  3. US Association In 3 Phase Meter
US Association in 3 phase meter
By _Aparna_ , 28 October, 2023
I can establish communication with single phase meter in all associations and PC, MR in 3 phase meter. But when trying in US i am getting the following error. I have checked passwords and they are correct as everything is working in guruxdirector perfectly.
COM11:9600 8NONE1
Authentication: 2
ClientAddress: 0x30
Standard: 1
Security: 48
System title: 56 41 52 30 30 30 30 31
Authentication key: 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39
Block cipher key: 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39 39
Dedicated key: 45 46 49 43 41 41 45 4E 53 4D 41 52 54 4C 54 44
TX: 11:06:51 7E A0 07 03 61 93 69 47 7E 8
RX: 11:06:52 7E A0 1E 61 03 73 B5 7C 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E 8
TX: 11:06:52 7E A0 7C 03 61 10 AA 6B E6 E6 00 60 6E A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 56 41 52 30 30 30 30 31 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 DC C5 D3 66 41 5E 2E 21 AD 56 05 B6 50 33 3B DC BE 34 04 32 21 30 30 00 00 00 00 75 20 0A DE 67 38 73 2D 75 0F 73 1F 74 A8 4D 7E 0C EE 03 98 10 32 66 92 F2 2A 2D D5 06 7C DD 3D 5A 4B E6 C6 ED CE E5 A5 B6 4B B1 31 B8 7E 8
RX: 11:06:52 7E A0 77 61 03 30 AD 6C E6 E7 00 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 56 41 52 32 33 30 30 31 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 BE 23 04 21 28 1F 30 00 00 00 02 00 BC C0 78 9D 81 B9 12 9F 13 81 B9 39 D8 32 9D 0A AB AE FE 29 89 81 8C E6 D7 FE 76 7E 8
TX: 11:06:52 7E A0 3E 03 61 32 7B 46 E6 E6 00 CB 30 30 00 00 00 00 B7 20 DB 9B 2E 71 30 44 34 4A C2 4D 38 E0 0F 63 AB 7E 8B 5B 48 D8 BB 23 4A 6E BE DD 81 43 44 93 CB DF 94 76 50 69 E5 3A 97 F7 5E 45 E5 7E 8
RX: 11:06:58 7E A0 07 61 03 51 67 44 7E 8
parseApplicationAssociationResponse
Server did not accept CtoS.
File "c:\Users\aparna.p\Desktop\DLMS_Trash\connect.py", line 96, in <module>
connection()
File "c:\Users\aparna.p\Desktop\DLMS_Trash\connect.py", line 84, in connection
reader.initializeConnection()
File "C:\Users\aparna.p\AppData\Local\Programs\Python\Python311\Lib\site-packages\gurux_dlms\GXDLMSReader.py", line 321, in initializeConnection
self.client.parseApplicationAssociationResponse(reply.data)
File "C:\Users\aparna.p\AppData\Local\Programs\Python\Python311\Lib\site-packages\gurux_dlms\GXDLMSClient.py", line 670, in parseApplicationAssociationResponse
raise Exception("parseApplicationAssociationResponse failed. " + " Server to Client do not match.")
Exception: parseApplicationAssociationResponse failed. Server to Client do not match.
This is how i have given settings
settings.client.ciphering.security= Security.AUTHENTICATION_ENCRYPTION
settings.client.ciphering.invocationCounter = 1000
settings.client.useLogicalNameReferencing = True
settings.client.standard = Standard.INDIA
settings.client.clientAddress = 48
settings.client.serverAddress = 1
settings.client.interfaceType = InterfaceType.HDLC
settings.client.ciphering.systemTitle = bytes("VAR00001", encoding="UTF-8")
settings.client.isAuthenticationRequired = SourceDiagnostic.AUTHENTICATION_REQUIRED
settings.client.authentication = Authentication.HIGH
settings.client.ciphering.blockCipherKey = bytes("9999999999999999", encoding="UTF-8")
settings.client.ciphering.authenticationKey = bytes("9999999999999999", encoding='UTF-8')
settings.client.ciphering.dedicatedKey = bytes("EFICAAENSMARTLTD", encoding="UTF-8")
settings.client.password = "VVVVVVVVVVVVVVVV"
settings.trace = TraceLevel.INFO
settings.outputFile = "output.xml"
client.settings.useCustomChallenge = True
client.settings.connected = ConnectionState.DLMS
settings.client.ciphering.Security = SecuritySuite.AES_GCM_128
2 years 10 months ago
Hi, Check your password. Are…
Check your password. Are you reading the invocation counter with GXDLMSDirector? If you are, you need to add -V argument.
