  2. CEWE Prometer 100 W With Gurux GXDLMSDirector
CEWE Prometer 100 W with Gurux GXDLMSDirector
By Viet , 12 December, 2023
Hi!
I'm trying to read the CEWE Prometer 100 W with GXDLMSDirector and it always return this message "Failed to receive reply from the device in given time"
I use the Device monitoring studio to capture the READ/WRITE packets in reading time and realise that the source/destination in write packet is not simillar to the packet I captured when I successfully connected to the meter via M-Cubed 100 application.
This is captured packet with GXDLMSDirector:
7E A0 0A 00 02 68 2D 21 93 3F 1D 7E
and this is captured packet with M-Cubed 100:
7E A0 07 03 21 53 03 C7 7E
You can see the source/destination in these packes is difference (00 02 with 03 21)
Please give me an advice.
Thanks in advance!
2 years 7 months ago
Hi, If you don't use a…
If you don't use a serial number as a meter address the settings are then the same.
Change address type back to Default. Then make sure that the physical server address is 1 and connect.
Viet
Hi Mikko, sorry for late…
sorry for late reply.
Maybe there's a confusion here, I used a tool to configure the serial number of meter from "WP023121" to "12345678" and I used this serial number in M-Cubed 100 for successful reading too.
And when I change address type back to "Default", then set the physical address to 1, it still throw "Failed to receive reply from the device in given time".
And I want to read the meter with serial number cause I want to read multiple meters, so I think the serial number is required.
Thanks in advance!
Hi, M-Cubed 100 is using the…
M-Cubed 100 is using the server address that I described in the HDLC message that you share and I get those values from the HDLC message.
Client address is 0x10 and physical address is 1.
Viet
Hi Mikko, thanks for your…
Hi Mikko, thanks for your advice.
I successfully connect/read the meter with these settings (using newest GXDLMSDirector and Gurux.DLMS github version):
Authentication: Low,
Client address: 0x20
Password: ABCD0001
Address Type: Default or Custom
Logical Server: 0
Physical Server: 1
Media: Serial (COM3)
My problem is, I want to read multiple meters, with each meter have an unique serial number. How can I use the serial number for connecting and data reading? or can I read multiple meters using physical number?
Thank you!
Additional information: I still cannot connect to the meter using Gurux.DLMS version 7.0.14.1, GXDLMSDirector (corresponding version) - (debug in visual studio)
2 years 6 months ago
Hi, Is your meter using RS…
Is your meter using RS-485 or RS-232? You can connect multiple meters only for the RS-485 bus.
Some meters use using meter serial number as a meter address. I don't know if CEWE supports that.
You can also set a unique HDLC device address for each meter using IEC HDLC setup object.
https://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSIecHdlcSetup
In that way, each of your meters can have a unique HDLC address.
Viet
Hi Mikko, I am using RS-485…
I am using RS-485.
I will update the newest information about CEWE prometer 100 reading here.
Thank you!
