  3. Destination Addresses Do Not Match. It Is 17. It Should Be 16.
Destination addresses do not match. It is 17. It should be 16.
By muhammad ahmed , 24 May, 2024
i am receiving this response while reading meter using tcp/ip:Error reading DLMS packet: Destination addresses do not match. It is 17. It should be 16.
def handle_client(client_socket):
client = GXDLMSClient(True, 16, 1, Authentication.NONE, '', InterfaceType.WRAPPER)
try:
# Send SNRM request
print("Sending SNRM request...")
reply = GXReplyData()
data = client.snrmRequest()
if data:
client_socket.sendall(data)
time.sleep(1)
response = client_socket.recv(2048)
if not response:
print("No UA response received.")
return
print(f"Raw UA response: {response.hex()}")
ua_response = read_dlms_packet(client, response)
client.parseUAResponse(ua_response.data)
size = client.limits.maxInfoTX + 40
replyBuff = bytearray(size)
_________________________________
Server listening on port 9090
Connection from ('116.71.173.42', 35904)
Sending AARQ request...
Sending request and waiting for response...
Raw response: 0001000100110012dd1030303030303032383938303030303138
Reading DLMS packet...
No AARE response received.
2 years 5 months ago
Hi, You have tried to…
You have tried to connect without an authentication level where the client address is 16. The meter sends a reply where the client's address is 17. Check if you should connect with client address 17 from the meter documentation.
