  3. GXDLMSClock
GXDLMSClock
By alnardn , 10 November, 2023
Hello! What methods in GXDLMSClock object are responsible for hard and soft time correction?
Thanks for help!
3 years ago
Hi, You can use deviation…
You can use deviation for that.
https://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSClock
alnardn
3 years ago
Can you please write an…
Can you please write an example for these methods? Because i don't understand how it will be in code(Python). Something like clock = GXDLMSClock("obis_code"); clock.deviation...?
3 years ago
Hi, You can use the client…
You can use the client example to read your meter.
alnardn
3 years ago
I just need correct the…
I just need correct the clock object time (in hard and soft way)from code for testing the meter. Is it possible ? What lines of code should i write?
  • Victorian | WA 083148835648
