  2. PUSH Related Information
PUSH related information
By shagufta, 19 June, 2024
Can we push the code through optical port ?
How to setup push without authentication?
10 months 3 weeks ago
Hi, That depends on the…
That depends on the meter and how it's configured. You need to check this from the meter documentation.
There is usually a P1 serial port where push messages are sent.
  • Fri, 05/09/2025 - 13:03
    Gurux.DLMS.Python 1.0.181
  • Wed, 05/07/2025 - 16:09
    Gurux.DLMS.Android 2.0.14
  • Tue, 05/06/2025 - 09:34
    gurux.dlms.c 9.0.2505.0601
  • Tue, 05/06/2025 - 08:51
    GXDLMSDirector 9.0.2505.0601
  • Tue, 05/06/2025 - 08:26
    gurux.dlms.java 4.0.79
  • I LOST MY CRYPTO, HOW DO I RECOVER IT? iFORCE HACKER RECOVERY
  • GXNet python implementation hangs on close
  • Conexión Landis ZMG310 Protocolo IEC
  • I need function of below OBIS code
  • How communicating with meter using proparatory command
