 Get next frame.
13:58:20 Collecting objects
13:58:20
7E A0 37 21 03 D4 46 DD 12 00 03 11 00 09 06 01 00 8B 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 FC 18 7E
13:58:20 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 7D 37 94 7E
13:58:20
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 7E 00 82 02 1F 02 04 12 00 03 11 00 09 06 01 00 8B 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 09 00 6E 02 02 CC 7B 7E
13:58:20
7E A0 37 21 03 F8 28 36 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 09 00 6F 91 62 7E
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 7E AC A6 7E
13:58:21
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 7F 00 82 02 1F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 8B 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 AD 0C 7E
13:58:21 Get next frame.
13:58:21 Collecting objects
13:58:21
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 A3 89 7E
13:58:21 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 7F 25 B7 7E
13:58:22
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 80 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 52 0C 7E
13:58:22 Get next frame.
13:58:22 Collecting objects
13:58:22
7E A0 37 21 03 30 6C 7C 00 02 04 12 00 03 11 00 09 06 01 00 94 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 57 79 7E
13:58:22 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 80 5D B8 7E
13:58:22
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 81 00 82 02 1F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 09 00 1F C0 7E
7E A0 07 03 21 51 11 E4 7E
13:58:23
7E A0 37 21 03 54 4E 59 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 EE 8C 7E
13:58:23 Get Next Data block.
13:58:23 Collecting objects
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 81 D4 A9 7E
13:58:23
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 82 00 82 02 1F 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 94 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 67 D5 7E
13:58:23 Get next frame.
7E A0 07 03 21 91 1D 22 7E
13:58:23
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 71 1B 7E
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 82 4F 9B 7E
13:58:24
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 83 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 B0 54 7E
13:58:24 Get next frame.
13:58:24 Collecting objects
7E A0 07 03 21 D1 19 60 7E
13:58:24
7E A0 37 21 03 9C 0A 13 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 4C 3F 7E
13:58:24 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 83 C6 8A 7E
13:58:24
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 84 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 95 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 5D EF 7E
7E A0 07 03 21 11 15 A6 7E
13:58:25
7E A0 37 21 03 B0 64 F8 9E 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 8E 07 7E
13:58:25 Get Next Data block.
13:58:25 Collecting objects
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 84 79 FE 7E
13:58:25
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 85 00 82 02 1F 01 00 9E 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 3E CB 7E
13:58:25 Get next frame.
13:58:25
7E A0 37 21 03 D4 46 DD 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 08 00 65 02 02 01 03 02 03 0F 01 16 4B A3 7E
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 85 F0 EF 7E
13:58:26
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 86 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 09 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 09 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 56 04 7E
13:58:26 Get next frame.
13:58:26 Collecting objects
13:58:26
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 68 DC 7E
13:58:26 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 86 6B DD 7E
13:58:27
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 87 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9E 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 07 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 08 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 08 00 67 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 08 00 68 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 31 12 7E
13:58:27 Get next frame.
13:58:27 Collecting objects
13:58:27
7E A0 37 21 03 1C 02 97 06 01 00 9F 08 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 CE 63 7E
13:58:27 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 87 E2 CC 7E
13:58:27
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 88 00 82 02 1F 00 09 06 01 00 9F 08 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 08 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 08 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 08 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 08 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 08 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 08 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 08 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 08 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 09 00 66 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 09 00 67 02 02 01 03 02 03 0F 01 E0 FD 7E
13:58:27
7E A0 37 21 03 30 6C 7C 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 09 00 68 02 02 01 03 02 03 EA BA 7E
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 88 15 34 7E
13:58:28
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 89 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 09 00 69 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 09 00 6A 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 09 00 6B 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 09 00 6C 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 09 00 6D 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 09 00 6E 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 09 00 6F 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 09 00 70 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 09 00 65 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 09 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 36 06 7E
13:58:28 Get next frame.
13:58:28 Collecting objects
13:58:28
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 1B 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 12 6E 7E
13:58:28 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 89 9C 25 7E
13:58:29
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 8A 00 82 02 1F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 33 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 03 11 00 09 06 01 00 9F 35 00 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 01 18 02 01 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 01 18 02 02 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 01 18 02 03 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 01 18 02 04 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 01 18 02 05 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 01 18 02 06 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 01 18 02 07 FF 02 02 0C 9D 7E
13:58:29 Get next frame.
13:58:29 Collecting objects
13:58:29
7E A0 37 21 03 78 20 B2 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 38 DE 7E
13:58:29 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 8A 07 17 7E
13:58:29
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 8B 00 82 02 1F 04 12 00 04 11 00 09 06 00 02 18 02 01 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 02 18 02 02 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 02 18 02 03 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 02 18 02 04 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 02 18 02 05 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 02 18 02 06 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 02 18 02 07 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 03 18 02 01 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 83 18 7E
13:58:29
7E A0 37 21 03 9C 0A 13 12 00 04 11 00 09 06 00 03 18 02 02 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 43 A1 7E
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 8B 8E 06 7E
13:58:30
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 8C 00 82 02 1F 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 03 18 02 03 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 03 18 02 04 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 03 18 02 05 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 03 18 02 06 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 03 18 02 07 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 04 18 02 01 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 04 18 02 02 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 04 18 02 03 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 CC 11 7E
13:58:30 Get next frame.
13:58:30 Collecting objects
13:58:30
7E A0 37 21 03 B0 64 F8 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 04 18 02 04 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 25 52 7E
13:58:30 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 8C 31 72 7E
13:58:31
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 8D 00 82 02 1F 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 04 18 02 05 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 04 18 02 06 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 00 04 18 02 07 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 00 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 00 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 00 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 00 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 00 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 6B 9D 7E
13:58:31 Get next frame.
13:58:31 Collecting objects
13:58:31
7E A0 37 21 03 D4 46 DD 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 00 6B 02 02 01 9E 3C 7E
13:58:31 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 8D B8 63 7E
13:58:31
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 8E 00 82 02 1F 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 00 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 00 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 00 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 00 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 00 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 00 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 00 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 01 66 02 02 01 05 99 AA 7E
13:58:31
7E A0 37 21 03 F8 28 36 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 0D 44 7E
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 8E 23 51 7E
13:58:32
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 8F 00 82 02 1F 00 04 11 00 09 06 01 00 01 06 01 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 01 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 01 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 01 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 01 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 01 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 01 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 01 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 38 EC 7E
13:58:32 Get next frame.
13:58:32 Collecting objects
13:58:32
7E A0 37 21 03 1C 02 97 04 11 00 09 06 01 00 01 06 01 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F E9 05 7E
13:58:32 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 8F AA 40 7E
13:58:33
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 90 00 82 02 1F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 01 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 01 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 01 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 02 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 02 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 02 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 02 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 02 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 EA 7D 7E
13:58:33 Get next frame.
13:58:33 Collecting objects
13:58:33
7E A0 37 21 03 30 6C 7C 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 02 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 5B 73 7E
13:58:33 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 90 DC A8 7E
13:58:33
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 91 00 82 02 1F 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 02 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 02 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 02 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 02 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 02 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 02 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 02 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 03 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 11 5E 7E
13:58:33
7E A0 37 21 03 54 4E 59 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 03 67 02 02 01 05 02 8F 49 7E
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 91 55 B9 7E
13:58:34
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 92 00 82 02 1F 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 03 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 03 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 03 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 03 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 03 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 03 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 03 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 03 6F 02 02 01 05 02 03 B0 03 7E
13:58:34 Get next frame.
13:58:34 Collecting objects
13:58:34
7E A0 37 21 03 78 20 B2 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 1F 65 7E
13:58:34 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 92 CE 8B 7E
13:58:35
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 93 00 82 02 1F 11 00 09 06 01 00 01 06 03 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 03 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 03 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 04 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 04 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 04 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 04 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 04 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 5D 16 7E
13:58:35 Get next frame.
13:58:35 Collecting objects
13:58:35
7E A0 37 21 03 9C 0A 13 00 09 06 01 00 01 06 04 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 86 E6 7E
13:58:35 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 93 47 9A 7E
13:58:35
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 94 00 82 02 1F 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 04 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 04 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 04 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 04 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 04 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 04 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 01 06 04 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 00 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 B0 CC 7E
13:58:36
7E A0 37 21 03 B0 64 F8 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 00 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 CC 21 7E
13:58:36 Get Next Data block.
13:58:36 Collecting objects
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 94 F8 EE 7E
13:58:36
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 95 00 82 02 1F 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 00 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 00 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 00 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 00 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 00 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 00 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 00 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 00 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 9E 7B 7E
13:58:36 Get next frame.
13:58:36
7E A0 37 21 03 D4 46 DD 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 00 70 02 02 01 05 02 03 0F 36 40 7E
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 95 71 FF 7E
13:58:37
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 96 00 82 02 1F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 00 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 00 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 01 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 01 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 01 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 01 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 01 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 01 6B 02 02 01 05 02 03 0F 01 33 4E 7E
13:58:37 Get next frame.
13:58:37 Collecting objects
13:58:37
7E A0 37 21 03 F8 28 36 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 D7 3F 7E
13:58:37 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 96 EA CD 7E
13:58:37
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 97 00 82 02 1F 09 06 01 00 02 06 01 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 01 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 01 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 01 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 01 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 01 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 01 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 02 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 67 5D 7E
13:58:38
7E A0 37 21 03 1C 02 97 06 01 00 02 06 02 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 80 C8 7E
13:58:38 Get Next Data block.
13:58:38 Collecting objects
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 97 63 DC 7E
13:58:38
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 98 00 82 02 1F 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 02 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 02 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 02 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 02 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 02 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 02 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 02 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 02 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 CA 2B 7E
13:58:38 Get next frame.
