  3. Failed To Receive Reply
Failed to receive reply
By jan.kolar , 30 August, 2023
reading association view is terminated by error message:
As i remember from distant past this function never was reliable. The meter type is Landis&Gyr E550, client id = 80 (Level 4). When I analyze logs i see that reading is terminated on this packet (please see last three packets):
[08:53:04:332] Written data (COM20)
7e a0 36 03 a1 b6 25 ab 08 01 ff 03 00 00 03 01 ~ 6.ˇ¶%«..˙.....
01 01 08 02 ff 03 00 00 03 01 01 01 08 03 ff 03 ....˙.........˙.
00 00 03 01 01 05 08 01 ff 03 00 00 03 01 01 05 ........˙.......
08 02 ff 03 00 72 58 7e ..˙..rX~
[08:53:04:410] Read data (COM20)
7e a8 4f a1 03 9a 6d 9f e6 e7 00 c4 03 c1 0a 00 ~¨Oˇ.šmźćç.Ä.Á..
02 02 0f 00 16 ff 00 02 02 0f 00 16 ff 00 02 02 .....˙......˙...
0f 00 16 ff 00 02 02 0f 00 16 ff 00 02 02 0f 00 ...˙......˙.....
16 ff 00 02 02 0f ff 16 1e 00 02 02 0f ff 16 1e .˙....˙......˙..
00 02 02 0f ff 16 1e 00 02 02 0f ff 16 20 36 52 ....˙......˙. 6R
7e ~
[08:53:04:623] Written data (COM20)
7e a0 19 03 a1 7c d9 ff e6 e6 00 c0 01 c1 00 07 ~ ..ˇ|Ů˙ćć.Ŕ.Á..
01 00 63 62 00 ff 03 00 f3 2c 7e ..cb.˙..ó,~
[08:53:09:644] Written data (COM20)
[08:53:14:707] Written data (COM20)
After parsing:
│ └──DLMS_PDU[192] {** getRequest **}
│ └──GetRequest[1] {** Get-request-normal **}
│ └──GetRequestNormal Sequence
│ ├──InvokeIdPriority
│ │ ├──InvokeID (0..3): 1
│ │ ├──ServiceClass (6): confirmed
│ │ └──Priority (7): high
│ ├──CosemAttributeDescriptor Sequence {** Cosem-Attribute-Descriptor **}
│ │ ├──CosemClassID = 7 (0x0007) {** Cosem-Class-Id **}
│ │ ├──CosemObjectInstanceID[6] = 1.0.99.98.0.255 {** Cosem-Object-Instance-Id **}
│ │ └──CosemObjectAttributeID = 3 {** Cosem-Object-Attribute-Id **}
│ └──Optional Flag = False {** Access-Selection **}
I have no problem reading load profile from my application as can be seen here:
[09:08:31:561] Written data (COM20)
7e a0 19 03 a1 54 93 52 e6 e6 00 c0 01 c1 00 07 ~ ..ˇT“Rćć.Ŕ.Á..
[09:08:31:670] Read data (COM20)
7e a8 5a a1 03 74 eb 3c e6 e7 00 c4 01 c1 00 01 ~¨Zˇ.të<ćç.Ä.Á..
05 02 04 12 00 08 09 06 00 00 01 00 00 ff 0f 02 .............˙..
12 00 00 02 04 12 00 03 09 06 00 00 60 f0 0c ff ............`đ.˙
0f 02 12 00 00 02 04 12 00 03 09 06 00 00 60 f0 ..............`đ
0c ff 0f 0c 12 00 00 02 04 12 00 03 09 06 00 00 .˙..............
60 f0 0c ff 0f 13 12 00 00 6d c2 7e `đ.˙.....mÂ~
[09:08:31:889] Written data (COM20)
7e a0 07 03 a1 71 df 49 7e ~ ..ˇqßI~
[09:08:32:108] Read data (COM20)
7e a0 1b a1 03 76 d5 4f 02 04 12 00 03 09 06 00 ~ .ˇ.vŐO........
00 61 61 00 ff 0f 02 12 00 00 68 d2 7e .aa.˙.....hŇ~
After parsing:
--- Packet 5 ---
├──InvokeIdPriority
--- Packet 6 ---
DLMS_PDU[196] {** GetResponse **}
└──GetResponse[1] {** Get-response-normal **}
└──GetResponseNormal Sequence
├──InvokeIdPriority
└──GetDataResult Result[0] {** data **}
└──Data[1] {** Array **}
└──SequenceOf 5 Element(s)
├──0: Data[2] {** Structure **}
│ └──SequenceOf 4 Element(s)
│ ├──0: [18] Unsigned16 = 8 (0x0008)
│ ├──1: [9] OctetString[6] = 00 00 01 00 00 FF
│ ├──2: [15] Integer8 = 2 (0x02)
│ └──3: [18] Unsigned16 = 0 (0x0000)
├──1: Data[2] {** Structure **}
│ ├──0: [18] Unsigned16 = 3 (0x0003)
│ ├──1: [9] OctetString[6] = 00 00 60 F0 0C FF
├──2: Data[2] {** Structure **}
│ ├──2: [15] Integer8 = 12 (0x0C)
├──3: Data[2] {** Structure **}
│ ├──2: [15] Integer8 = 19 (0x13)
└──4: Data[2] {** Structure **}
├──1: [9] OctetString[6] = 00 00 61 61 00 FF
Timeout is set to 5 seconds.
jan.kolar
3 years 2 months ago
Attaching compare of HDLC…
Attaching compare of HDLC packets. Left: DLMS Director, Right - our application. Packets are same with the exception of send and receive packets numbers a CRC which is normal.
Hi, There is some strange…
There is some strange data before Get request. There are several reasons why the meter is not replying. Can you add GXDLMSDirector hex log so I can check what is really happening?
You can get it when you select "View", "Log" and "View Log".
Hi, Thank you for the log…
Thank you for the log. There is something in with scalers and units reading that causes this. I need to check this from the bytes and it'll take some time.
Select "Supported Services" and then un-select "Multiple references".
I believe that you can now read your meter without problems.
jan.kolar
Unchecking multiple…
Unchecking multiple references helped. Thank you.
3 years 1 month ago
Hi, The new version is…
The new version is released during the next week where this is fixed.
