  3. Command Line Issue
command line issue
By rajeshvarma680 , 17 August, 2024
Gurux.Net
Dear Sir,
I am using .net project of gurux and try to use
Gurux.DLMS.Client.Example.Net.exe -S COM16 -c 32 -s 1 -a Low -P xxxxxxxxxxxxxxxx -C None -V Suite0 -d India
Able to download other data but for below obis code no response
-------- Reading GXDLMSProfileGeneric 0.0.99.98.0.255 Voltage Related Events Profile
Entries: 0/0
-------- Reading GXDLMSProfileGeneric 0.0.99.98.1.255 Current Related Events Profile
Entries: 0/0
-------- Reading GXDLMSProfileGeneric 0.0.99.98.4.255 Other Tamper Events Profile
Entries: 0/0
-------- Reading GXDLMSProfileGeneric 0.0.99.98.2.255 Power Related Events Profile
Entries: 0/0
-------- Reading GXDLMSProfileGeneric 0.0.99.98.3.255 Transaction Events Profile
Entries: 0/0
-------- Reading GXDLMSProfileGeneric 0.0.99.98.5.255 Non Roll Over Events Profile
Entries: 0/0
-------- Reading GXDLMSProfileGeneric 0.0.99.98.6.255 Control Events Profile
Entries: 0/0
The same meter read through reading through gurux director and select all received below data
Entries: 8/98
28-09-2022 13:04:10 | 51 | 1500 | 229.59 | 0.501 | 150 | 1 |
28-09-2022 13:04:10 | 69 | 1500 | 229.59 | 0.501 | 150 | 2 |
21-12-2022 14:13:43 | 52 | 999 | 239.99 | 1 | 7850 | 2 |
12-06-2023 13:08:05 | 70 | 914 | 217.45 | 1 | 17970 | 4 |
15-06-2023 15:48:24 | 69 | 999 | 240.09 | 0.5 | 18090 | 5 |
05-01-2024 19:15:22 | 51 | 91 | 240.09 | 1 | 29460 | 7 |
06-01-2024 11:54:03 | 52 | 90 | 239.6 | 1 | 29470 | 7 |
06-01-2024 15:12:28 | 51 | 499 | 240.13 | 1 | 30400 | 8 |
06-01-2024 15:19:59 | 52 | 1499 | 240.27 | 1 | 30470 | 8 |
05-02-2024 16:44:43 | 51 | 999 | 240.13 | 1 | 33250 | 8 |
05-02-2024 17:11:41 | 52 | 999 | 239.38 | 1 | 33370 | 8 |
08-02-2024 14:25:01 | 51 | 999 | 240.06 | 1 | 34190 | 9 |
08-02-2024 14:44:12 | 52 | 999 | 239.99 | 1 | 34300 | 9 |
08-02-2024 15:40:45 | 51 | 999 | 240.34 | 1 | 34980 | 10 |
08-02-2024 16:40:00 | 52 | 3000 | 240.13 | 1 | 35130 | 10 |
08-02-2024 16:51:29 | 51 | 999 | 240.2 | 1 | 35610 | 11 |
08-02-2024 18:37:59 | 52 | 6004 | 239.38 | 1 | 35820 | 11 |
15-03-2024 10:56:23 | 51 | 999 | 240.31 | 1 | 40440 | 13 |
15-03-2024 11:04:30 | 52 | 1000 | 240.34 | 1 | 40520 | 13 |
19-04-2024 15:20:35 | 70 | 22 | 227.42 | 1 | 41030 | 13 |
20-04-2024 16:47:15 | 69 | 1000 | 240.13 | 1 | 41220 | 14 |
Entries: 21/100
21-09-2022 10:45:04 | 209 | 0 | 0 | 1 | 0 | 1 |
21-09-2022 10:45:34 | 210 | 0 | 198.44 | 1 | 0 | 1 |
23-01-2023 10:58:25 | 207 | 138 | 240 | 1 | 8670 | 3 |
23-01-2023 17:20:36 | 208 | 0 | 240.17 | 1 | 9400 | 3 |
18-02-2023 17:43:30 | 207 | 167 | 240 | 1 | 13610 | 4 |
19-02-2023 09:57:51 | 208 | 0 | 239.88 | 1 | 13620 | 4 |
22-07-2023 11:36:40 | 209 | 0 | 0 | 1 | 24530 | 6 |
