  3. Reading DLMS Meter Using Python
Reading DLMS meter using Python
By adryan , 14 November, 2023
Hi!
I tried to connect 2 dlms meters using Gurux.DLMS.Python. I can read the first meter but got "Service not allowed. Operation not possible" error message on the second one. Is there anything I could do about it?
Thank you in advance.
python main.py -S COM27:19200:8None1 -c 6 -a HighGMAC -C AuthenticationEncryption -T 4C5945017098FA86 -A 0F8ABAC74A2944A598F109313B1F170E -B 6BB5831C15834C51849CF5083BAFBA0E -v 0.0.43.1.0.255 -w 1 -f 128 -t Verbose
gurux_dlms version: 1.0.146
gurux_net version: 1.0.19
gurux_serial version: 1.0.20
Authentication: 5
ClientAddress: 0x6
Standard: 0
Security: 48
System title: 4C 59 45 01 70 98 FA 86
Authentication key: 0F 8A BA C7 4A 29 44 A5 98 F1 09 31 3B 1F 17 0E
Block cipher key: 6B B5 83 1C 15 83 4C 51 84 9C F5 08 3B AF BA 0E
TX: 15:07:32 7E A0 07 03 21 93 0F 01 7E
RX: 15:07:32 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 15:07:32 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 5D FF FF 91 23 7E
RX: 15:07:33 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 10 02 00 00 07 AC A8 7E
TX: 15:07:33 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 01 00 00 2B 01 00 FF 02 00 7D 8F 7E
RX: 15:07:33 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 C1 00 06 00 00 00 72 E8 48 7E
Invocation counter: 115
TX: 15:07:33 7E A0 07 03 21 53 03 C7 7E
RX: 15:07:33 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 15:07:33 7E A0 07 03 0D 93 9C 8B 7E
RX: 15:07:33 7E A0 1E 0D 03 73 5B DC 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 15:07:33 7E A0 6B 03 0D 10 DF 33 E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 4C 59 45 01 70 98 FA 86 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 63 1F 06 E6 C1 30 DA 17 44 59 04 FD FC 16 AC AF BE 23 04 21 21 1F 30 00 00 00 73 35 F0 BE 51 68 CF F5 6C A2 B2 48 F5 82 07 64 FE 9B E4 D8 9B 3F A6 B5 CC A3 2C 02 33 7E
RX: 15:07:33 7E A0 6F 0D 03 30 3A EA E6 E7 00 61 61 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 4C 59 45 01 70 98 FA 86 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 0A 80 08 33 35 46 37 46 39 46 46 BE 23 04 21 28 1F 30 00 00 00 71 73 B0 5B 5C 80 5C 84 B9 A6 CA 41 A6 62 D0 F3 AE C5 AA FE 7B 52 35 43 8B 7F AF 12 B8 7E
flag here
TX: 15:07:33 7E A0 3F 03 0D 32 35 96 E6 E6 00 CB 31 30 00 00 00 73 F7 F1 7F 51 61 90 EA 40 A2 F2 A9 A9 81 0E 95 D3 12 C0 C5 1F 4E 3D C6 51 A2 4D 36 34 6E D3 A3 EC 62 29 84 BA 8D 2E 74 7E 88 68 44 83 1F 63 7E
RX: 15:07:33 7E A0 0F 0D 03 52 CA 33 E6 E7 00 D8 01 01 3C 43 7E
TX: 15:07:33 7E A0 07 03 0D 53 90 4D 7E
3 years ago
Hi, Because your meter is…
Because your meter is returning the invocation counter your initialize settings seem to be correct.
Are the meters the same model? Check your authentication and block cipher keys. I believe that they are different on the second meter.
adryan
3 years ago
Hi, Thank you for the reply…
Thank you for the reply.
Yes, the meter is from different brand and model. The authentication and block cipher keys are different. I tried to connect using Gurux.DLMS.Net with same parameters. It works normal. But I still want to work with python. Is it possible? How can I do that?
[Trace deleted]
remo
2 years 11 months ago
Hello, Kurumi and Adryan. I…
Hello, Kurumi and Adryan. I hope you're doing well.
I actually facing similar issue using gurux python.
Service not allowed. Operation not possible.
I'm curious to know if there have been any updates or progress regarding the issue. Has it been resolved yet, or is there any new information available?
Thank you.
Hi Remo, Please, if you have…
Hi Remo,
Please, if you have a new question, create a new topic.
The only difference between the hex logs is that python is not calling release.
Make sure that you have not modified the GXDLMSReader close -method.
  • Victorian | WA 083148835648
