  2. SHA256 Does Not Count Correctly In ANSI C
SHA256 does not count correctly in ANSI C
By labasvakaras , 1 February, 2024
did some more investigation:
HEX bytes that needs to be converted to SHA256: 47 75 72 75 78 41 42 43 44 45 46 47 48 38 06 6D 79 07 09 1D 49 26 60 59 79 68 3E 0D 5F 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22
gxsha256_encrypt returns: E5 36 DE FB B3 1B 6D 14 9D 80 F0 23 E8 C0 50 BA 85 83 77 A7 AF EF D0 7F 00 12 01 75 30 B4 A4 B8
If i use the same hex bytes with other calculators I get:
c93338aa6d325e19efd1d5a7e067dd252c8fb193ecc2091103596b0b5fc71876
Also, Java server returns:
INFO: Invalid CtoS:C93338AA6D325E19EFD1D5A7E067DD252C8FB193ECC2091103596B0B5FC71876-E536DEFBB31B6D149D80F023E8C050BA858377A7AFEFD07F0012017530B4A4B8
Client Disconnected.
This confirms, that SHA256 is not calculated correctly in Ansi C DLMS library.
labasvakaras
2 years 4 months ago
Also, i can reproduce this…
Also, i can reproduce this on C++:
./bin/gurux.dlms.client.bin -h localhost -p 4061 -P Gurux -c 22 -a HighSha256 -t Verbose
InitializeConnection
TX: 11:46:26 7E A0 07 03 2D 93 AF A8 7E
RX: 11:46:26 7E A0 1E 2D 03 73 60 DF 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 11:46:26 7E A0 4C 03 2D 10 9E C8 E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 06 AC 12 80 10 67 C6 69 73 51 FF 4A EC 29 CD BA AB F2 FB E3 46 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF BA 72 7E
RX: 11:46:26 7E A0 70 2D 03 30 59 98 E6 E7 00 61 62 A1 09 06 07 60 85 74 05 08 01 01 A6 0A 04 08 41 42 43 44 45 46 47 48 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 41 42 43 44 45 46 47 48 88 02 07 80 89 07 60 85 74 05 08 02 06 AA 12 80 10 51 10 3F 56 51 10 79 75 44 2E 49 54 69 2D 74 1A BE 10 04 0E 08 00 06 5F 1F 04 00 00 1E 5D 04 00 00 07 29 78 7E
TX: 11:46:26 7E A0 3B 03 2D 32 EA C7 E6 E6 00 C3 01 81 00 0F 00 00 28 00 00 FF 01 01 09 20 B2 AB 08 08 BF AB 37 16 08 82 52 79 EF 11 51 FE B5 6B 37 54 14 33 AB FA 88 E3 54 4F 19 8E A8 0E 80 D3 7E
RX: 11:46:26 7E A0 11 2D 03 52 12 5D E6 E7 00 C7 01 81 03 00 E2 98 7E
Authentication failed (3) Access Error : Device reports Read-Write denied.
TX: 11:46:26 7E A0 07 03 2D 53 A3 6E 7E
Hi, This is under work. I'll…
This is under work. I'll let you know as soon as this is fixed.
labasvakaras
Also, SHA1 not working…
Also, SHA1 not working correctly. Looked into it and got it working by doing this:
(bb_attach sets capacity 0x80000... and then getUint returns OUT OF MEMORY)
Index: libdlms-fa855d2e/development/src/client.c
--- libdlms-fa855d2e.orig/development/src/client.c
+++ libdlms-fa855d2e/development/src/client.c
@@ -410,7 +410,7 @@ int cl_getApplicationAssociationRequest(
message* messages)
int ret;
- gxByteBuffer challenge;
+ gxByteBuffer challenge = { 0 };
gxByteBuffer* pw;
dlmsVARIANT data;
#ifndef DLMS_IGNORE_HIGH_GMAC
@@ -423,7 +423,6 @@ int cl_getApplicationAssociationRequest(
#else
static unsigned char APPLICATION_ASSOCIATION_REQUEST[32];
#endif //DLMS_IGNORE_HIGH_GMAC
- bb_attach(&challenge, APPLICATION_ASSOCIATION_REQUEST, 0, sizeof(APPLICATION_ASSOCIATION_REQUEST));
if (settings->authentication != DLMS_AUTHENTICATION_HIGH_ECDSA &&
settings->authentication != DLMS_AUTHENTICATION_HIGH_GMAC &&
@@ -482,7 +481,6 @@ int cl_getApplicationAssociationRequest(
#ifndef DLMS_IGNORE_MALLOC
- var_clear(&data);
bb_clear(&challenge);
#endif //DLMS_IGNORE_MALLOC
labasvakaras
hello, wanted to ask maybe…
hello, wanted to ask for a feedback, maybe there is some success finding bug here?
Hello, Yes, we are working…
Yes, we are working on it. I can't say when the fix is released.
labasvakaras
2 years 3 months ago
Hello, wanted to ask for a…
Hello, wanted to ask for a feedback.
