By scratch_nk , 26 June, 2024 Forums Gurux.DLMS Can we use GXDLMSCredit object updateAmount(), setAmountToValue() to add credit to meter? I'm using python, HLS Authentication successful, etc. Hi, If you can establish the… Hi, If you can establish the connection to the meter you can use updateAmount and setAmountToValue. BR, Mikko Thanks for the confirmation… Thanks for the confirmation. It wasn't working for me, will check again. Hi, Check your access rights… Hi, Check your access rights for the credit object with GXDLMSDirector. BR, Mikko
