  3. Cannot Connect Holley DDSY283
Cannot connect Holley DDSY283
By khana , 25 September, 2023
Hello
I am trying to connect Holley DDSY283 smart meter using dlms.
But it returns:
GetObject failed. Access error: Device reports a temporary failure.
2 years 11 months ago
Hi, If I remember correctly,…
If I remember correctly, all Holley meters don't support the association view, even if it's mandatory. Try to add objects manually. Select "Edit" and "Add Object". Then try to add a clock object and read it. If you can read it, you need to add all the objects manually. You need to ask for the list of objects from Holley.
khana
it working thank you