13:58:38
7E A0 37 21 03 30 6C 7C 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 02 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 49 5A 7E
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 98 94 24 7E
13:58:39
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 99 00 82 02 1F 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 02 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 02 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 03 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 03 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 03 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 03 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 03 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 03 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 8E 4F 7E
13:58:39 Get next frame.
13:58:39 Collecting objects
13:58:39
7E A0 37 21 03 54 4E 59 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 03 6C 02 02 01 05 02 03 0F 01 16 1B 3F 7E
13:58:39 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 99 1D 35 7E
13:58:40
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 9A 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 03 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 03 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 03 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 03 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 03 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 03 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 04 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 04 67 02 02 01 05 02 03 0F 01 16 00 B5 34 7E
13:58:40 Get next frame.
13:58:40 Collecting objects
13:58:40
7E A0 37 21 03 78 20 B2 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 D6 3F 7E
13:58:40 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 9A 86 07 7E
13:58:40
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 9B 00 82 02 1F 01 00 02 06 04 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 04 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 04 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 04 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 04 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 04 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 04 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 04 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 8E 69 7E
13:58:40
7E A0 37 21 03 9C 0A 13 00 02 06 04 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 A9 0E 7E
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 9B 0F 16 7E
13:58:41
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 9C 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 04 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 02 06 04 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 00 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 00 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 00 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 00 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 00 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 00 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 CD 0B 7E
13:58:41 Get next frame.
13:58:41 Collecting objects
13:58:41
7E A0 37 21 03 B0 64 F8 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 00 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 B9 72 7E
13:58:41 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 9C B0 62 7E
13:58:42
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 9D 00 82 02 1F 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 00 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 00 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 00 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 00 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 00 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 00 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 01 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 01 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 E8 52 7E
13:58:42 Get next frame.
13:58:42 Collecting objects
13:58:42
7E A0 37 21 03 D4 46 DD 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 01 68 02 02 01 05 02 03 0F 01 16 00 00 28 69 7E
13:58:42 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 9D 39 73 7E
13:58:42
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 9E 00 82 02 1F 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 01 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 01 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 01 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 01 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 01 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 01 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 01 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 01 70 02 02 01 05 02 03 0F 01 16 00 00 02 5D B9 7E
13:58:42
7E A0 37 21 03 F8 28 36 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 6F D0 7E
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 9E A2 41 7E
13:58:43
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 9F 00 82 02 1F 03 06 01 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 01 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 02 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 02 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 02 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 02 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 02 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 02 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 AB 1E 7E
13:58:43 Get next frame.
13:58:43 Collecting objects
13:58:43
7E A0 37 21 03 1C 02 97 06 02 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 33 49 7E
13:58:43 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 9F 2B 50 7E
13:58:44
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 A0 00 82 02 1F 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 02 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 02 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 02 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 02 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 02 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 02 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 03 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 03 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 3E DF 7E
13:58:44 Get next frame.
13:58:44 Collecting objects
13:58:44
7E A0 37 21 03 30 6C 7C 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 03 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F F9 4A 7E
13:58:44 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 A0 5F 99 7E
13:58:44
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 A1 00 82 02 1F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 03 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 03 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 03 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 03 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 03 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 03 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 03 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 03 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 81 90 7E
7E A0 07 03 21 51 11 E4 7E
13:58:44
7E A0 37 21 03 54 4E 59 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 03 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 54 6D 7E
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 A1 D6 88 7E
13:58:45
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 A2 00 82 02 1F 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 03 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 04 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 04 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 04 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 04 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 04 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 04 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 04 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 2C 69 7E
13:58:45 Get next frame.
13:58:45 Collecting objects
7E A0 07 03 21 91 1D 22 7E
13:58:45
7E A0 37 21 03 78 20 B2 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 53 8A 7E
13:58:45 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 A2 4D BA 7E
13:58:46
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 A3 00 82 02 1F 04 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 04 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 04 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 04 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 04 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 03 06 04 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 00 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 00 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 00 85 59 7E
13:58:46 Get next frame.
13:58:46 Collecting objects
7E A0 07 03 21 D1 19 60 7E
13:58:46
7E A0 37 21 03 9C 0A 13 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 D1 50 7E
13:58:46 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 A3 C4 AB 7E
13:58:46
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 A4 00 82 02 1F 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 00 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 00 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 00 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 00 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 00 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 00 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 00 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 00 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 67 20 7E
7E A0 07 03 21 11 15 A6 7E
13:58:47
7E A0 37 21 03 B0 64 F8 00 02 04 12 00 04 11 00 09 06 01 00 04 06 00 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 72 97 7E
13:58:47 Get Next Data block.
13:58:47 Collecting objects
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 A4 7B DF 7E
13:58:47
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 A5 00 82 02 1F 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 00 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 01 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 01 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 01 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 01 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 01 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 01 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 01 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 1E 39 7E
13:58:47 Get next frame.
13:58:47
7E A0 37 21 03 D4 46 DD 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 01 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 07 6A 7E
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 A5 F2 CE 7E
13:58:48
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 A6 00 82 02 1F 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 01 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 01 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 01 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 01 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 01 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 02 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 02 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 02 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 1F 6C 7E
13:58:48 Get next frame.
13:58:48 Collecting objects
13:58:48
7E A0 37 21 03 F8 28 36 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 02 69 4B A8 7E
13:58:48 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 A6 69 FC 7E
13:58:48
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 A7 00 82 02 1F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 02 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 02 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 02 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 02 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 02 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 02 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 02 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 02 65 02 74 E7 7E
13:58:49
7E A0 37 21 03 1C 02 97 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 87 85 7E
13:58:49 Get Next Data block.
13:58:49 Collecting objects
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 A7 E0 ED 7E
13:58:49
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 A8 00 82 02 1F 02 04 12 00 04 11 00 09 06 01 00 04 06 02 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 03 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 03 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 03 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 03 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 03 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 03 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 03 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 AD 8C 7E
13:58:49 Get next frame.
13:58:49
7E A0 37 21 03 30 6C 7C 04 12 00 04 11 00 09 06 01 00 04 06 03 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 37 C9 7E
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 A8 17 15 7E
13:58:50
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 A9 00 82 02 1F 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 03 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 03 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 03 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 03 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 03 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 04 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 04 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 04 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 32 A2 7E
13:58:50 Get next frame.
13:58:50 Collecting objects
13:58:50
7E A0 37 21 03 54 4E 59 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 04 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 DD 7E 7E
13:58:50 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 A9 9E 04 7E
13:58:51
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 AA 00 82 02 1F 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 04 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 04 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 04 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 04 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 04 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 04 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 04 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 04 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 96 63 7E
13:58:51 Get next frame.
13:58:51 Collecting objects
13:58:51
7E A0 37 21 03 78 20 B2 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 04 06 04 FF 02 02 42 89 7E
13:58:51 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 AA 05 36 7E
13:58:51
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 AB 00 82 02 1F 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 00 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 00 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 00 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 00 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 00 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 00 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 00 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 00 6D 02 02 01 98 31 7E
13:58:51
7E A0 37 21 03 9C 0A 13 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 E8 FD 7E
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 AB 8C 27 7E
13:58:52
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 AC 00 82 02 1F 12 00 04 11 00 09 06 01 00 0F 06 00 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 00 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 00 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 00 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 00 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 01 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 01 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 01 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 2F AC 7E
13:58:52 Get next frame.
13:58:52 Collecting objects
13:58:52
7E A0 37 21 03 B0 64 F8 00 04 11 00 09 06 01 00 0F 06 01 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 5A 11 7E
13:58:52 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 AC 33 53 7E
13:58:53
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 AD 00 82 02 1F 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 01 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 01 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 01 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 01 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 01 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 01 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 01 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 01 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F BC 4D 7E
13:58:53 Get next frame.
13:58:53 Collecting objects
13:58:53
7E A0 37 21 03 D4 46 DD 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 01 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 E8 36 7E
13:58:53 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 AD BA 42 7E
13:58:53
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 AE 00 82 02 1F 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 02 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 02 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 02 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 02 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 02 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 02 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 02 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 02 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 9D 7E
13:58:53
7E A0 37 21 03 F8 28 36 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 02 6E 02 02 01 05 CE 3F 7E
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 AE 21 70 7E
13:58:54
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 AF 00 82 02 1F 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 02 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 02 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 02 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 02 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 03 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 03 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 03 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 03 69 02 02 01 05 02 95 42 7E
13:58:54 Get next frame.
13:58:54 Collecting objects
13:58:54
7E A0 37 21 03 1C 02 97 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 B9 D6 7E
13:58:54 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 AF A8 61 7E
13:58:55
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 B0 00 82 02 1F 04 11 00 09 06 01 00 0F 06 03 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 03 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 03 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 03 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 03 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 03 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 03 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 03 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 70 02 7E
13:58:55 Get next frame.
13:58:55 Collecting objects
13:58:55
7E A0 37 21 03 30 6C 7C 11 00 09 06 01 00 0F 06 03 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 54 10 7E
13:58:55 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 B0 DE 89 7E
13:58:55
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 B1 00 82 02 1F 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 04 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 04 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 04 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 04 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 04 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 04 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 04 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 04 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 75 C5 7E
13:58:55
7E A0 37 21 03 54 4E 59 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 04 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 8A 62 7E
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 B1 57 98 7E
13:58:56
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 B2 00 82 02 1F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 04 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 04 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 04 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 04 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 00 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 00 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 00 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 00 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 1A B4 7E
13:58:56 Get next frame.
13:58:56 Collecting objects
13:58:56
7E A0 37 21 03 78 20 B2 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 00 6A 02 02 01 05 02 03 C4 6F 7E
13:58:56 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 B2 CC AA 7E
13:58:57
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 B3 00 82 02 1F 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 00 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 00 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 00 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 00 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 00 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 00 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 00 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 00 FF 02 02 01 05 02 03 0F 3F 02 7E
13:58:57 Get next frame.
