  3. Issue With Executable Generation Using PyInstaller.
Issue with Executable Generation using PyInstaller.
By Ali_nk , 3 May, 2024
I generated the main.py executable file using Gurux.DLMS.Client.Example.python\main.py,
and it's working fine in VS Code.
However, after generating the executable using PyInstaller, I encountered this error when running the executable:
Error:
File "Gurux.DLMS.Client.Example.python\main.py", line 13, in <module>
ModuleNotFoundError: No module named 'GXSettings'
[14452] Failed to execute script 'main' due to an unhandled exception!
My Python version is Python 3.12.3.
2 years 4 months ago
Hi, It seems like GXSettings…
It seems like GXSettings.py is not included in the installation package. Check your arguments.
Ali_nk
Hi, Thank you for your…
Thank you for your response.
It's an issue with PyInstaller. I used cx_Freeze, and it's working now.
