  3. Not Able To Read Rows By Range
Not able to read rows by range
By ParthDesai , 23 July, 2024
I am not able to read rows by range using C.
int ret;
unsigned char logical_name[6];
gxtime startTime;
gxtime endTime;
gxProfileGeneric bufferDataByDateTimeRange;
time_init3(&startTime, 2024, 07, 23, 19, 0, 0, 0);
time_init3(&endTime, 2024, 07, 23, 19, 30, 0, 0);
ret = com_open(connection, port);
printf("Error (If Any): %s\n", hlp_getErrorMessage(ret));
ret = com_initializeConnection(connection);
hlp_setLogicalName(logical_name, "1.0.99.1.0.255");
cosem_init2((gxObject*)&bufferDataByDateTimeRange, DLMS_OBJECT_TYPE_PROFILE_GENERIC, logical_name);
ret = com_read(connection, (gxObject*)&bufferDataByDateTimeRange, 3);
ret = com_getAssociationView(connection, outputFile);
ret = com_readRowsByRange(connection, &bufferDataByDateTimeRange, &startTime.value, &endTime.value);
printf("ReadRowsByRange: %d\n", ret);
com_close(connection);
con_close(connection);
root@SP1002:~/GuruxDLMS.c-master/GuruxDLMSClientExample/bin# sudo ./gurux.dlms.client.bin -S /dev/ttyO5 -c 32 -s 1 -a Low -P lnt1 -t Verbose -g "1.0.99.1.0.255:2"
Error (If Any): OK
InitializeConnection
TX: 7E A0 07 03 41 93 5A 64 7E
RX: 7E A0 1E 41 03 73 8E 7F 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 7E A0 40 03 41 10 5F 93 E6 E6 00 60 32 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 06 80 04 6C 6E 74 31 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 1D FF FF 1B E5 7E
RX: 7E A0 37 41 03 30 21 79 E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 1C 04 00 00 07 06 94 7E
Error (If Any): OK
TX: 7E A0 19 03 41 32 3A BD E6 E6 00 C0 01 C1 00 07 01 00 63 01 00 FF 03 00 8C 90 7E
RX: 7E A8 89 41 03 52 CB AC E6 E7 00 C4 01 C1 00 01 13 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0E 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 20 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 34 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 48 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 10 1D 7E C2 7E
TX: 7E A0 07 03 41 51 44 81 7E
RX: 7E A8 89 41 03 54 FD C9 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 05 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 06 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 07 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 08 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 09 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 0A 1D 00 FF 9A DA 7E
TX: 7E A0 07 03 41 71 46 A0 7E
RX: 7E A0 68 41 03 56 FE 18 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 1F 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 33 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 47 1B 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 5E 5B 01 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 5E 5B 02 FF 0F 02 12 00 00 3A 3F 7E
Error (If Any): OK
TX: 7E A0 4C 03 41 94 47 C6 E6 E6 00 C0 01 C1 00 07 01 00 63 01 00 FF 02 01 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E8 07 15 07 00 00 00 00 00 00 00 09 0C 07 E8 07 15 07 0A 27 24 00 00 00 00 01 00 A9 5F 7E
ReadObject failed Data receive failed.
Error (If Any): Data receive failed.
ReadRowsByRange: 253
TX: 7E A0 11 03 41 B6 CE 9A E6 E6 00 62 03 80 01 00 BD 9B 7E
RX: 7E A0 07 41 03 51 5C 47 7E
TX: 7E A0 07 03 41 53 56 A2 7E
2 years 1 month ago
Hi, Check what time zone…
Check what time zone your meter is using. Some meters expect that the time zone is the same when readRowsByRange is used.
Try to read the meter with GXDLMSDirector first. Some meters don't implement read-by range at all.
