I am trying to set some sort of security level to test the Meter.
For example
by default the security for Manager level is :
Authentication: HLS_GMAC
Use Dedicated Key: True
Application Context: LN-With Ciphering
in the properties section.
My question is:
Where can I change these parameter to something else..(Where is the Location).
like where can I set Authentication to LLS instead of HLS_GMAC?
and what is the meaning of use dedicated Key: False
is this mean should I remove any credential and set nothing in the blanks when I want to set as False?
I am new here.
Thanks anyway for any help
Hi, You can change those…
You can change those parameters when you select "Secured connections" tab in GXDLMSDirector.
dedicated Key: False means the meter doesn't use a dedicated key. You can leave the dedicated key to empty.
Thank you...
Thank you...