13:58:57 Collecting objects
13:58:57
7E A0 37 21 03 9C 0A 13 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 B8 CD 7E
13:58:57 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 B3 45 BB 7E
13:58:57
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 B4 00 82 02 1F 00 09 06 01 00 80 06 01 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 01 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 01 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 01 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 01 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 01 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 01 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 01 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 5D 5D 7E
13:58:57
7E A0 37 21 03 B0 64 F8 09 06 01 00 80 06 01 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 E4 D7 7E
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 B4 FA CF 7E
13:58:58
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 B5 00 82 02 1F 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 01 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 01 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 01 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 01 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 02 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 02 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 02 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 02 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 5B 7A 7E
13:58:58 Get next frame.
13:58:58 Collecting objects
13:58:58
7E A0 37 21 03 D4 46 DD 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 02 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 19 47 7E
13:58:58 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 B5 73 DE 7E
13:58:59
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 B6 00 82 02 1F 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 02 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 02 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 02 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 02 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 02 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 02 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 02 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 02 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 8C 24 7E
13:58:59 Get next frame.
13:58:59 Collecting objects
13:58:59
7E A0 37 21 03 F8 28 36 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 03 66 02 02 01 05 02 03 0F 01 83 C6 7E
13:58:59 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 B6 E8 EC 7E
13:58:59
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 B7 00 82 02 1F 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 03 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 03 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 03 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 03 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 03 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 03 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 03 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 03 6E 02 02 01 05 02 03 0F 01 16 C4 0E 7E
13:59:00
7E A0 37 21 03 1C 02 97 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 D8 43 7E
13:59:00 Get Next Data block.
13:59:00 Collecting objects
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 B7 61 FD 7E
13:59:00
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 B8 00 82 02 1F 06 01 00 80 06 03 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 03 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 03 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 03 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 04 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 04 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 04 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 04 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 EF 8E 7E
13:59:00 Get next frame.
13:59:00
7E A0 37 21 03 30 6C 7C 01 00 80 06 04 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 5E 49 7E
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 B8 96 05 7E
13:59:01
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 B9 00 82 02 1F 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 04 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 04 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 04 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 04 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 04 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 04 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 04 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 80 06 04 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 48 C5 7E
13:59:01 Get next frame.
13:59:01 Collecting objects
13:59:01
7E A0 37 21 03 54 4E 59 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 00 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 95 13 7E
13:59:01 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 B9 1F 14 7E
13:59:01
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 BA 00 82 02 1F 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 00 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 00 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 00 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 00 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 00 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 00 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 00 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 00 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 64 18 7E
13:59:02
7E A0 37 21 03 78 20 B2 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 00 6F 02 02 01 05 02 03 0F 01 16 00 C8 DF 7E
13:59:02 Get Next Data block.
13:59:02 Collecting objects
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 BA 84 26 7E
13:59:02
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 BB 00 82 02 1F 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 00 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 00 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 00 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 01 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 01 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 01 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 01 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 01 6A 02 02 01 05 02 03 0F 01 16 00 00 75 32 7E
13:59:02 Get next frame.
13:59:02
7E A0 37 21 03 9C 0A 13 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 6B A2 7E
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 BB 0D 37 7E
13:59:03
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 BC 00 82 02 1F 00 81 06 01 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 01 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 01 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 01 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 01 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 01 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 01 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 01 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 1F 5A 7E
13:59:03 Get next frame.
13:59:03 Collecting objects
13:59:03
7E A0 37 21 03 B0 64 F8 81 06 02 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 11 A0 7E
13:59:03 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 BC B2 43 7E
13:59:04
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 BD 00 82 02 1F 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 02 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 02 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 02 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 02 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 02 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 02 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 02 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 02 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 BE 35 7E
13:59:04 Get next frame.
13:59:04 Collecting objects
13:59:04
7E A0 37 21 03 D4 46 DD 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 02 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 F3 A1 7E
13:59:04 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 BD 3B 52 7E
13:59:04
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 BE 00 82 02 1F 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 02 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 02 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 02 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 03 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 03 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 03 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 03 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 03 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F E7 35 7E
13:59:04
7E A0 37 21 03 F8 28 36 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 03 6B 02 02 01 05 02 03 0F 01 16 00 00 02 95 69 7E
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 BE A0 60 7E
13:59:05
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 BF 00 82 02 1F 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 03 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 03 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 03 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 03 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 03 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 03 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 03 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 04 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 54 48 7E
13:59:05 Get next frame.
13:59:05 Collecting objects
13:59:05
7E A0 37 21 03 1C 02 97 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 07 05 7E
13:59:05 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 BF 29 71 7E
13:59:06
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 C0 00 82 02 1F 06 04 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 04 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 04 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 04 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 04 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 04 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 04 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 04 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 27 98 7E
13:59:06 Get next frame.
13:59:06 Collecting objects
13:59:06
7E A0 37 21 03 30 6C 7C 04 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 68 8D 7E
13:59:06 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 C0 59 FA 7E
13:59:06
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 C1 00 82 02 1F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 04 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 04 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 81 06 04 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 00 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 00 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 00 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 00 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 00 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 AD 8A 7E
7E A0 07 03 21 51 11 E4 7E
13:59:06
7E A0 37 21 03 54 4E 59 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 00 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 73 77 7E
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 C1 D0 EB 7E
13:59:07
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 C2 00 82 02 1F 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 00 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 00 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 00 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 00 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 00 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 00 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 00 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 01 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 5B EF 7E
13:59:07 Get next frame.
13:59:07 Collecting objects
7E A0 07 03 21 91 1D 22 7E
13:59:07
7E A0 37 21 03 78 20 B2 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 01 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F A2 60 7E
13:59:07 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 C2 4B D9 7E
13:59:08
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 C3 00 82 02 1F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 01 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 01 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 01 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 01 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 01 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 01 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 01 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 01 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 4C 1D 7E
13:59:08 Get next frame.
13:59:08 Collecting objects
7E A0 07 03 21 D1 19 60 7E
13:59:08
7E A0 37 21 03 9C 0A 13 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 01 35 2A 7E
13:59:08 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 C3 C2 C8 7E
13:59:08
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 C4 00 82 02 1F 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 01 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 01 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 02 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 02 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 02 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 02 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 02 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 02 6B 5F CD 7E
7E A0 07 03 21 11 15 A6 7E
13:59:08
7E A0 37 21 03 B0 64 F8 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 4C F7 7E
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 C4 7D BC 7E
13:59:09
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 C5 00 82 02 1F 00 02 04 12 00 04 11 00 09 06 01 00 82 06 02 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 02 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 02 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 02 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 02 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 02 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 02 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 03 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 44 36 7E
13:59:09 Get next frame.
13:59:09 Collecting objects
13:59:09
7E A0 37 21 03 D4 46 DD 02 04 12 00 04 11 00 09 06 01 00 82 06 03 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 75 FC 7E
13:59:09 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 C5 F4 AD 7E
13:59:10
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 C6 00 82 02 1F 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 03 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 03 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 03 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 03 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 03 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 03 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 03 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 03 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 4C 68 7E
13:59:10 Get next frame.
13:59:10 Collecting objects
13:59:10
7E A0 37 21 03 F8 28 36 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 03 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 0B 3E 7E
13:59:10 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 C6 6F 9F 7E
13:59:10
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 C7 00 82 02 1F 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 03 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 03 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 04 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 04 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 04 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 04 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 04 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 04 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 B7 66 7E
13:59:11
7E A0 37 21 03 1C 02 97 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 04 6C 02 A7 C6 7E
13:59:11 Get Next Data block.
13:59:11 Collecting objects
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 C7 E6 8E 7E
13:59:11
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 C8 00 82 02 1F 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 04 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 04 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 04 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 04 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 04 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 82 06 04 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 00 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 00 67 02 02 E1 88 7E
13:59:11 Get next frame.
13:59:11
7E A0 37 21 03 30 6C 7C 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 38 DE 7E
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 C8 11 76 7E
13:59:12
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 C9 00 82 02 1F 04 12 00 04 11 00 09 06 01 00 83 06 00 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 00 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 00 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 00 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 00 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 00 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 00 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 00 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 BF 60 7E
13:59:12 Get next frame.
13:59:12 Collecting objects
13:59:12
7E A0 37 21 03 54 4E 59 12 00 04 11 00 09 06 01 00 83 06 00 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 40 33 7E
13:59:12 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 C9 98 67 7E
13:59:12
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 CA 00 82 02 1F 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 00 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 00 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 01 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 01 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 01 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 01 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 01 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 01 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 04 E2 7E
13:59:13
7E A0 37 21 03 78 20 B2 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 01 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 D5 2F 7E
13:59:13 Get Next Data block.
13:59:13 Collecting objects
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 CA 03 55 7E
13:59:13
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 CB 00 82 02 1F 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 01 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 01 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 01 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 01 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 01 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 01 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 02 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 02 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 11 F5 7E
13:59:13 Get next frame.
13:59:13
7E A0 37 21 03 9C 0A 13 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 02 68 02 02 01 7D BE 7E
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 CB 8A 44 7E
13:59:14
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 CC 00 82 02 1F 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 02 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 02 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 02 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 02 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 02 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 02 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 02 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 02 70 02 02 01 05 B7 0C 7E
13:59:14 Get next frame.
13:59:14 Collecting objects
13:59:14
7E A0 37 21 03 B0 64 F8 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 0D 44 7E
13:59:14 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 CC 35 30 7E
13:59:15
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 CD 00 82 02 1F 00 04 11 00 09 06 01 00 83 06 02 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 02 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 03 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 03 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 03 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 03 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 03 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 03 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 45 3D 7E
13:59:15 Get next frame.
