  3. Simulator .xml Templates
Simulator .xml templates
By goergios , 14 September, 2023
I'm looking for the XML file required for the Laendys+Gyr smart meter simulator.
If anyone has access to it or knows where to obtain it, please let me know.
Or in general except of crystal.xml where else I could find xmls that can build an simulated smart meter
3 years 2 months ago
Hi, What Landis+Gyr meter do…
What Landis+Gyr meter do you want to simulate? The are a lot of differences between the meters.
You can also add new objects manually if you want to use objects that are missing from the simulator.
goergios
I find it really difficult…
I find it really difficult to find the correct LN for Landys meters.
I am just trying to create any Laendys Meter just in order to understand the packets that are transferring in each occasion.
Do you have any xml for Laendys?
Hi, Landis+Gyr packet…
Landis+Gyr packet structure is the same as Crystal.
I have to say that DLMS is a very complicated protocol. If you are interested in the messages you need to get the DLMS protocols. Without those, you can't get the idea from the protocol.
The easiest way is if you use our open-source libraries to communicate with your meter.