Also i've tested gurux dlms C server and GMAC security not working! (it works fine with Java server)
Hi, Are you using the same…
Are you using the same block cipher and authentication keys? I just checked GMAC and it works without problems. What compiler you are using?
labasvakaras
Launched gurux dlms server: …
./bin/gurux.dlms.server.bin
TCP/IP server started in port: 4061
Authentication levels:
None: Client address 16 (0x10)
Low: Client address 17 (0x11)
High: Client address 18 (0x12)
HighGMac: Client address 1 (1)
gurux dlms client:
./bin/gurux.dlms.client.bin -c 1 -p 4061 -h localhost -a HighGmac -D 00112233445566778899AABBCCDDEEFF -T 4775727578313233 -B 000102030405060708090A0B0C0D0E0F
Connecting to localhost:4061
AARQRequest failed DecipheringError
DecipheringError
Hi, CMAC example uses a…
CMAC example uses a secured connection. You need to add arguments.
-C AuthenticationEncryption -v 0.0.43.1.0.255
labasvakaras
Thank you, now GMac works…
This worked perfectly, but wanted to ask: why i can connect to java server without these options?
Hi, Because the Java example…
Because the Java example doesn't use the encrypted connection with GMAC. There are multiple parameters and if one is different than the meter expects the connection fails. The amount of error codes in DLMS is very limited and it's always hard to say what is the reason.
labasvakaras
2 years 2 months ago
Hello, added crypto.h and…
Hello, added crypto.h and calculated correct hash, but there are other problems which do not let me authenticate connection.
Maybe there are any news about sha256 fix?
Hi, This is fixed and under…
This is fixed and under testing.
labasvakaras
Hello, how testing is going?
labasvakaras
2 years ago
2 years ago
Hi, This is fixed for the…
This is fixed for the version 20240529.1.
labasvakaras
2 years ago
Using C client with Java…
Using C client with Java server:
[Debug ] TX: 7E A0 07 03 2D 93 AF A8 7E
[Debug ] RX: 7E A0 1E 2D 03 73 60 DF 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
[Debug ] TX: 7E A0 4C 03 2D 10 9E C8 E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 06 AC 12 80 10 91 C8 E4 72 39 1C 8E 47 A3 D1 E8 74 BA DD 6E 37 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 1D FF FF 41 93 7E
[Debug ] RX: 7E A0 70 2D 03 30 59 98 E6 E7 00 61 62 A1 09 06 07 60 85 74 05 08 01 01 A6 0A 04 08 41 42 43 44 45 46 47 48 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 41 42 43 44 45 46 47 48 88 02 07 80 89 07 60 85 74 05 08 02 06 AA 12 80 10 43 07 56 19 58 4C 69 0A 59 09 77 47 3A 61 5B 33 BE 10 04 0E 08 00 06 5F 1F 04 00 40 1E 1D 04 00 00 07 C4 AA 7E
I am getting error from cl_getApplicationAssociationRequest: Invalid parameter.
2 years ago
Hi, I believe that your…
I believe that your password is empty.
labasvakaras
2 years ago
Sorry, yes, that was the…
Sorry, yes, that was the problem. But i still have a question: no matter what i try to read, i am getting read-write denied. Is this intended with Java server?
[Debug ] RX: 7E A0 70 2D 03 30 59 98 E6 E7 00 61 62 A1 09 06 07 60 85 74 05 08 01 01 A6 0A 04 08 41 42 43 44 45 46 47 48 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 41 42 43 44 45 46 47 48 88 02 07 80 89 07 60 85 74 05 08 02 06 AA 12 80 10 5F 4D 17 27 5A 0A 23 06 69 22 25 50 25 41 42 1B BE 10 04 0E 08 00 06 5F 1F 04 00 40 1E 1D 04 00 00 07 DF 81 7E
[Debug ] TX: 7E A0 3B 03 2D 32 EA C7 E6 E6 00 C3 01 C1 00 0F 00 00 28 00 00 FF 01 01 09 20 2F A5 A8 B1 AB DC 6C 3F 0F 9B A9 8C A8 56 E6 F2 CF A4 93 FA 80 2E B8 2D F9 A1 1D 73 AE 41 DF 13 47 E5 7E
[Debug ] RX: 7E A0 11 2D 03 52 12 5D E6 E7 00 C7 01 C1 03 00 94 9E 7E
labasvakaras
2 years ago
Looked into Java server logs…
Looked into Java server logs and i am getting:
CtoS:947DAA9F966A2CA4F71B53BA30E2711C0B4513C0F6E57CCD6C8FA513CD4DBC9F-E2AC2AC6344947E3B3580FFCDF4601F7BBDE6649EB62750834CAAB7AA384FB50
2 years ago
Hi, Your client address is…
Your client address is 16 and it Java server uses 22.
Your client and server must use the same password. In default it's Gurux.
labasvakaras
2 years ago
I am using correct password …
I am using correct password (Gurux) and I am using 22 client address. You can see that in provided logs (first TX).
