  3. ESP32 Assert In Cl_clear
ESP32 assert in cl_clear
By dvosp , 15 February, 2024
I'm using DLMS.c on an ESP32. I can do register reads without issue, but I get an assert in cl_clear. Below the code
uint16_t srv = cl_getServerAddress(1, 7662, 0);
cl_init(&settings, 1, 1, srv, DLMS_AUTHENTICATION_LOW, "12345678", DLMS_INTERFACE_TYPE_HDLC);
int ret = com_initializeConnection();
if (ret == DLMS_ERROR_CODE_OK)
// read the kWh register
gxRegister reg;
int err;
err = cosem_init(BASE(reg), DLMS_OBJECT_TYPE_REGISTER, "1.0.1.8.0.255");
err = com_read(BASE(reg), 3); // scaler
err = com_read(BASE(reg), 2); // value
ESP_LOGI(TAG, "value %d", reg.value.lVal);
obj_clear(BASE(reg));
#if 1
// profile generic
gxProfileGeneric pg;
err = cosem_init(BASE(pg), DLMS_OBJECT_TYPE_PROFILE_GENERIC, "1.0.99.1.0.255");
com_read(BASE(pg), 3); // capture objects
com_read(BASE(pg), 4); // period
com_read(BASE(pg), 7); // entries in use
gxtime startTime, endTime;
time_initUnix(&startTime, 1707264000);
time_initUnix(&endTime, 1707321600);
err = com_readRowsByRange(&pg, &startTime, &endTime);
if (err == DLMS_ERROR_CODE_OK)
showRows(&pg.buffer);
obj_clear(BASE(pg));
#endif
com_close();
cl_clear(&settings);
If i change the #if 1 to #if 0, commenting out the profile generic read I have no issue. With the code in I get an assert in cl_clear at the following line
bb_clear(&settings->password);
Am I doing the object clearing correctly?
2 years 8 months ago
Hi, At first, try to comment…
At first, try to comment showRows. It might use so much memory that it causes problems.
//showRows(&pg.buffer);
You try to read for four hours at once. Try to read for only one hour. The amount of memory is always a problem when reading DLMS historical data. How many columns there are in this profile generic?
You should also check the error code for each com_read and handle it somehow.
dvosp
Hi, I have already commented…
I have already commented showRows, no effect.
The date range returns 13 rows and there's 8 columns per row.
Free heap before the call is about 230k.
I do error checking, just removed it for clarity.
Changed the date range to return two rows, problem still there.
dvosp
Another thing I would like…
Another thing I would like to mention is that there are a few references to bb_init instead of BYTE_BUFFER_INIT. As I'm using an ESP32 this is a problem and I changed all references to BYTE_BUFFER_INIT.
Hi, bb_init might cause this…
bb_init might cause this.
What compiler are you using?
If it's Arduino, can you select "File" and "Preferences"?
What Additional Boards Manager URLs you are using?
dvosp
Hi Mikko, I'm using esp-idf…
I'm using esp-idf.
I can confirm that settings.password.data is clobbered by the following line
I use the following to print the password before and after the call
ESP_LOGI(TAG, "%s: %s %d %d %d",
prefix,
settings.password.data,
settings.password.capacity,
settings.password.size,
settings.password.position
Before:
PW2: 12345678 9 8 0
after:
PW3: 9 8 0
dvosp
Hi Mikko, I enabled the esp…
I enabled the esp-idf heap trace.
ESP_ERROR_CHECK( heap_trace_start(HEAP_TRACE_LEAKS) );
int err;
time_initUnix(&startTime, 1707296400);
time_initUnix(&endTime, 1707296400 + (3600));
//char *data;
//obj_toString(BASE(pg), &data);
//GXTRACE(GET_STR_FROM_EEPROM("Load profile"), data);
//free(data);
com_close();
ESP_ERROR_CHECK( heap_trace_stop() );
heap_trace_dump();
I commented out the bb_clear(&settings->password); line in cl_clear. The code runs now and does not assert, but as you can see the trace indicates correctly the 9 bytes leaked, No other leaks indicated. When I un-comment the line, the code asserts.
1 allocations trace (1000 entry buffer)
9 bytes (@ 0x3ffbc64c) allocated CPU 0 ccount 0x43073b74 caller 0x400da1e7:0x400da4da
0x400da1e7: bb_allocate at /media/pierre/Portable2/Projects/Modems/ME16-Firmware/ME16-ESP32/GuruxDLMS.c/development/src/bytebuffer.c:275
0x400da4da: bb_set at /media/pierre/Portable2/Projects/Modems/ME16-Firmware/ME16-ESP32/GuruxDLMS.c/development/src/bytebuffer.c:532
9 bytes 'leaked' in trace (1 allocations)
total allocations 267 total frees 266