13:59:15 Collecting objects
13:59:15
7E A0 37 21 03 D4 46 DD 04 11 00 09 06 01 00 83 06 03 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 3E 45 7E
13:59:15 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 CD BC 21 7E
13:59:15
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 CE 00 82 02 1F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 03 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 03 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 03 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 03 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 03 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 03 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 04 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 04 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 77 5D 7E
13:59:15
7E A0 37 21 03 F8 28 36 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 04 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 76 B3 7E
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 CE 27 13 7E
13:59:16
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 CF 00 82 02 1F 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 04 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 04 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 04 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 04 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 04 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 04 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 04 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 04 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 11 1B 7E
13:59:16 Get next frame.
13:59:16 Collecting objects
13:59:16
7E A0 37 21 03 1C 02 97 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 04 65 02 02 01 05 02 EC D9 7E
13:59:16 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 CF AE 02 7E
13:59:17
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 D0 00 82 02 1F 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 83 06 04 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 00 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 00 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 00 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 00 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 00 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 00 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 00 6C 02 02 01 05 02 03 05 2B 7E
13:59:17 Get next frame.
13:59:17 Collecting objects
13:59:17
7E A0 37 21 03 30 6C 7C 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 1F 65 7E
13:59:17 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 D0 D8 EA 7E
13:59:17
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 D1 00 82 02 1F 11 00 09 06 01 00 84 06 00 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 00 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 00 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 00 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 00 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 00 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 01 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 01 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 97 04 7E
13:59:17
7E A0 37 21 03 54 4E 59 00 09 06 01 00 84 06 01 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 3C 8A 7E
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 D1 51 FB 7E
13:59:18
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 D2 00 82 02 1F 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 01 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 01 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 01 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 01 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 01 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 01 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 01 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 01 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 81 4D 7E
13:59:18 Get next frame.
13:59:18 Collecting objects
13:59:18
7E A0 37 21 03 78 20 B2 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 01 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 FC 58 7E
13:59:18 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 D2 CA C9 7E
13:59:19
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 D3 00 82 02 1F 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 01 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 02 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 02 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 02 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 02 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 02 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 02 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 02 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 19 FF 7E
13:59:19 Get next frame.
13:59:19 Collecting objects
13:59:19
7E A0 37 21 03 9C 0A 13 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 02 6D 02 02 01 05 02 03 0F 05 5D 7E
13:59:19 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 D3 43 D8 7E
13:59:19
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 D4 00 82 02 1F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 02 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 02 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 02 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 02 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 02 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 03 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 03 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 03 68 02 02 01 05 02 03 0F 01 E5 E3 7E
13:59:19
7E A0 37 21 03 B0 64 F8 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 D7 3F 7E
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 D4 FC AC 7E
13:59:20
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 D5 00 82 02 1F 09 06 01 00 84 06 03 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 03 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 03 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 03 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 03 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 03 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 03 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 03 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 E0 B4 7E
13:59:20 Get next frame.
13:59:20 Collecting objects
13:59:20
7E A0 37 21 03 D4 46 DD 06 01 00 84 06 03 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 FC 73 7E
13:59:20 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 D5 75 BD 7E
13:59:21
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 D6 00 82 02 1F 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 03 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 04 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 04 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 04 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 04 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 04 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 04 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 04 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 E1 88 7E
13:59:21 Get next frame.
13:59:21 Collecting objects
13:59:21
7E A0 37 21 03 F8 28 36 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 04 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 36 09 7E
13:59:21 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 D6 EE 8F 7E
13:59:21
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 D7 00 82 02 1F 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 04 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 04 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 04 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 04 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 84 06 04 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 00 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 00 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 00 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 AA 05 7E
13:59:21
7E A0 37 21 03 1C 02 97 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 00 69 02 02 01 05 02 03 0F 01 16 F2 83 7E
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 D7 67 9E 7E
13:59:22
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 D8 00 82 02 1F 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 00 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 00 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 00 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 00 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 00 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 00 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 00 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 00 65 02 02 01 05 02 03 0F 01 16 00 3D 76 7E
13:59:22 Get next frame.
13:59:22 Collecting objects
13:59:22
7E A0 37 21 03 30 6C 7C 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 D6 3F 7E
13:59:22 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 D8 90 66 7E
13:59:23
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 D9 00 82 02 1F 01 00 85 06 00 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 01 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 01 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 01 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 01 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 01 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 01 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 01 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 D1 17 7E
13:59:23 Get next frame.
13:59:23 Collecting objects
13:59:23
7E A0 37 21 03 54 4E 59 00 85 06 01 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 87 EF 7E
13:59:23 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 D9 19 77 7E
13:59:23
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 DA 00 82 02 1F 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 01 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 01 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 01 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 01 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 01 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 02 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 02 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 02 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 EF A7 7E
13:59:24
7E A0 37 21 03 78 20 B2 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 02 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 57 CF 7E
13:59:24 Get Next Data block.
13:59:24 Collecting objects
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 DA 82 45 7E
13:59:24
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 DB 00 82 02 1F 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 02 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 02 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 02 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 02 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 02 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 02 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 02 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 02 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 78 3C 7E
13:59:24 Get next frame.
13:59:24
7E A0 37 21 03 9C 0A 13 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 02 FF 02 02 01 05 02 03 0F 01 16 00 00 C7 D9 7E
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 DB 0B 54 7E
13:59:25
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 DC 00 82 02 1F 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 03 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 03 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 03 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 03 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 03 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 03 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 03 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 03 6D 02 02 01 05 02 03 0F 01 16 00 00 02 24 4B 7E
13:59:25 Get next frame.
13:59:25 Collecting objects
13:59:25
7E A0 37 21 03 B0 64 F8 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 6F D0 7E
13:59:25 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 DC B4 20 7E
13:59:25
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 DD 00 82 02 1F 85 06 03 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 03 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 03 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 03 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 03 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 04 66 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 04 67 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 04 68 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 C9 82 7E
13:59:26
7E A0 37 21 03 D4 46 DD 06 04 69 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 D0 6C 7E
13:59:26 Get Next Data block.
13:59:26 Collecting objects
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 DD 3D 31 7E
13:59:26
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 DE 00 82 02 1F 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 04 6A 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 04 6B 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 04 6C 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 04 6D 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 04 6E 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 04 6F 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 04 70 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 04 65 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 62 01 7E
13:59:26 Get next frame.
13:59:26
7E A0 37 21 03 F8 28 36 01 16 00 02 04 12 00 04 11 00 09 06 01 00 85 06 04 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F B2 82 7E
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 DE A6 03 7E
13:59:27
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 DF 00 82 02 1F 04 16 00 00 02 03 0F 05 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 05 11 00 09 06 01 00 01 04 00 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 01 04 01 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 01 04 02 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 01 04 03 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 01 04 04 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 8A 9B 7E
13:59:27 Get next frame.
13:59:27 Collecting objects
13:59:27
7E A0 37 21 03 1C 02 97 16 00 02 04 12 00 05 11 00 09 06 01 00 02 04 00 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 E7 BF 7E
13:59:27 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 DF 2F 12 7E
13:59:28
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 E0 00 82 02 1F 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 02 04 01 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 02 04 02 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 02 04 03 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 02 04 04 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 03 04 00 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 8E 5D 7E
13:59:28 Get next frame.
13:59:28 Collecting objects
13:59:28
7E A0 37 21 03 30 6C 7C 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 9C B6 7E
13:59:28 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 E0 5B DB 7E
13:59:28
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 E1 00 82 02 1F 03 04 01 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 03 04 02 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 03 04 03 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 03 04 04 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 04 04 00 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 04 04 01 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 AF 06 7E
7E A0 07 03 21 51 11 E4 7E
13:59:28
7E A0 37 21 03 54 4E 59 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 6D 81 7E
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 E1 D2 CA 7E
13:59:29
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 E2 00 82 02 1F 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 04 04 02 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 04 04 03 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 04 04 04 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 0F 04 00 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 0F 04 01 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 A1 DE 7E
13:59:29 Get next frame.
13:59:29 Collecting objects
7E A0 07 03 21 91 1D 22 7E
13:59:29
7E A0 37 21 03 78 20 B2 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 0F 04 02 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 8A 67 7E
13:59:29 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 E2 49 F8 7E
13:59:30
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 E3 00 82 02 1F 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 0F 04 03 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 05 11 00 09 06 01 00 0F 04 04 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 06 11 00 09 06 00 00 0E 00 01 FF 02 02 01 04 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 01 03 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 04 12 00 06 11 00 09 06 00 00 0E 00 02 FF 02 02 01 04 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 01 03 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 04 12 00 07 11 01 09 06 00 00 15 00 02 FF 02 02 01 08 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 15 00 03 FF 40 CA 7E
13:59:30 Get next frame.
13:59:30 Collecting objects
7E A0 07 03 21 D1 19 60 7E
13:59:30
7E A0 37 21 03 9C 0A 13 02 02 01 08 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 DE 92 7E
13:59:30 Get Next Data block.