_Aparna_
Hi Mikko, This is the output…
I have used this command
python example.py -S COM11:9600:8None1 -c 48 -a High -v 0.0.43.1.0.255 -P VVVVVVVVVVVVVVVV -C AuthenticationEncryption -T 5641523030303031 -A 39393939393939393939393939393939 -B 39393939393939393939393939393939 -D 92288D3A30D12606F39ACC77B7C6832E -d India -w 1 -f 128 -t Verbose
This is the output when i tried to execute from command prompt.
gurux_dlms version: 1.0.145
gurux_net version: 1.0.20
gurux_serial version: 1.0.20
Authentication: 2
ClientAddress: 0x30
Standard: 1
Security: 48
Dedicated key: 92 28 8D 3A 30 D1 26 06 F3 9A CC 77 B7 C6 83 2E
TX: 13:01:31 7E A0 07 03 21 93 0F 01 7E
TX: 13:01:31 7E A0 07 03 21 93 0F 01 7E 8
RX: 13:01:36 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
RX: 13:01:36 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E 8
TX: 13:01:36 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 5D FF FF 91 23 7E
TX: 13:01:36 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 5D FF FF 91 23 7E 8
RX: 13:01:41 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 04 00 00 07 86 A1 7E
RX: 13:01:41 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 04 00 00 07 86 A1 7E 8
TX: 13:01:41 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 01 00 00 2B 01 00 FF 02 00 7D 8F 7E
TX: 13:01:41 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 01 00 00 2B 01 00 FF 02 00 7D 8F 7E 8
RX: 13:01:46 7E A0 11 21 03 52 B1 F8 E6 E7 00 C4 01 C1 01 04 CC F6 7E
RX: 13:01:46 7E A0 11 21 03 52 B1 F8 E6 E7 00 C4 01 C1 01 04 CC F6 7E 8
TX: 13:01:46 7E A0 15 03 61 54 0D 0F E6 E6 00 62 03 80 01 00 03 80 01 00 EB 86 7E
TX: 13:01:46 7E A0 15 03 61 54 0D 0F E6 E6 00 62 03 80 01 00 03 80 01 00 EB 86 7E 8
TX: 13:02:21 7E A0 07 03 61 53 65 81 7E
TX: 13:02:21 7E A0 07 03 61 53 65 81 7E 8
RX: 13:02:26 7E A0 07 61 03 1F 1D EF 7E
RX: 13:02:26 7E A0 07 61 03 1F 1D EF 7E 8
Access Error : Unknown error.
It seems that I dont have much dependency with invocation counter. As i dont have any differene if i add it or remove it while reading. I have checked password again and it is correct as per the team.
Aparna
Hi, Can you add the…
Can you add the GXDLMSDirector log as a hex so I can check what argument is different?
Only the connection log is important. Please, don't all anything else.
_Aparna_
Hi Mikko, Please find the…
Please find the connection log from guruxDirector.
19:59:29 Send SNRM request.
TX: 7E A0 07 03 61 93 69 47 7E
19:59:29
RX: 7E A0 1E 61 03 73 B5 7C 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
19:59:29 Send AARQ request.
TX: 7E A0 7C 03 61 10 AA 6B E6 E6 00 60 6E A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 56 41 52 30 30 30 30 31 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 62 72 77 69 17 70 41 68 0F 6E 76 4C 3C 71 42 22 BE 34 04 32 21 30 30 00 00 00 00 75 20 0A 09 09 FC 0A 5C E5 6C 3B BF A3 25 68 9D 86 39 69 98 10 32 66 92 F2 2A 4F D5 06 7C DD 4F EF C1 97 A6 E2 BC 99 3E 95 0F 15 F3 B0 7E
19:59:30
RX: 7E A0 77 61 03 30 AD 6C E6 E7 00 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 56 41 52 32 33 30 30 31 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 BE 23 04 21 28 1F 30 00 00 00 00 AF 2B 0B DF 4D 0F 73 D0 B7 15 EF 4A DC EB 42 FD 38 6C E0 05 4A CC 7F BC 91 8C 2B 46 7E
19:59:30 Authenticating.
