  3. Can't Change Passive Calendar Name
Can't change passive calendar name
By SmileLime , 5 January, 2024
Hello!
When I change Passive Calendar Name to "Default" I get an Error from the meter.
I noticed that in TX from DLMSDirector name is passed directly without encoding it to Octet String.
08:29:36 Writing object 0.0.13.0.0.255, interface ActivityCalendar
TX: 7E A0 1E 02 21 25 32 3E 8D E6 E6 00 C1 01 C1 00 14 00 00 0D 00 00 FF 06 00 09 02 DE FA EA FA 7E
When I do the same for Week Profile it works fine and week name is encoded
08:32:32 Writing object 0.0.13.0.0.255, interface ActivityCalendar
TX: 7E A0 35 02 21 25 D8 17 E2 E6 E6 00 C1 01 C1 00 14 00 00 0D 00 00 FF 08 00 01 01 02 08 09 07 44 65 66 61 75 6C 74 11 01 11 01 11 01 11 01 11 01 11 01 11 01 15 8B 7E
DLMSDirector version is 9.0.2311.1001. Is it intended?
Thank you in advance!
2 years 10 months ago
Hi, I tested this and it…
I tested this and it worked as expected. I checked your write PDU as data is sent as an octet string. Why do you think that value is not encoded to an octet string?
<SetRequest>
<SetRequestNormal>
<!-- Priority: High, ServiceClass: Confirmed, Invoke ID: 1 -->
<AttributeDescriptor>
<!-- ActivityCalendar -->
<ClassId Value="0014" />
<!-- 0.0.13.0.0.255 -->
<InstanceId Value="00000D0000FF" />
<!-- Passive Calendar Name -->
<AttributeId Value="06" />
</AttributeDescriptor>
<Value>
<OctetString Value="DEFA" />
</Value>
</SetRequestNormal>
</SetRequest>
SmileLime
Below are screenshots where…
Below are screenshots where I highlighted parts that don't match.
In case of Week name Default is passed as a <OctetString Value="44656661756C74" />, while Season name as <OctetString Value="DEFA" />
2 years 9 months ago
Hi, We have tried to repeat…
We have tried to repeat this and it works every time.
I noticed from your last pic that you are comparing two different write.
On the left side, you had written the passive calendar name and on the right side, you had written the week table.
Can you try to set the passive calendar name as the picture below and try to write it?
SmileLime
Hi. I compared to different…
Hi. I compared to different write because a can write Default as a Week Name and can't as a Calendar Name. I think that there should be no difference between them, that's why I am confuesd.
Result of trying to write DEFAULT as a passive calendar name
TX: 7E A0 1E 02 21 25 76 1E 89 E6 E6 00 C1 01 C1 00 14 00 00 0D 00 00 FF 06 00 09 02 DE FA EA FA 7E
RX: 7E A0 11 25 02 21 96 A1 57 E6 E7 00 C5 01 C1 FA 85 D1 7E
Hi, Can you select "Access…
Can you select "Access rights" and take a screenshot from that page?
This is now tested with a few meters and it works without problems.
SmileLime
Here you are
Here you are
