  2. Error Is Coming When Reading In MR Mode
Error is coming when reading in MR mode
By satishjyoti1998 , 12 July, 2024
Please help for below error while reading in MR Mode.
cl = GXDLMSSecureClient()
cl.useLogicalNameReferencing = True
cl.InterfaceType = InterfaceType.HDLC
cl.authentication = Authentication.LOW
cl.clientAddress = 32
cl.serverAddress =1
cl.ciphering.Security = Security.ENCRYPTION
cl.ciphering.SystemTitle = GXCommon.hexToBytes("HEX form")
cl.ciphering.BlockCipherKey = GXCommon.hexToBytes("Hex form")
cl.ciphering.AuthenticationKey = GXCommon.hexToBytes("Hex Form")
cl.password = GXCommon.hexToBytes("Hex Form")
Authentication: 1
ClientAddress: 0x20
TX: 12:37:01 7E A0 07 03 41 93 5A 64 7E
RX: 12:37:01 7E A0 20 41 03 73 3E 9D 81 80 14 05 02 03 40 06 02 03 40 07 04 00 00 00 01 08 04 00 00 00 01 B7 29 7E
TX: 12:37:01 7E A0 44 03 41 10 B3 E1 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 49 53 4B 5F 53 45 43 31 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF 2D B4 7E
RX: 12:37:02 7E A0 2D 41 03 30 2E 66 E6 E7 00 61 1F A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 BE 06 04 04 0E 01 06 02 00 6D 7E
File "C:\Users\s_paliwal\AppData\Local\Programs\Python\Python311\Lib\site-packages\gurux_dlms\_GXAPDU.py", line 819, in parsePDU2
_GXAPDU.parseUserInformation(settings, cipher, buff, xml)
File "C:\Users\s_paliwal\AppData\Local\Programs\Python\Python311\Lib\site-packages\gurux_dlms\_GXAPDU.py", line 330, in parseUserInformation
_GXAPDU.parseInitiate(False, settings, cipher, data, xml)
File "C:\Users\s_paliwal\AppData\Local\Programs\Python\Python311\Lib\site-packages\gurux_dlms\_GXAPDU.py", line 557, in parseInitiate
_GXAPDU.parse(initiateRequest, settings, cipher, data, xml, tag)
File "C:\Users\s_paliwal\AppData\Local\Programs\Python\Python311\Lib\site-packages\gurux_dlms\_GXAPDU.py", line 404, in parse
raise GXDLMSConfirmedServiceError(ConfirmedServiceError(data.getUInt8()), ServiceError(data.getUInt8()), data.getUInt8())
gurux_dlms.GXDLMSConfirmedServiceError.GXDLMSConfirmedServiceError: ServiceError Initiate Error exception. Initiate 2
During handling of the above exception, another exception occurred:
File "C:\Users\s_paliwal\AppData\Local\Programs\Python\Python311\Final_08072024.py", line 132, in <module>
cl.parseAareResponse(reply.data)
File "C:\Users\s_paliwal\AppData\Local\Programs\Python\Python311\Lib\site-packages\gurux_dlms\GXDLMSClient.py", line 581, in parseAareResponse
self.isAuthenticationRequired = _GXAPDU.parsePDU(self.settings, self.settings.cipher, reply, None) == SourceDiagnostic.AUTHENTICATION_REQUIRED
File "C:\Users\s_paliwal\AppData\Local\Programs\Python\Python311\Lib\site-packages\gurux_dlms\_GXAPDU.py", line 655, in parsePDU
ret = _GXAPDU.parsePDU2(settings, cipher, buff, xml)
File "C:\Users\s_paliwal\AppData\Local\Programs\Python\Python311\Lib\site-packages\gurux_dlms\_GXAPDU.py", line 826, in parsePDU2
raise GXDLMSException(resultComponent, resultDiagnosticValue)
gurux_dlms.GXDLMSException.GXDLMSException: Connection is permanently rejected
No reason is given.
1 year 11 months ago
Hi, I believe that your…
I believe that your meter expects that general protection is used.
