  3. Receive Hardware Fault
Receive hardware fault
By Suketa , 10 April, 2024
I am using Gurux DLMS library for ANSI C to communicate with meter.
Facing the error as "AARQRequest failed Access Error: Device reports a hardware fault" when try to communicate with meter.
In which case device reports a hardware fault?
Suketa
2 years 5 months ago
In which cases hardware…
In which cases hardware fault error received?
Hi, Please, don't add…
Please, don't add pictures. They are impossible to read.
Can you add a hex log as plain text so I can check this?
Suketa
Hello, Please find attached…
Please find attached logs below,
DLMS Tx Data = 00 01 00 30 00 01 00 5F 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 48 50 4C 32 30 32 31 37 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 0B 85 C2 E1 F0 F8 7C 3E 9F 4F 27 13 09 84 42 A1 BE 23 04 21 21 1F 30 00 00 00 01 85 2F CA 13 50 A0 7F AA 0A 04 89 BF 81 D9 FD 3C 15 46 12 D1 7D 27 86 FD 87 4E
readDLMSPacket
AARQRequest failed Access Error : Device reports a hardware fault.
[E] 0:08:26.237 21 ../app/dlms_app/src/dlms_client.c:93 :u8Connect: Connection DLMS_FAIL : 1 InitializeConnection
DLMS Tx Data = 00 01 00 30 00 01 00 5F 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 48 50 4C 32 30 32 31 37 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 D0 E8 F4 FA FD 7E BF 5F 2F 17 0B 05 02 01 80 40 BE 23 04 21 21 1F 30 00 00 00 02 29 00 CD 03 BB E8 9E FD 5B A7 2C 01 C7 4F E6 F8 2B 51 AF 4C 5B 52 64 F9 A4 99
readDLMSPacket
Hi, You didn't share the…
You didn't share the meter reply, but I noticed that you are using ciphering. Make sure that your block cipher and authentication keys are the same in both the client and the meter.
Suketa
Hi, Is there any other case…
Is there any other case in which we receive this error?
Due to this error is it any possibility to reboot the device?
Hi, You can try to reboot…
You can try to reboot the meter. This is a generic error and there is no way to say what could be causing this. I suggest you to contact the meter manufacturer and ask if there is a firmware update available for the meter.