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 E3 C0 E9 7E
13:59:30
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 E4 00 82 02 1F 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 15 00 04 FF 02 02 01 08 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 62 01 00 FF 02 02 01 08 02 03 0F 01 16 00 01 02 0F 01 0F 02 02 03 0F 02 16 00 01 02 0F 01 0F 02 02 03 0F 03 16 00 01 02 0F 01 0F 02 02 03 0F 04 16 00 01 02 0F 01 0F 02 02 03 0F 05 16 00 01 02 0F 01 0F 02 02 03 0F 06 16 00 01 02 0F 01 0F 02 02 03 0F 07 16 00 01 02 0F 01 0F 02 02 03 0F 08 16 00 01 02 0F 01 0F 02 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 00 FF 02 02 01 08 02 03 0F 01 16 00 01 02 0F 01 0F 02 02 03 0F 02 16 00 01 02 0F 01 0F 02 02 03 0F 03 16 00 01 02 0F 01 0F 02 02 03 0F 04 16 00 01 02 0F 01 0F 02 02 03 0F 05 16 00 01 02 0F 01 0F 02 02 03 0F 06 16 00 01 02 0F 01 0F 02 02 03 0F 07 16 00 01 02 0F 01 0F 02 02 03 0F 08 16 00 01 02 0F 01 0F 02 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 01 FF 02 02 01 08 02 03 0F 01 16 00 01 02 0F 01 0F 02 02 03 0F 02 16 00 01 02 0F 01 0F 02 02 03 0F 03 16 00 01 02 0F 01 0F 02 02 03 0F 04 16 00 01 02 0F 01 0F 02 02 03 0F 05 16 00 01 63 35 7E
7E A0 07 03 21 11 15 A6 7E
13:59:30
7E A0 37 21 03 B0 64 F8 02 0F 01 0F 02 02 03 0F 06 16 00 01 02 0F 01 0F 02 02 03 0F 07 16 00 01 02 0F 01 0F 02 02 03 0F 08 16 00 01 02 0F 01 0F 02 01 04 02 02 0F 4A 4B 7E
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 E4 7F 9D 7E
13:59:31
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 E5 00 82 02 1F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 02 FF 02 02 01 08 02 03 0F 01 16 00 01 02 0F 01 0F 02 02 03 0F 02 16 00 01 02 0F 01 0F 02 02 03 0F 03 16 00 01 02 0F 01 0F 02 02 03 0F 04 16 00 01 02 0F 01 0F 02 02 03 0F 05 16 00 01 02 0F 01 0F 02 02 03 0F 06 16 00 01 02 0F 01 0F 02 02 03 0F 07 16 00 01 02 0F 01 0F 02 02 03 0F 08 16 00 01 02 0F 01 0F 02 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 03 FF 02 02 01 08 02 03 0F 01 16 00 01 02 0F 01 0F 02 02 03 0F 02 16 00 01 02 0F 01 0F 02 02 03 0F 03 16 00 01 02 0F 01 0F 02 02 03 0F 04 16 00 01 02 0F 01 0F 02 02 03 0F 05 16 00 01 02 0F 01 0F 02 02 03 0F 06 16 00 01 02 0F 01 0F 02 02 03 0F 07 16 00 01 02 0F 01 0F 02 02 03 0F 08 16 00 01 02 0F 01 0F 02 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 04 FF 02 02 01 08 02 03 0F 01 16 00 01 02 0F 01 0F 02 02 03 0F 02 16 00 01 02 0F 01 0F 02 02 03 0F 03 16 00 01 02 0F 01 0F 02 02 03 0F 04 16 00 01 02 0F 01 0F 02 02 03 0F 05 16 00 01 02 0F 01 0F 02 02 03 0F 06 16 00 01 02 0F 01 0F 02 02 03 0F 07 16 00 01 02 0F 01 0F 02 02 03 0F 08 16 00 01 02 0F 01 0F 02 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 05 FF 02 02 01 08 02 03 0F 01 16 00 01 02 0F 01 0F 02 02 03 0F 02 16 00 01 02 0F 01 0F 02 02 03 0F 03 16 00 01 02 0F 01 51 A6 7E
13:59:31 Get next frame.
13:59:31 Collecting objects
13:59:31
7E A0 37 21 03 D4 46 DD 0F 02 02 03 0F 04 16 00 01 02 0F 01 0F 02 02 03 0F 05 16 00 01 02 0F 01 0F 02 02 03 0F 06 16 00 01 02 0F 01 0F 02 02 03 0F 07 16 00 01 02 C7 B7 7E
13:59:31 Get Next Data block.
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 E5 F6 8C 7E
13:59:32
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 E6 00 82 02 1F 0F 01 0F 02 02 03 0F 08 16 00 01 02 0F 01 0F 02 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 06 FF 02 02 01 08 02 03 0F 01 16 00 01 02 0F 01 0F 02 02 03 0F 02 16 00 01 02 0F 01 0F 02 02 03 0F 03 16 00 01 02 0F 01 0F 02 02 03 0F 04 16 00 01 02 0F 01 0F 02 02 03 0F 05 16 00 01 02 0F 01 0F 02 02 03 0F 06 16 00 01 02 0F 01 0F 02 02 03 0F 07 16 00 01 02 0F 01 0F 02 02 03 0F 08 16 00 01 02 0F 01 0F 02 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 07 FF 02 02 01 08 02 03 0F 01 16 00 01 02 0F 01 0F 02 02 03 0F 02 16 00 01 02 0F 01 0F 02 02 03 0F 03 16 00 01 02 0F 01 0F 02 02 03 0F 04 16 00 01 02 0F 01 0F 02 02 03 0F 05 16 00 01 02 0F 01 0F 02 02 03 0F 06 16 00 01 02 0F 01 0F 02 02 03 0F 07 16 00 01 02 0F 01 0F 02 02 03 0F 08 16 00 01 02 0F 01 0F 02 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 08 FF 02 02 01 08 02 03 0F 01 16 00 01 02 0F 01 0F 02 02 03 0F 02 16 00 01 02 0F 01 0F 02 02 03 0F 03 16 00 01 02 0F 01 0F 02 02 03 0F 04 16 00 01 02 0F 01 0F 02 02 03 0F 05 16 00 01 02 0F 01 0F 02 02 03 0F 06 16 00 01 02 0F 01 0F 02 02 03 0F 07 16 00 01 02 0F 01 0F 02 02 03 0F 08 16 00 01 02 0F 01 0F 02 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 09 FF 02 02 01 08 02 03 0F 01 16 00 01 02 0F 01 0F 02 02 5B EE 7E
13:59:32 Get next frame.
13:59:32 Collecting objects
13:59:32
7E A0 37 21 03 F8 28 36 03 0F 02 16 00 01 02 0F 01 0F 02 02 03 0F 03 16 00 01 02 0F 01 0F 02 02 03 0F 04 16 00 01 02 0F 01 0F 02 02 03 0F 05 16 00 01 02 0F 01 0F 52 B6 7E
13:59:32 Get Next Data block.
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 E6 6D BE 7E
13:59:32
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 E7 00 82 02 1F 02 02 03 0F 06 16 00 01 02 0F 01 0F 02 02 03 0F 07 16 00 01 02 0F 01 0F 02 02 03 0F 08 16 00 01 02 0F 01 0F 02 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 00 63 62 0C FF 02 02 01 08 02 03 0F 01 16 00 01 02 0F 01 0F 02 02 03 0F 02 16 00 01 02 0F 01 0F 02 02 03 0F 03 16 00 01 02 0F 01 0F 02 02 03 0F 04 16 00 01 02 0F 01 0F 02 02 03 0F 05 16 00 01 02 0F 01 0F 02 02 03 0F 06 16 00 01 02 0F 01 0F 02 02 03 0F 07 16 00 01 02 0F 01 0F 02 02 03 0F 08 16 00 01 02 0F 01 0F 02 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 01 18 03 00 FF 02 02 01 08 02 03 0F 01 16 00 01 02 0F 01 0F 02 02 03 0F 02 16 00 01 02 0F 01 0F 02 02 03 0F 03 16 00 01 02 0F 01 0F 02 02 03 0F 04 16 00 01 02 0F 01 0F 02 02 03 0F 05 16 00 01 02 0F 01 0F 02 02 03 0F 06 16 00 01 02 0F 01 0F 02 02 03 0F 07 16 00 01 02 0F 01 0F 02 02 03 0F 08 16 00 01 02 0F 01 0F 02 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 01 18 05 00 FF 02 02 01 08 02 03 0F 01 16 00 01 02 0F 01 0F 02 02 03 0F 02 16 00 01 02 0F 01 0F 02 02 03 0F 03 16 00 01 02 0F 01 0F 02 02 03 0F 04 16 00 01 02 0F 01 0F 02 02 03 0F 05 16 00 01 02 0F 01 0F 02 02 03 0F 06 16 00 01 02 0F 01 0F 02 02 03 0F 07 16 00 01 02 0F 01 0F 02 02 03 0F 08 16 00 01 02 0F 01 0F 02 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 02 8E 2D 7E
13:59:32
7E A0 37 21 03 1C 02 97 18 03 00 FF 02 02 01 08 02 03 0F 01 16 00 01 02 0F 01 0F 02 02 03 0F 02 16 00 01 02 0F 01 0F 02 02 03 0F 03 16 00 01 02 0F 01 0F 02 02 03 97 E1 7E
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 E7 E4 AF 7E
13:59:33
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 E8 00 82 02 1F 0F 04 16 00 01 02 0F 01 0F 02 02 03 0F 05 16 00 01 02 0F 01 0F 02 02 03 0F 06 16 00 01 02 0F 01 0F 02 02 03 0F 07 16 00 01 02 0F 01 0F 02 02 03 0F 08 16 00 01 02 0F 01 0F 02 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 00 02 18 05 00 FF 02 02 01 08 02 03 0F 01 16 00 01 02 0F 01 0F 02 02 03 0F 02 16 00 01 02 0F 01 0F 02 02 03 0F 03 16 00 01 02 0F 01 0F 02 02 03 0F 04 16 00 01 02 0F 01 0F 02 02 03 0F 05 16 00 01 02 0F 01 0F 02 02 03 0F 06 16 00 01 02 0F 01 0F 02 02 03 0F 07 16 00 01 02 0F 01 0F 02 02 03 0F 08 16 00 01 02 0F 01 0F 02 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 01 00 63 01 00 FF 02 02 01 08 02 03 0F 01 16 00 01 02 0F 01 0F 02 02 03 0F 02 16 00 01 02 0F 01 0F 02 02 03 0F 03 16 00 01 02 0F 01 0F 02 02 03 0F 04 16 00 01 02 0F 01 0F 02 02 03 0F 05 16 00 01 02 0F 01 0F 02 02 03 0F 06 16 00 01 02 0F 01 0F 02 02 03 0F 07 16 00 01 02 0F 01 0F 02 02 03 0F 08 16 00 01 02 0F 01 0F 02 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 01 00 63 02 00 FF 02 02 01 08 02 03 0F 01 16 00 01 02 0F 01 0F 02 02 03 0F 02 16 00 01 02 0F 01 0F 02 02 03 0F 03 16 00 01 02 0F 01 0F 02 02 03 0F 04 16 00 01 02 0F 01 0F 02 02 03 0F 05 16 00 01 02 0F 01 0F 02 02 03 0F 06 16 00 01 02 0F 01 0F 02 02 03 0F 07 16 00 01 02 0F 01 0F 02 02 03 0F 08 16 00 01 02 0F 01 0F 02 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 76 E7 7E
13:59:33 Get next frame.