22-07-2023 11:37:35 | 210 | 0 | 0 | 1 | 24530 | 6 |
08-02-2024 18:38:00 | 215 | 6009 | 240.17 | 1 | 36430 | 12 |
08-02-2024 18:41:03 | 216 | 0 | 240.09 | 1 | 36440 | 12 |
22-04-2024 11:58:52 | 215 | 6015 | 240.38 | 1 | 44580 | 15 |
22-04-2024 12:02:39 | 216 | 0 | 240.45 | 1 | 44620 | 15 |
22-04-2024 12:17:04 | 215 | 6014 | 240.42 | 1 | 45460 | 16 |
22-04-2024 12:20:08 | 216 | 0 | 240.42 | 1 | 45480 | 16 |
22-04-2024 14:59:28 | 215 | 6016 | 240.38 | 1 | 49300 | 17 |
22-04-2024 15:13:08 | 216 | 0 | 240.38 | 1 | 49320 | 17 |
22-04-2024 19:08:04 | 215 | 6016 | 240.34 | 1 | 50950 | 18 |
22-04-2024 19:11:07 | 216 | 0 | 240.45 | 1 | 50970 | 18 |
25-04-2024 11:33:10 | 215 | 6016 | 240.38 | 1 | 54650 | 19 |
25-04-2024 11:36:13 | 216 | 0 | 240.42 | 1 | 54670 | 19 |
22-05-2024 14:08:07 | 203 | 0 | 312.69 | 1 | 57180 | 21 |
22-05-2024 14:15:20 | 204 | 0 | 288.44 | 1 | 57180 | 21 |
29-05-2024 16:36:34 | 215 | 6020 | 240.66 | 1 | 58170 | 23 |
29-05-2024 16:39:56 | 216 | 0 | 240.2 | 1 | 58190 | 23 |
19-07-2024 10:34:01 | 215 | 6013 | 240.42 | 1 | 67790 | 25 |
19-07-2024 10:37:05 | 216 | 0 | 240.13 | 1 | 67810 | 25 |
Entries: 26/40
19-07-2024 17:03:15 | 101 |
19-07-2024 17:40:51 | 102 |
19-07-2024 18:12:14 | 101 |
20-07-2024 09:44:49 | 102 |
20-07-2024 11:26:13 | 101 |
20-07-2024 11:49:58 | 102 |
20-07-2024 11:51:00 | 101 |
23-07-2024 11:17:04 | 102 |
23-07-2024 11:23:55 | 101 |
23-07-2024 12:01:49 | 102 |
23-07-2024 12:14:57 | 101 |
23-07-2024 12:27:30 | 102 |
23-07-2024 13:22:29 | 101 |
23-07-2024 16:47:10 | 102 |
23-07-2024 16:58:49 | 101 |
29-07-2024 14:56:12 | 102 |
29-07-2024 16:50:01 | 101 |
29-07-2024 17:01:33 | 102 |
29-07-2024 17:01:39 | 101 |
29-07-2024 17:15:31 | 102 |
29-07-2024 17:47:28 | 101 |
29-07-2024 17:57:53 | 102 |
29-07-2024 18:44:37 | 101 |
30-07-2024 13:09:24 | 102 |
30-07-2024 13:22:50 | 101 |
30-07-2024 17:19:36 | 102 |
30-07-2024 17:50:50 | 101 |
30-07-2024 18:33:27 | 102 |
30-07-2024 18:37:54 | 101 |
31-07-2024 15:56:08 | 102 |
31-07-2024 15:58:19 | 101 |
31-07-2024 16:11:12 | 102 |
31-07-2024 16:15:17 | 101 |
03-08-2024 14:48:02 | 102 |
03-08-2024 15:04:46 | 101 |
03-08-2024 15:15:14 | 102 |
03-08-2024 15:15:21 | 101 |
03-08-2024 15:27:41 | 102 |
03-08-2024 18:33:22 | 101 |
05-08-2024 09:55:09 | 102 |
05-08-2024 09:55:16 | 101 |
05-08-2024 11:10:29 | 102 |
05-08-2024 11:26:30 | 101 |
07-08-2024 18:01:46 | 102 |
07-08-2024 18:39:33 | 101 |
08-08-2024 09:37:11 | 102 |
08-08-2024 17:55:19 | 101 |
14-08-2024 16:01:43 | 102 |
14-08-2024 19:37:01 | 101 |
17-08-2024 14:15:34 | 102 |
Entries: 50/50
04-07-2024 15:20:54 | 160 |
04-07-2024 15:22:29 | 159 |
06-07-2024 19:01:03 | 160 |
08-07-2024 19:07:49 | 159 |
12-07-2024 16:08:24 | 160 |
12-07-2024 16:11:06 | 159 |
12-07-2024 17:39:28 | 160 |