2 years ago
Hi, From the latest log you…
From the latest log you added, I can see that you tried connecting with client address 16 and not 22. I can't see what password you used.
You can try this with ANSI C client example with arguments:
-h localhost -p 4061 -c 22 -a HighSHA256 -P Gurux -T 4775727578313233 -t Verbose
labasvakaras
2 years ago
I am getting the same error…
I am getting the same error with latest C server. Do i need to use new java server?
./bin/gurux.dlms.client.bin -h localhost -p 4061 -c 22 -a HighSHA256 -P Gurux -T 4775727578313233 -t Verbose
TX: 7E A0 4C 03 2D 10 9E C8 E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 06 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 1D FF FF 31 4A 7E
RX: 7E A0 70 2D 03 30 59 98 E6 E7 00 61 62 A1 09 06 07 60 85 74 05 08 01 01 A6 0A 04 08 41 42 43 44 45 46 47 48 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 41 42 43 44 45 46 47 48 88 02 07 80 89 07 60 85 74 05 08 02 06 AA 12 80 10 5C 26 6E 39 25 45 6C 05 2A 51 51 56 54 64 55 2B BE 10 04 0E 08 00 06 5F 1F 04 00 40 1E 1D 04 00 00 07 D3 39 7E
TX: 7E A0 3B 03 2D 32 EA C7 E6 E6 00 C3 01 C1 00 0F 00 00 28 00 00 FF 01 01 09 20 02 36 27 32 75 27 9E 4C DF 9D C3 AA 75 BF E5 00 B4 32 6A 13 FD 7E EB 3C 5E 43 BB C0 BD 4D 08 00 C3 8A 7E
TX: 7E A0 07 03 2D 53 A3 6E 7E
2 years ago
Hi, Get the latest version…
Get the latest version from ANSI C. You can now connect to Java server.
High SHA256 is not implemented for the ANSI C server example. You can modify it for your needs and add SHA256 support.
labasvakaras
2 years ago
I know, that ansi C server…
I know, that ansi C server does not have sha256. I am using Java server and ANSI C client.
Sorry, but i am still unable to read data from Java server. Also, ANSI C server does not compile. Fixed it with changing:
unsigned char svr_isTarget(
dlmsSettings* settings,
unsigned long serverAddress,
unsigned long clientAddress)
to:
uint32_t serverAddress,
uint32_t clientAddress)
Ansi C client:
RX: 7E A0 70 2D 03 30 59 98 E6 E7 00 61 62 A1 09 06 07 60 85 74 05 08 01 01 A6 0A 04 08 41 42 43 44 45 46 47 48 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 41 42 43 44 45 46 47 48 88 02 07 80 89 07 60 85 74 05 08 02 06 AA 12 80 10 4D 38 00 65 36 71 77 13 24 76 10 37 60 46 3C 17 BE 10 04 0E 08 00 06 5F 1F 04 00 40 1E 1D 04 00 00 07 C0 87 7E
TX: 7E A0 3B 03 2D 32 EA C7 E6 E6 00 C3 01 C1 00 0F 00 00 28 00 00 FF 01 01 09 20 3C C8 7D EE 79 42 1D FB 11 C5 7E 90 92 56 C9 EB 5C FC 81 64 DF 89 63 55 2E D6 0A 1B A1 72 4C 4B A3 D5 7E
Java Server:
java -jar ./target/gurux.dlms.server.example.java-0.0.1-SNAPSHOT.jar
System Title: 41 42 43 44 45 46 47 48
Authentication key: D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF
Block cipher key: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
Client System title:
Master key (KEK) title:
Short Name DLMS Server in port 4060
Example connection settings:
Gurux.DLMS.Client.Example.Net -r sn -h localhost -p 4060
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<GfG1
Logical Name DLMS Server in port 4061
Gurux.DLMS.Client.Example.Net -h=localhost -p 4061
Short Name DLMS Server with IEC 62056-47 in port 4062
Gurux.DLMS.Client.Example.Net -r sn -h localhost -w -p 4062
Logical Name DLMS Server with IEC 62056-47 in port 4063
Gurux.DLMS.Client.Example.Net -h localhost -w -p 4063
Press Enter to close.
Client Connected.
Jun 07, 2024 3:01:48 PM gurux.dlms.objects.GXDLMSAssociationLogicalName replyToHlsAuthentication
INFO: Invalid CtoS:DA29DB55A200450614F071E060FBCF1543619F1A508DEEA3BE341FF31AB46243-3CC87DEE79421DFB11C57E909256C9EB5CFC8164DF8963552ED60A1BA1724C4B
2 years ago
Hi, Can you run gcc -…
Can you run gcc --version and add output here?
Did you build the library in the development folder and then rebuild the client?
labasvakaras
2 years ago
gcc --version gcc (Ubuntu 9…
gcc --version
gcc (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
Copyright (C) 2019 Free Software Foundation, Inc.
Yes, i build the development first and rebuild client.
labasvakaras
1 year 11 months ago
Thank you, everything is…
Thank you, everything is working now!
