  3. Gurux.DLMS 9.0.2409.1701 and Above Error Get Associationview
Gurux.DLMS 9.0.2409.1701 and above error get associationview
By gpatane , 20 September, 2024
I have a problem after updating Gurux.DLMS to the latest version.
Up until version 9.0.2409.1101 everything worked fine but with version Gurux.DLMS 9.0.2409.1701 and above I have this error:
' get the items from the meter
Dim cacheAssociationView As New GXDLMSObjectCollection
Dim reply As New GXReplyData()
ReadDataBlock(Client.GetObjectsRequest(), reply)
cacheAssociationView = Client.ParseObjects(reply.Data, True) <- *** THE ERROR IS HERE ***
Gurux.DLMS.GXDLMSException: Invalid response.
in Gurux.DLMS.GXDLMSClient.ParseSNObjects(GXByteBuffer buff, Boolean onlyKnownObjects, Boolean ignoreInactiveObjects)
in Gurux.DLMS.GXDLMSClient.ParseObjects(GXByteBuffer data, Boolean onlyKnownObjects, Boolean ignoreInactiveObjects)
in eMeter.GXCommunication.GetAssociationView2(String XmlAssociationCache)
Meter is Landis and I have never had a problem like this.
2 years 1 month ago
Hi, This is fixed and the…
This is fixed and the new version is released today.
gpatane
2 years 1 month ago
With update 9.0.2409.2002…
With update 9.0.2409.2002 the previous error has been fixed but I get an error in the next steps when Read scalers and units from the device for GXDLMSRegister and GXDLMSDemandRegister:
Gurux.DLMS.GXDLMSException: Invalid block length.
in eMeter.GXCommunication.ReadDLMSPacket(Byte[] data, GXReplyData reply) in C:\Users\Dev\Meters\DLMS\GXCommunication.vb:riga 849
in eMeter.GXCommunication.ReadDataBlock(Byte[] data, GXReplyData reply) in C:\Users\Dev\Meters\DLMS\GXCommunication.vb:riga 946
in eMeter.GXCommunication.ReadList(List`1 list) in C:\Users\Dev\Meters\DLMS\GXCommunication.vb:riga 657
in eMeter.DLMS2_Class.Connect()
2 years 1 month ago
Hi, The old code is returned…
The old code is returned because it works with old meters. I need to think how to handle newer meters. I didn't remember that some L+G meters are using this differently. Old L+G meters do not use blocks and they are just add all data to a single reply. This is causing the problem.
Update to the version 9.0.2409.2004.
gpatane
2 years 1 month ago
It's working now, many…
It's working now, many thanks for the always great support
Best regards
Giacomo
