  3. LANDIS E650 METER RS485 COMMUNICATION ISSUE
By Arunkumaran1 , 15 May, 2024
We urgently require your support for the subject case. Here are details. We have installed 4nos. of E650 meter equipped with E65 CU-XE communication modules in a 12kV VCB Panel where the RS485 connection doesnt establish with your DLMS test software. Please let me know what are points to be noted.
2 years 4 months ago
Hi, At first, check your CU…
At first, check your CU-XE settings. There are several settings with CU-XE that must be correct. Then check if you can read your meter with CU-XE client. In that way, you can verify that your connection can be established.
I believe that your server address is different from what is configured for the meter.
