  3. Reading Server Objects Via SecureClient Without Preread of Objects Tree
Reading server objects via SecureClient without preread of objects tree
By bushidik , 2 May, 2024
Hello!
I use C++ GuruX library and want to know, is there a possibility to read objects directly from Server side using interested obis and method/attribute number?
Best regards
2 years 4 months ago
Hello, Yes, it's possible…
Yes, it's possible. After you have implemented the connection to the meter, you can read the objects you want to read. You can do it like this:
std::string str;
CGXDLMSData data("OBIS_CODE");
int ret = Read(&data, 2, str);
bushidik
int ret = Read(&data, 2, str…
Thank you!
