  3. Empty Array In Structure Is Also Structure
Empty Array in Structure is also Structure
By Xanders08 , 13 December, 2023
Hi!
I have problem, when i need to add empty array in structure.
In c# i use next code:
GXArray array = new GXArray()
new GXStructure()
new GXStructure()
new GXEnum(0),
null
new GXArray()
And after use method Write for GXDLMSClient i have next data:
01 01 02 02 02 02 16 00 00 02 00
My GXArray is GXStructure. Why is it? How to put empty array to request?
I need requset with next data:
01 01 02 02 02 02 16 00 00 01 00
2 years 11 months ago
Hi, I tested this with the C…
I tested this with the C# version and the data is expected.
Have you made any changes to the source code or are you using a different programming language?
  • Victorian | WA 083148835648
