  3. What Is The Configuration To Connect Wasion IMeter318 ?
What Is the configuration to connect Wasion iMeter318 ?
By luthfipratamaps , 2 October, 2023
I want to connect Wasion iMeter318 using a serial port what is the configuration to connect it?
3 years 1 month ago
Hi, Try to change the…
Try to change the interface from WRAPPER to HDLC.
Then check the serial port settings from the meter documentation.
luthfipratamaps
3 years 1 month ago
Thank you! Got it connected…
Thank you!
Got it connected using HDLC with physical address 12.
