  3. [Gurux DLMS For C] Error In "loadSettings" Function Located In "svr_InitObjects" Function
[Gurux DLMS for C] Error in "loadSettings" function located in "svr_InitObjects" function
By nima_1375 , 28 November, 2023
There is a problem in using "loadSettings" function when I used it twice.
Firstly I call "svr_InitObjects(&Wrapper)" function and initialize two objects ("gxdata" type) and attach a structure to them by using "var_attachStructure" function, after that "loadSettings" function is called and it properly works.
Then I have to call "svr_InitObjects(&iec)" function. But this time, when "loadSettings" function is called, a fault happens and entire app is broken.
I just know this fault happens in "ser_loadObjects" function (which is located in "loadSettings" function).
2 years 11 months ago
Hi, Are you using malloc?…
Are you using malloc? And you have only two data objects? What content you have set for the data objects?
nima_1375
Dear Kurumi Thank you for…
Dear Kurumi
Thank you for your help.
I solved the problem.
  • Toko Bangunan Mahkota Jaya | WA 083148835648
