  2. Lzqj With Rs232 Serial
lzqj with rs232 serial
By igotar , 12 June, 2024
Hi, please, can anyone help me query the 1.8.0 register directly via the serial cable of my PC, this counter? I use a program directly in VBnet opened on COM3. Thanks
2 years 1 month ago
Hi, Try to connect first…
Try to connect first with GXDLMSDirector. Select "EMH Metering" as a manufacturer and select the correct serial port.
You can see the correct parameters when you connect with GXDLMSDirector.
Try to change the baud rate If the meter doesn't reply.
igotar
2 years 1 month ago
Thank you
Thank you
igotar
2 years 1 month ago
I can't communicate via…
I can't communicate via serial port.help
igotar
2 years 1 month ago
setting
setting
2 years 1 month ago
Hi, I believe that the…
I believe that the reason is baud rate. It' something else than 9600. Our customers are usually reading EMH with TCP/IP and I can't remember the EMH default baud rate at the moment, but try e.g. 4800.