13:59:33 Collecting objects
13:59:33
7E A0 37 21 03 30 6C 7C 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 01 00 63 03 00 FF 02 02 01 08 02 03 0F 01 16 00 01 02 0F 01 0F 02 02 03 0F 02 16 68 9D 7E
13:59:33 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 E8 13 57 7E
13:59:34
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 E9 00 82 02 1F 00 01 02 0F 01 0F 02 02 03 0F 03 16 00 01 02 0F 01 0F 02 02 03 0F 04 16 00 01 02 0F 01 0F 02 02 03 0F 05 16 00 01 02 0F 01 0F 02 02 03 0F 06 16 00 01 02 0F 01 0F 02 02 03 0F 07 16 00 01 02 0F 01 0F 02 02 03 0F 08 16 00 01 02 0F 01 0F 02 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 07 11 01 09 06 01 00 63 61 00 FF 02 02 01 08 02 03 0F 01 16 00 01 02 0F 01 0F 02 02 03 0F 02 16 00 01 02 0F 01 0F 02 02 03 0F 03 16 00 01 02 0F 01 0F 02 02 03 0F 04 16 00 01 02 0F 01 0F 02 02 03 0F 05 16 00 01 02 0F 01 0F 02 02 03 0F 06 16 00 01 02 0F 01 0F 02 02 03 0F 07 16 00 01 02 0F 01 0F 02 02 03 0F 08 16 00 01 02 0F 01 0F 02 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 08 11 00 09 06 00 00 01 00 00 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 06 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 02 0F 05 16 00 02 02 0F 06 16 00 02 04 12 00 09 11 00 09 06 00 00 0A 00 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 09 11 00 09 06 00 00 0A 00 01 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 09 11 00 09 06 00 00 0A 00 64 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 09 11 00 09 64 47 7E
13:59:34 Get next frame.
13:59:34 Collecting objects
13:59:34
7E A0 37 21 03 54 4E 59 06 00 00 0A 00 6A FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 09 11 00 09 06 00 00 0A 00 B2 74 7E
13:59:34 Get Next Data block.
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 E9 9A 46 7E
13:59:34
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 EA 00 82 02 1F 6B FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 09 11 00 09 06 00 00 0A 01 67 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 09 11 00 09 06 00 01 0A 00 6A FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 09 11 00 09 06 00 00 0A 05 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 0B 11 00 09 06 00 00 0B 00 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 02 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 03 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 01 F0 B7 7E
13:59:35
7E A0 37 21 03 78 20 B2 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 11 11 00 09 06 00 00 29 00 00 FF 02 02 01 02 02 03 8A 89 7E
13:59:35 Get Next Data block.
13:59:35 Collecting objects
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 EA 01 74 7E
13:59:35
7E AA 09 21 03 9A 24 D8 E6 E7 00 C4 02 41 00 00 00 01 EB 00 82 02 1F 0F 01 16 01 00 02 03 0F 02 16 01 00 01 01 02 02 0F 01 16 00 02 04 12 00 12 11 00 09 06 00 00 2C 00 00 FF 02 02 01 07 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 12 11 00 09 06 00 00 2C 00 01 FF 02 02 01 07 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 13 11 01 09 06 00 00 14 00 00 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 00 02 04 12 00 14 11 00 09 06 00 00 0D 00 00 FF 02 02 01 0A 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 02 03 0F 0A 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 15 11 00 09 06 00 00 10 00 01 FF 02 02 01 04 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 01 00 02 04 12 00 15 11 00 09 06 00 00 10 00 02 FF 02 02 01 04 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 01 00 02 04 12 00 16 11 00 09 06 00 EF 8D 7E
13:59:35 Get next frame.
13:59:35
7E A0 37 21 03 9C 0A 13 00 0F 00 00 FF 02 02 01 04 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 01 00 02 04 12 00 16 11 00 09 52 7E
7E A0 13 03 21 F8 97 6D E6 E6 00 C0 02 41 00 00 01 EB 88 65 7E
13:59:36
7E AA 09 21 03 BE 02 BF E6 E7 00 C4 02 41 00 00 00 01 EC 00 82 02 1F 09 06 00 00 0F 00 01 FF 02 02 01 04 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 01 00 02 04 12 00 16 11 00 09 06 00 00 0F 00 02 FF 02 02 01 04 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 01 00 02 04 12 00 16 11 00 09 06 00 00 0F 01 00 FF 02 02 01 04 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 01 00 02 04 12 00 16 11 00 09 06 00 00 0F 01 01 FF 02 02 01 04 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 01 00 02 04 12 00 16 11 00 09 06 00 01 0F 00 01 FF 02 02 01 04 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 01 00 02 04 12 00 16 11 00 09 06 00 01 0F 00 04 FF 02 02 01 04 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 01 00 02 04 12 00 16 11 00 09 06 00 02 0F 00 04 FF 02 02 01 04 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 01 00 02 04 12 00 17 11 01 09 06 00 00 16 00 00 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 00 02 04 12 00 17 11 01 09 06 00 01 16 00 00 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 3B 77 7E
13:59:36 Get next frame.
13:59:36 Collecting objects
13:59:36
7E A0 37 21 03 B0 64 F8 0F 09 16 00 00 01 00 02 04 12 00 1C 11 02 09 06 00 00 02 02 00 FF 02 02 01 07 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 3B 9E 7E
13:59:36 Get Next Data block.
7E A0 13 03 21 3A 89 88 E6 E6 00 C0 02 41 00 00 01 EC 37 11 7E
13:59:36
7E AA 09 21 03 D2 68 16 E6 E7 00 C4 02 41 00 00 00 01 ED 00 82 02 1F 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 01 00 02 04 12 00 1D 11 02 09 06 00 00 02 01 00 FF 02 02 01 06 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 1D 11 02 09 06 00 01 02 01 00 FF 02 02 01 06 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 1D 11 02 09 06 00 02 02 01 00 FF 02 02 01 06 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 1D 11 02 09 06 00 03 02 01 00 FF 02 02 01 06 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 1D 11 02 09 06 00 04 02 01 00 FF 02 02 01 06 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 29 11 00 09 06 00 00 19 00 00 FF 02 02 01 06 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 01 00 02 04 12 00 2A 11 00 09 06 00 00 19 01 00 FF 02 02 01 0A 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 3F 4D 7E
13:59:37
7E A0 37 21 03 D4 46 DD 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 02 03 0F 0A 16 00 00 01 03 02 02 0F 01 16 00 02 02 0F 02 16 00 02 85 B1 7E
13:59:37 Get Next Data block.
13:59:37 Collecting objects
7E A0 13 03 21 7C BB AF E6 E6 00 C0 02 41 00 00 01 ED BE 00 7E
13:59:37
7E AA 09 21 03 F6 4E 71 E6 E7 00 C4 02 41 00 00 00 01 EE 00 82 02 1F 02 0F 03 16 00 02 04 12 00 2C 11 00 09 06 00 00 19 03 00 FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 00 02 04 12 00 2D 11 00 09 06 00 00 19 04 00 FF 02 02 01 04 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 01 00 02 04 12 00 2F 11 00 09 06 00 00 19 06 00 FF 02 02 01 08 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 82 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 83 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 84 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 85 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 86 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 87 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 88 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 89 FF 02 B1 95 7E
13:59:37 Get next frame.
13:59:37
7E A0 37 21 03 F8 28 36 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 8A FF 02 02 01 03 02 D4 92 7E
7E A0 13 03 21 BE A5 4A E6 E6 00 C0 02 41 00 00 01 EE 25 32 7E
13:59:38
7E AA 09 21 03 1A 2C 5C E6 E7 00 C4 02 41 00 00 00 01 EF 00 82 02 1F 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 8B FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 8C FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 8D FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 8E FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 8F FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 90 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 91 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 92 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 93 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 94 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 95 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 BC DF 7E
13:59:38 Get next frame.
13:59:38 Collecting objects
13:59:38
7E A0 37 21 03 1C 02 97 96 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 97 FF 02 02 FD 75 7E
13:59:38 Get Next Data block.
7E A0 13 03 21 F0 DF E1 E6 E6 00 C0 02 41 00 00 01 EF AC 23 7E
13:59:39
7E AA 09 21 03 3E 0A 3B E6 E7 00 C4 02 41 00 00 00 01 F0 00 82 02 1F 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 98 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 99 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 9A FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 9B FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 9C FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 A0 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 A1 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 A2 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 A3 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 A4 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 00 60 04 A5 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 3F 11 00 09 06 00 C9 09 7E
13:59:39 Get next frame.
13:59:39 Collecting objects
13:59:39
7E A0 37 21 03 30 6C 7C 00 60 04 A6 FF 02 02 01 03 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 01 00 02 04 12 00 40 11 00 09 06 00 00 2B 00 00 FF 2E 7E
13:59:39 Get Next Data block.
