  2. Auto Recovery Times Meter Configuration
By taher_alfalah , 19 December, 2023
Gurux DLMS for Android
Appreciate your support on how to set a meter configuration like "Auto Recovery Time". using Gurux android version. kindly note that i can connect to the meter and read generic profiles, connect and disconnect the relay, but i need a sample code or steps to help configure the meter parameters.
2 years 7 months ago
Hello, What do you mean by…
What do you mean by Auto Recovery Time? What object do you want to use for this?
Do you mean setting the clock every time when you connect to the meter?
taher_alfalah
Hello, i want to set the…
i want to set the meter configuration value Auto Recovery Times of current Over Limit (the OBIS is “0.96:94.96.10.255”) i need to change the value and make it 2
Hi, 0.96:94.96.10.255 is…
0.96:94.96.10.255 is Utility specific objects so it doesn't help. What interface type this is?
taher_alfalah
Hi, I believe my question is…
I believe my question is not clear, so sorry for that.
The object "Auto Recovery Times of current Over Limit" value is the number of times counted when the current value goes beyond the current over limit threshold.
but let me ask the question in another way, how to configure meter parameters in general using it is obis code in the Java sdk?
Thank you,
taher_alfalah
Hi Mikko, Merry Christmas…
Merry Christmas and happy holidays.
Appreciate your support for the previous inquiry.
2 years 6 months ago
Hi, Everything depends on…
Everything depends on the object type, not the OBIS code. You can get a list of objects from here:
https://www.gurux.fi/Gurux.DLMS.Objects
I believe that you need to use a Limiter object for that.