16-07-2024 16:08:54 | 159 |
08-08-2024 10:29:17 | 160 |
08-08-2024 10:32:11 | 159 |
Entries: 10/10
Entries: 0/1
1.Why it behave differently . There is no option for selection for all data or entry data in command line.
2. I also add -g "0.0.99.98.1.0.255:3;0.0.99.98.1.0.255:2" in command line but not getting data
Is it any way to read 0.0.99.98.1.0.255 instead of of entire thing
2 years ago
Hi, This is a simple example…
This is a simple example. You can modify examples for your needs.
rajeshvarma680
2 years ago
Ok Sir, We understood that…
Ok Sir,
We understood that we can modify but default what it is reading in profile (Tamper profile 0.0.99.98.1.0.255) All data or entry
Gurux.DLMS.Client.Example.Net.exe -S COM16 -c 32 -s 1 -a Low -P xxxxxxxxxxx -C None -V Suite0 -d India
2 years ago
Hi, Check that 0.0.99.98.1.0…
Check that 0.0.99.98.1.0.255 is available with this association. Now it seems like it's not.
You can use GXDLMSDirector to read it and see all available profile generic objects.
rajeshvarma680
2 years ago
Sir, We have checked through…
Sir,
We have checked through GXDLMSDirector and the association -profile the mentioned obis code 0.0.99.98.1.255 is exist and we are also download individual all read.
We have already shared the log in my first comment
2 years ago
Hi, You were talking from…
You were talking from OBIS code 0.0.99.98.1.0.255 and now 0.0.99.98.1.255. Check that the OBIS code you are trying to read is correct.
rajeshvarma680
2 years ago
Sir, It was my mistake while…
Sir,
It was my mistake while writing .
It was obis code 0.0.99.98.1.255 and reading through guruxdirectors all data is coming.
but when firing command
Gurux.DLMS.Client.Example.Net.exe -S COM16 -c 32 -s 1 -a Low -P xxxxx -C Encryption -V Suite0 -v 0.0.43.1.2.255 -T xxxxxxxxxxxxxxxx -T xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx -A xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx -B xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx -D 30303030303030303030303030303030 -d India
we are getting complete association but for below obis we get
Entries: 0/0
Entries: 0/0
Entries: 0/0
Entries: 0/0
Entries: 0/0
Entries: 0/0
Entries: 0/0
2 years ago
Hi, The meter returns that…
The meter returns that there are no entries. This means that the buffer is empty.
Check if 0.0.99.98.1.0.255 is implemented to the meter with GXDLMSDirector.
rajeshvarma680
2 years ago
Sir, When download the…
Sir,
When download the association through gurux director ,for 0.0.99.98.1.255 the radio button on "Read last" so no data in record showing. To change radio button from readlast to "All" then data downloaded.
The same thing happen when we download through command line it show no entry. How to make default read is All