7E A0 13 03 21 32 C1 04 E6 E6 00 C0 02 41 00 00 01 F0 DA CB 7E
13:59:39
7E AA 09 21 03 52 60 92 E6 E7 00 C4 02 41 00 00 00 01 F1 00 82 02 1F FF 02 02 01 05 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 46 11 00 09 06 00 00 60 03 0A FF 02 02 01 04 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 46 11 00 09 06 00 01 18 04 00 FF 02 02 01 04 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 46 11 00 09 06 00 02 18 04 00 FF 02 02 01 04 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 01 02 02 02 0F 01 16 00 02 02 0F 02 16 00 02 04 12 00 47 11 00 09 06 00 00 11 00 00 FF 02 02 01 0B 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 02 03 0F 0A 16 00 00 02 03 0F 0B 16 00 00 01 00 02 04 12 00 48 11 01 09 06 00 01 18 01 00 FF 02 02 01 0E 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 02 03 0F 0A 16 00 00 02 03 0F 0B 16 00 00 02 03 0F 0C 16 00 00 02 03 0F 0D 16 00 00 02 03 0F 0E 16 00 00 01 08 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 02 0F 05 16 00 02 02 0F 06 16 00 02 02 0F 07 16 00 02 8C 81 7E
13:59:39
7E A0 37 21 03 54 4E 59 02 0F 08 16 00 02 04 12 00 48 11 01 09 06 00 02 18 01 00 FF 02 02 01 0E 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 94 28 7E
7E A0 13 03 21 74 F3 23 E6 E6 00 C0 02 41 00 00 01 F1 53 DA 7E
13:59:40
7E AA 09 21 03 76 46 F5 E6 E7 00 C4 02 41 00 00 00 01 F2 00 82 02 1F 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 02 03 0F 0A 16 00 00 02 03 0F 0B 16 00 00 02 03 0F 0C 16 00 00 02 03 0F 0D 16 00 00 02 03 0F 0E 16 00 00 01 08 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 02 0F 05 16 00 02 02 0F 06 16 00 02 02 0F 07 16 00 02 02 0F 08 16 00 02 04 12 00 48 11 01 09 06 00 03 18 01 00 FF 02 02 01 0E 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 02 03 0F 0A 16 00 00 02 03 0F 0B 16 00 00 02 03 0F 0C 16 00 00 02 03 0F 0D 16 00 00 02 03 0F 0E 16 00 00 01 08 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 02 0F 05 16 00 02 02 0F 06 16 00 02 02 0F 07 16 00 02 02 0F 08 16 00 02 04 12 00 48 11 01 09 06 00 04 18 01 00 FF 02 02 01 0E 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 02 03 0F 0A 16 00 00 02 03 0F 0B 16 00 00 02 03 0F 0C 16 00 00 02 03 0F 0D 16 00 00 02 03 0F 0E 16 00 00 01 08 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 02 0F 05 16 00 02 02 0F 06 16 00 02 02 0F 07 16 00 02 02 0F 08 16 00 02 04 12 00 4A 11 00 09 06 00 00 18 06 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 ED 8B 7E
13:59:40 Get next frame.
13:59:40 Collecting objects
13:59:40
7E A0 37 21 03 78 20 B2 12 00 4A 11 00 09 06 00 01 18 06 00 FF 02 02 01 02 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 01 00 02 04 12 00 4D 11 00 09 06 00 00 18 09 1B CD 7E
13:59:40 Get Next Data block.
7E A0 13 03 21 B6 ED C6 E6 E6 00 C0 02 41 00 00 01 F2 C8 E8 7E
13:59:40
7E A0 BE 21 03 9A 31 A2 E6 E7 00 C4 02 41 01 00 00 01 F3 00 81 A7 00 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 01 02 02 0F 01 16 00 02 04 12 00 4D 11 00 09 06 00 01 18 09 00 FF 02 02 01 09 02 03 0F 01 16 00 00 02 03 0F 02 16 00 00 02 03 0F 03 16 00 00 02 03 0F 04 16 00 00 02 03 0F 05 16 00 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 02 03 0F 09 16 00 00 01 01 02 02 0F 01 16 00 09 4F 7E
13:59:44 --- Collecting 5344 objects. ---
13:59:44 --- Created 5344 objects. ---
13:59:44 --- Reading scalers and units. ---
13:59:44 Reading object 1.0.1.4.0.255, interface DemandRegister
7E A0 19 03 21 D8 3B 90 E6 E6 00 C0 01 41 00 05 01 00 01 04 00 FF 08 00 76 D4 7E
13:59:44
7E A0 11 21 03 BC C1 F6 E6 E7 00 C4 01 41 01 03 9F 8E 7E
13:59:44 Access Error : Device reports Read-Write denied.
13:59:44 Reading object 1.0.1.4.1.255, interface DemandRegister
7E A0 19 03 21 FA 2B 92 E6 E6 00 C0 01 41 00 05 01 00 01 04 01 FF 08 00 CD C8 7E
13:59:44
7E A0 11 21 03 DE D5 B6 E6 E7 00 C4 01 41 01 03 9F 8E 7E
13:59:44 Reading object 1.0.1.4.2.255, interface DemandRegister
7E A0 19 03 21 1C 13 10 E6 E6 00 C0 01 41 00 05 01 00 01 04 02 FF 08 00 00 ED 7E
13:59:44
7E A0 11 21 03 F0 A9 7E E6 E7 00 C4 01 41 01 03 9F 8E 7E
13:59:44 Reading object 1.0.1.4.3.255, interface DemandRegister
7E A0 19 03 21 3E 03 12 E6 E6 00 C0 01 41 00 05 01 00 01 04 03 FF 08 00 BB F1 7E
13:59:44
7E A0 11 21 03 12 B5 BA E6 E7 00 C4 01 41 01 03 9F 8E 7E
13:59:44 Reading object 1.0.1.4.4.255, interface DemandRegister
7E A0 19 03 21 50 7B 98 E6 E6 00 C0 01 41 00 05 01 00 01 04 04 FF 08 00 9A A6 7E
13:59:44
7E A0 11 21 03 34 81 FE E6 E7 00 C4 01 41 01 03 9F 8E 7E
13:59:44 Reading object 1.0.2.4.0.255, interface DemandRegister
7E A0 19 03 21 72 6B 9A E6 E6 00 C0 01 41 00 05 01 00 02 04 00 FF 08 00 0B D8 7E
13:59:45
7E A0 11 21 03 56 95 BE E6 E7 00 C4 01 41 01 03 9F 8E 7E
13:59:45 Access Error : Device reports Read-Write denied.
13:59:45 Reading object 1.0.2.4.1.255, interface DemandRegister
7E A0 19 03 21 94 53 18 E6 E6 00 C0 01 41 00 05 01 00 02 04 01 FF 08 00 B0 C4 7E
13:59:45
7E A0 11 21 03 78 E9 76 E6 E7 00 C4 01 41 01 03 9F 8E 7E
13:59:45 Reading object 1.0.2.4.2.255, interface DemandRegister
7E A0 19 03 21 B6 43 1A E6 E6 00 C0 01 41 00 05 01 00 02 04 02 FF 08 00 7D E1 7E
13:59:45
7E A0 11 21 03 9A F5 B2 E6 E7 00 C4 01 41 01 03 9F 8E 7E
13:59:45 Reading object 1.0.2.4.3.255, interface DemandRegister
7E A0 19 03 21 D8 3B 90 E6 E6 00 C0 01 41 00 05 01 00 02 04 03 FF 08 00 C6 FD 7E
13:59:45
13:59:45 Reading object 1.0.2.4.4.255, interface DemandRegister
7E A0 19 03 21 FA 2B 92 E6 E6 00 C0 01 41 00 05 01 00 02 04 04 FF 08 00 E7 AA 7E
13:59:45
13:59:45 Reading object 1.0.3.4.0.255, interface DemandRegister
7E A0 19 03 21 1C 13 10 E6 E6 00 C0 01 41 00 05 01 00 03 04 00 FF 08 00 20 DC 7E
13:59:45
13:59:45 Reading object 1.0.3.4.1.255, interface DemandRegister
7E A0 19 03 21 3E 03 12 E6 E6 00 C0 01 41 00 05 01 00 03 04 01 FF 08 00 9B C0 7E
13:59:45
13:59:45 Reading object 1.0.3.4.2.255, interface DemandRegister
7E A0 19 03 21 50 7B 98 E6 E6 00 C0 01 41 00 05 01 00 03 04 02 FF 08 00 56 E5 7E
13:59:45
13:59:45 Reading object 1.0.3.4.3.255, interface DemandRegister
7E A0 19 03 21 72 6B 9A E6 E6 00 C0 01 41 00 05 01 00 03 04 03 FF 08 00 ED F9 7E
13:59:45
13:59:45 Reading object 1.0.3.4.4.255, interface DemandRegister
7E A0 19 03 21 94 53 18 E6 E6 00 C0 01 41 00 05 01 00 03 04 04 FF 08 00 CC AE 7E
13:59:45
13:59:45 Reading object 1.0.4.4.0.255, interface DemandRegister
7E A0 19 03 21 B6 43 1A E6 E6 00 C0 01 41 00 05 01 00 04 04 00 FF 08 00 F1 C0 7E
13:59:45
13:59:45 Reading object 1.0.4.4.1.255, interface DemandRegister
7E A0 19 03 21 D8 3B 90 E6 E6 00 C0 01 41 00 05 01 00 04 04 01 FF 08 00 4A DC 7E
13:59:45
13:59:45 Reading object 1.0.4.4.2.255, interface DemandRegister
7E A0 19 03 21 FA 2B 92 E6 E6 00 C0 01 41 00 05 01 00 04 04 02 FF 08 00 87 F9 7E
13:59:45
13:59:45 Reading object 1.0.4.4.3.255, interface DemandRegister
7E A0 19 03 21 1C 13 10 E6 E6 00 C0 01 41 00 05 01 00 04 04 03 FF 08 00 3C E5 7E
13:59:45
13:59:45 Reading object 1.0.4.4.4.255, interface DemandRegister
7E A0 19 03 21 3E 03 12 E6 E6 00 C0 01 41 00 05 01 00 04 04 04 FF 08 00 1D B2 7E
13:59:46
13:59:46 Access Error : Device reports Read-Write denied.
