  3. Updating Global Authentication Key(gak) and Unicast Encryption Key(guek)
Updating global authentication key(gak) and unicast encryption key(guek)
By hayari , 1 October, 2024
I'm trying to update only global authentication key with master key on Indian
meters like Zensmart
But i'm not able to change only one key each time, when i change gak or guek it changes the tow global keys with the same value
Im using gurux client on Security setup object 0.0.43.0.0.255
Please help
thanks
2 years 1 month ago
Hi, If you update only one…
If you update only one key and both keys are updated this is a meter issue. There is nothing you can do to it except ask if there is a firmware update available that fixes this.
