  3. System.InvalidCastException: 'Unable To Cast Object of Type 'Gurux.DLMS.Objects.GXDLMSActivityCalendar' To Type 'System.Object[]'.'
System.InvalidCastException: 'Unable to cast object of type 'Gurux.DLMS.Objects.GXDLMSActivityCalendar' to type 'System.Object[]'.'
By Rahuls , 9 May, 2024
Gurux.Net
Getting this error as I try to set activvity calender
object GetActivityWrite(){
GXDLMSActivityCalendar activity = new GXDLMSActivityCalendar();
activity.CalendarNamePassive = "Passive";
activity.DayProfileTablePassive = new GXDLMSDayProfile[] { new GXDLMSDayProfile(1, new GXDLMSDayProfileAction[] { new GXDLMSDayProfileAction(new GXTime(DateTime.Now), "0.0.10.0.100.255", 1) }) };
return activity;
object tempObj = GetActivityWrite();
ReadDataBlock(Client.Write(writeObj.Name, tempObj, dt, objectType, attributeIndex), reply);
trying to test the library, and i am getting error. It is reading smoothly, only error on this part, tried passed date in different formats, nothing works
Rahuls
2 years 4 months ago
Hi Mikko, Any update? thanks.
Any update?
thanks.
Hi, Try like this: object…
Try like this:
ReadDataBlock(Client.Write(tempObj, 9), reply);
Rahuls
Thanks Mikko, I was able to…
Thanks Mikko, I was able to write it to passive.
As of now i did manually activate from GURUX director, how can i activate it from code library?
Hi, You can activate it by…
You can activate it by calling the ActivatePassiveCalendar method. Like this:
ReadDataBlock(tempObj.ActivatePassiveCalendar(Client), reply);