13:59:46 Reading object 1.0.15.4.0.255, interface DemandRegister
7E A0 19 03 21 50 7B 98 E6 E6 00 C0 01 41 00 05 01 00 0F 04 00 FF 08 00 D4 ED 7E
13:59:46
13:59:46 Reading object 1.0.15.4.1.255, interface DemandRegister
7E A0 19 03 21 72 6B 9A E6 E6 00 C0 01 41 00 05 01 00 0F 04 01 FF 08 00 6F F1 7E
13:59:46
13:59:46 Reading object 1.0.15.4.2.255, interface DemandRegister
7E A0 19 03 21 94 53 18 E6 E6 00 C0 01 41 00 05 01 00 0F 04 02 FF 08 00 A2 D4 7E
13:59:46
13:59:46 Reading object 1.0.15.4.3.255, interface DemandRegister
7E A0 19 03 21 B6 43 1A E6 E6 00 C0 01 41 00 05 01 00 0F 04 03 FF 08 00 19 C8 7E
13:59:46
13:59:46 Reading object 1.0.15.4.4.255, interface DemandRegister
7E A0 19 03 21 D8 3B 90 E6 E6 00 C0 01 41 00 05 01 00 0F 04 04 FF 08 00 38 9F 7E
13:59:46
13:59:46 --- Reading scalers and units end. ---
13:59:46 Reading object 0.0.21.0.2.255, interface ProfileGeneric
7E A0 19 03 21 FA 2B 92 E6 E6 00 C0 01 41 00 07 00 00 15 00 02 FF 03 00 E1 6C 7E
13:59:46 Get profile generic columns...
13:59:46
14:00:07 Reading object 0.0.21.0.3.255, interface ProfileGeneric
7E A0 19 03 21 1C 13 10 E6 E6 00 C0 01 41 00 07 00 00 15 00 03 FF 03 00 5A 70 7E
14:00:07 Get profile generic columns...
14:00:07
14:00:08 Reading object 0.0.21.0.4.255, interface ProfileGeneric
7E A0 19 03 21 3E 03 12 E6 E6 00 C0 01 41 00 07 00 00 15 00 04 FF 03 00 7B 27 7E
14:00:08 Get profile generic columns...
14:00:08
14:00:09 Reading object 0.0.98.1.0.255, interface ProfileGeneric
7E A0 19 03 21 50 7B 98 E6 E6 00 C0 01 41 00 07 00 00 62 01 00 FF 03 00 03 87 7E
14:00:09 Get profile generic columns...
14:00:09
14:00:11 Reading object 0.0.99.98.0.255, interface ProfileGeneric
7E A0 19 03 21 72 6B 9A E6 E6 00 C0 01 41 00 07 00 00 63 62 00 FF 03 00 57 3F 7E
14:00:11 Get profile generic columns...
14:00:11
14:00:13 Reading object 0.0.99.98.1.255, interface ProfileGeneric
7E A0 19 03 21 94 53 18 E6 E6 00 C0 01 41 00 07 00 00 63 62 01 FF 03 00 EC 23 7E
14:00:13 Get profile generic columns...
14:00:13
14:00:14 Reading object 0.0.99.98.2.255, interface ProfileGeneric
7E A0 19 03 21 B6 43 1A E6 E6 00 C0 01 41 00 07 00 00 63 62 02 FF 03 00 21 06 7E
14:00:14 Get profile generic columns...
14:00:14
14:00:15 Reading object 0.0.99.98.3.255, interface ProfileGeneric
7E A0 19 03 21 D8 3B 90 E6 E6 00 C0 01 41 00 07 00 00 63 62 03 FF 03 00 9A 1A 7E
14:00:15 Get profile generic columns...
14:00:15
14:00:16 Reading object 0.0.99.98.4.255, interface ProfileGeneric
7E A0 19 03 21 FA 2B 92 E6 E6 00 C0 01 41 00 07 00 00 63 62 04 FF 03 00 BB 4D 7E
14:00:16 Get profile generic columns...
14:00:16
14:00:16 Reading object 0.0.99.98.5.255, interface ProfileGeneric
7E A0 19 03 21 1C 13 10 E6 E6 00 C0 01 41 00 07 00 00 63 62 05 FF 03 00 00 51 7E
14:00:16
14:00:17 Reading object 0.0.99.98.6.255, interface ProfileGeneric
7E A0 19 03 21 3E 03 12 E6 E6 00 C0 01 41 00 07 00 00 63 62 06 FF 03 00 CD 74 7E
14:00:17 Get profile generic columns...
14:00:17
14:00:18 Reading object 0.0.99.98.7.255, interface ProfileGeneric
7E A0 19 03 21 50 7B 98 E6 E6 00 C0 01 41 00 07 00 00 63 62 07 FF 03 00 76 68 7E
14:00:18 Get profile generic columns...
14:00:18
14:00:20 Reading object 0.0.99.98.8.255, interface ProfileGeneric
7E A0 19 03 21 72 6B 9A E6 E6 00 C0 01 41 00 07 00 00 63 62 08 FF 03 00 8F DA 7E
14:00:20 Get profile generic columns...
14:00:20
14:00:20 Reading object 0.0.99.98.9.255, interface ProfileGeneric
7E A0 19 03 21 94 53 18 E6 E6 00 C0 01 41 00 07 00 00 63 62 09 FF 03 00 34 C6 7E
14:00:20
14:00:21 Reading object 0.0.99.98.12.255, interface ProfileGeneric
7E A0 19 03 21 B6 43 1A E6 E6 00 C0 01 41 00 07 00 00 63 62 0C FF 03 00 63 A8 7E
14:00:21 Get profile generic columns...
14:00:21
14:00:21 Reading object 0.1.24.3.0.255, interface ProfileGeneric
7E A0 19 03 21 D8 3B 90 E6 E6 00 C0 01 41 00 07 00 01 18 03 00 FF 03 00 51 E2 7E
14:00:21
14:00:21 Reading object 0.1.24.5.0.255, interface ProfileGeneric
7E A0 19 03 21 FA 2B 92 E6 E6 00 C0 01 41 00 07 00 01 18 05 00 FF 03 00 C9 D9 7E
14:00:21
14:00:21 Reading object 0.2.24.3.0.255, interface ProfileGeneric
7E A0 19 03 21 1C 13 10 E6 E6 00 C0 01 41 00 07 00 02 18 03 00 FF 03 00 3F 4A 7E
14:00:21
14:00:22 Reading object 0.2.24.5.0.255, interface ProfileGeneric
7E A0 19 03 21 3E 03 12 E6 E6 00 C0 01 41 00 07 00 02 18 05 00 FF 03 00 A7 71 7E
14:00:22 Get profile generic columns...
14:00:22
14:00:22 Reading object 1.0.99.1.0.255, interface ProfileGeneric
7E A0 19 03 21 50 7B 98 E6 E6 00 C0 01 41 00 07 01 00 63 01 00 FF 03 00 97 02 7E
14:00:23
14:00:23 Reading object 1.0.99.2.0.255, interface ProfileGeneric
7E A0 19 03 21 72 6B 9A E6 E6 00 C0 01 41 00 07 01 00 63 02 00 FF 03 00 5B 1F 7E
14:00:23 Get profile generic columns...
14:00:23
14:00:25 Reading object 1.0.99.3.0.255, interface ProfileGeneric
7E A0 19 03 21 94 53 18 E6 E6 00 C0 01 41 00 07 01 00 63 03 00 FF 03 00 1F 14 7E
14:00:25 Get profile generic columns...
14:00:25
14:00:25 Reading object 1.0.99.97.0.255, interface ProfileGeneric
7E A0 19 03 21 B6 43 1A E6 E6 00 C0 01 41 00 07 01 00 63 61 00 FF 03 00 24 A3 7E
14:00:25
1 year 8 months ago
Hi, The meter doesn't…
The meter doesn't implement the demand register period attribute.
When you get this error save the file and re-open it. You can now see the association view.
Profile picture for user oulahsensaid
oulahsensaid
1 year 8 months ago
I don't know how. What about…
I don't know how.
What about this error:
15:11:04 Initializing serial connection.
15:11:05 IEC Sending:/?!<CR><LF>
15:11:05 HDLC received: /CLE5\2<CR><LF>
15:11:05 BaudRate is : 9600
15:11:05 Moving to mode E.
06 32 35 32 0D 0A
15:11:09 Send SNRM request.
7E A0 07 03 25 93 6F 66 7E
15:11:09
7E A0 20 25 03 73 12 FB 81 80 14 05 02 02 00 06 02 02 00 07 04 00 00 00 01 08 04 00 00 00 01 6F EF 7E
15:11:09 Parsing UA reply succeeded.
15:11:09 Send AARQ request.
7E A0 44 03 25 10 86 E3 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 31 32 33 34 35 36 37 38 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 1E 5D FF FF 92 4A 7E
15:11:14 Data send failed. Try to resend 1/3
15:11:14
7E A0 07 25 03 31 76 42 7E
15:11:14 Disconnect request
15:11:14
System.Exception: Frame is not fully received.
à Gurux.DLMS.GXDLMSClient.ParseAAREResponse(GXByteBuffer reply)
à GXDLMSDirector.GXDLMSCommunicator.ParseAAREResponse(GXByteBuffer data)
à GXDLMSDirector.GXDLMSCommunicator.InitializeConnection(Boolean force)
à GXDLMSDirector.GXDLMSDevice.InitializeConnection()
à GXDLMSDirector.MainForm.Connect(Object sender, GXAsyncWork work, Object[] parameters)
1 year 7 months ago
Hi, The client tries to…
The client tries to establish the connection to the meter, but the meter returns an invalid reply.
I believe one of your settings differs from what the meter expects.