Try to add this line:
cl.proposedConformance |= Conformance.GENERAL_PROTECTION
satishjyoti1998
Hi Mikko, I did what you…
I did what you suggested but still error is coming see below code (settings to read meter in MR mode) and error:
cl.serverAddress =1
cl.Password = "ISK_SEC1".encode()
cl.ciphering.SystemTitle = GXByteBuffer.hexToBytes("49534B3030303031")
cl.ciphering.AuthenticationKey = GXByteBuffer.hexToBytes("000102030405060708090A0B0C0D0E0F")
cl.ciphering.BlockCipherKey = GXByteBuffer.hexToBytes("000102030405060708090A0B0C0D0E0F")
GXDLMSObject.validateLogicalName("0.0.43.1.2.255")
cl.proposedConformance = Conformance.GENERAL_PROTECTION
Authentication: 0
ClientAddress: 0x10
TX: 17:46:13 7E A0 07 03 21 93 0F 01 7E
RX: 17:46:13 7E A0 20 21 03 73 73 98 81 80 14 05 02 03 40 06 02 03 40 07 04 00 00 00 01 08 04 00 00 00 01 B7 29 7E
TX: 17:46:13 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF B3 E2 7E
RX: 17:46:14 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 03 40 00 07 D1 F0 7E
TX: 17:46:14 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 01 00 00 60 01 00 FF 02 00 89 A0 7E
RX: 17:46:14 7E A0 1B 21 03 52 1F 24 E6 E7 00 C4 01 C1 00 0A 09 55 53 30 30 30 30 30 33 32 3A 10 7E
Meter Sr. No is: US0000032
TX: 17:46:14 7E A0 19 03 21 54 5F DE E6 E6 00 C0 01 C1 00 01 00 00 2B 01 02 FF 02 00 0B B6 7E
RX: 17:46:14 7E A0 15 21 03 74 69 CE E6 E7 00 C4 01 C1 00 06 00 00 04 C1 98 A8 7E
Invovation counter Value is: 1217
TX: 17:46:14 7E A0 07 03 21 53 03 C7 7E
RX: 17:46:14 7E A0 20 21 03 73 73 98 81 80 14 05 02 03 40 06 02 03 40 07 04 00 00 00 01 08 04 00 00 00 01 B7 29 7E
Authentication: 1
ClientAddress: 0x20
TX: 17:46:16 7E A0 07 03 41 93 5A 64 7E
RX: 17:46:17 7E A0 20 41 03 73 3E 9D 81 80 14 05 02 03 40 06 02 03 40 07 04 00 00 00 01 08 04 00 00 00 01 B7 29 7E
TX: 17:46:17 7E A0 3C 03 41 10 2E 5E E6 E6 00 60 2E A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 02 80 00 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 00 00 03 40 BC 72 7E
RX: 17:46:17 7E A0 2D 41 03 30 2E 66 E6 E7 00 61 1F A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 BE 06 04 04 0E 01 03 00 AA 30 7E
gurux_dlms.GXDLMSConfirmedServiceError.GXDLMSConfirmedServiceError: ServiceError Initiate Error exception. Service 0
File "C:\Users\s_paliwal\AppData\Local\Programs\Python\Python311\Final_08072024.py", line 191, in <module>
readdataMR()
File "C:\Users\s_paliwal\AppData\Local\Programs\Python\Python311\Final_08072024.py", line 140, in readdataMR
No reason is given.
satishjyoti1998
Sorry, I did this but still…
Sorry, I did this but still error is coming.
settings.client.proposedConformance |= Conformance.GENERAL_PROTECTION
Hi, You need to add the…
You need to add the proposed conformance like this:
cl.proposedConformance = cl.proposedConformance | Conformance.GENERAL_PROTECTION
satishjyoti1998
I did what you suggested but still error is coming. Please find below my settings for client please check and suggest where I am doing mistakes.
client = GXDLMSSecureClient(useLogicalNameReferencing = True,clientAddress = 32, serverAddress = 1, forAuthentication = Authentication.LOW, password = bytes("ISK_SEC1",'utf-8'), interfaceType = InterfaceType.HDLC)
client.proposedConformance = client.proposedConformance | Conformance.GENERAL_PROTECTION
client.invocationCounter = "0.0.43.1.2.255"
client.ciphering.Security = Security.ENCRYPTION
client.SystemTitle = bytes("ISK00001".encode('utf-8'))
client.ciphering.authenticationKey = bytes.fromhex("000102030405060708090A0B0C0D0E0F")
client.ciphering.blockCipherKey = bytes.fromhex("000102030405060708090A0B0C0D0E0F")
media = GXSerial(port="COM5")
media.baudRate = 9600
media.open()
reader = GXDLMSReader(client = client , media = media , trace = 0x8, invocationCounter = 0)
Authentication: 1
ClientAddress: 0x20
Standard: 0
TX: 19:43:53 7E A0 07 03 41 93 5A 64 7E
RX: 19:43:53 7E A0 20 41 03 73 3E 9D 81 80 14 05 02 03 40 06 02 03 40 07 04 00 00 00 01 08 04 00 00 00 01 B7 29 7E
TX: 19:43:53 7E A0 44 03 41 10 B3 E1 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 49 53 4B 5F 53 45 43 31 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 5D FF FF 0F 75 7E
RX: 19:43:53 7E A0 2D 41 03 30 2E 66 E6 E7 00 61 1F A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 BE 06 04 04 0E 01 06 02 00 6D 7E
File "C:\Users\s_paliwal\AppData\Local\Programs\Python\Python311\Final_08072024.py", line 106, in <module>
reader.initializeConnection() # First command start from here
File "C:\Users\s_paliwal\AppData\Local\Programs\Python\Python311\GXDLMSReader.py", line 312, in initializeConnection
self.client.parseAareResponse(reply.data)
No reason is given.
Hi, Your connection is not…
Your connection is not secured. Change this line:
to:
client.ciphering.security = Security.ENCRYPTION
satishjyoti1998
Hi Kurumi, I already change…
Hi Kurumi,
I already change it to client.ciphering.security = Security.ENCRYPTION
but still same error is coming. Please help me to resole the issue.
Regards
Satish
satishjyoti1998
Hi Mikko, Now this issue has…
Now this issue has been resolved.