TX: 7E A0 3E 03 61 32 7B 46 E6 E6 00 CB 30 30 00 00 00 01 90 16 10 61 D8 F2 66 05 6B BC 39 76 DE B7 BB 29 A0 13 0B 3D 6F D3 5C 88 3E 3B A4 5E DD 0D 14 6A BB 7A D7 0B 7A B2 F4 90 14 30 2B ED A7 7E
19:59:30
RX: 7E A0 37 61 03 52 0E 3A E6 E7 00 CF 29 30 00 00 00 01 62 1D D7 81 62 7F D8 61 71 1C A9 B0 9E 38 69 9C AD F6 C4 F7 9B 6A 58 13 3F 21 36 14 3C FF 59 91 F8 EF 83 DB 54 1B 7E
Aparna
Hi, Remove -v 0.0.43.1.0.255…
Remove -v 0.0.43.1.0.255. Your meter is not using the invocation counter.
_Aparna_
Hi Mikko, I have executed…
I have executed the command without invocation counter but still the issue persists. And here is the log.
SNRM
TX: 12:44:49 7E A0 07 03 61 93 69 47 7E
RX: 12:44:54 7E A0 1E 61 03 73 B5 7C 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E 8
ARQ
TX: 12:44:54 7E A0 7C 03 61 10 AA 6B E6 E6 00 60 6E A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 56 41 52 30 30 30 30 31 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 2D B5 D2 D1 5F C7 6E 71 06 14 B7 61 E5 5A 88 2C BE 34 04 32 21 30 30 00 00 00 00 75 20 0A 09 09 FC 0A 5C E5 6C 3B BF A3 25 68 9D 86 39 69 98 10 32 66 92 F2 2A 2D D5 06 7C DD A8 54 8D C8 66 BA 4F 4E 43 9A AE D6 B7 45 7E
RX: 12:44:59 7E A0 77 61 03 30 AD 6C E6 E7 00 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 56 41 52 32 33 30 30 31 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 BE 23 04 21 28 1F 30 00 00 00 03 1D A0 38 D4 8C A5 AD CA 46 6E A8 7D 62 D3 04 D9 03 78 6C 19 E5 96 B8 5F 97 75 13 93 7E 8
Authentication/challenge
TX: 12:44:59 7E A0 3E 03 61 32 7B 46 E6 E6 00 CB 30 30 00 00 00 00 B7 20 DB 9B 2E 71 30 44 34 4A C2 4D 38 E0 0F 63 AB 7E 8B 5B 48 D8 BB 23 4A 6E BE DD 81 43 44 93 CB DF 94 76 50 69 E5 3A 97 F7 5E 45 E5 7E 8
RX: 12:45:14 7E 7E A0 07 61 03 51 67 44 7E 8 ------wrong frame as reply
Disconnect Request
TX: 12:45:14 7E A0 07 03 61 53 65 81 7E
RX: 12:45:19 7E A0 1E 61 03 73 B5 7C 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E 8
Aparna
_Aparna_
Hi Mikko, The same settings…
The same settings are working as expected with single phase meter. Even i can download PC and MR with 3 phase meter. Not sure what additional changes that needs to done for US association. All the keys are correct and password is also correct as per the team. Can you confirm if there are additional settings that needs to be done?
Aparna
Hi, The only thing that is…
The only thing that is different between GXDLMSDirector and your Python traces is the value of the invocation counter. Set the value of the invocation counter to one like this:
self.client.ciphering.invocationCounter = 1
_Aparna_
Hi Mikko, I have added…
I have added invocation counter as suggested. But still the issue persists.
Aparna
Hi, What authentication key…
What authentication key you are using in GXDLMSDirector?
_Aparna_
Hi Mikko, I am using…
I am using authentication key and Block cipher Key as 9999999999999999.
Aparna
Hi, Get the version 1.0.146…
Get the version 1.0.146. The default invocation counter value is changed from zero to one and ciphering invocation counter is increased in the same way as in C#. Let me know what happened.
_Aparna_
Hi Mikko, That worked for me…
That worked for me. Issue is resolved now. Thankyou for your assistance.
Regards
Aparna
Hi Aparna, Thank you for…
Hi Aparna,
Thank you for letting me know about this. I'm glad that you can read your meter now.
