  3. Error Found When GXC File Trying To Safe
Error found when GXC file trying to safe
By vivek604 , 11 July, 2023
There was error in generating xml document when safe working gxc file. Director Version 9.0.2306.0201
3 years 2 months ago
Hi, Restart GXDLMSDirector…
Restart GXDLMSDirector. It will say that there is a new version available. Update to that and let me know if you still have problems.
vivek604
same issue observed when…
same issue observed when trying to reopen new gxc file without disconnect existing gxc file.
3 years 1 month ago
Hi, What version you are…
What version you are using from GXDLMSDirector?
Can you send the gxc file to me so this can be checked?
I just checked this and it worked without problems.
vivek604
3 years 1 month ago
As per your request version…
As per your request version screenshot attached. I am using older version made gxc file in newer version. this is my normal practice. Does not create new gxc file on every update of GX director . This is wrong way?
3 years ago
Hi, Update to the latest…
Update to the latest version (9.0.2308.1601) from GXDLMSDirector and let me know if you have any problems.
vivek604
3 years ago
Facing same issue with new…
Facing same issue with new update, I am notice that if I used two device(HDLC and TCP) in single gxc file and trying to save project after data reading then facing this type issue .
3 years ago
Hi, You told me that you get…
You told me that you get this error when reopening gxc file.
Can you send this file to me by email?
vivek604
3 years ago
Plz share the mail ID
3 years ago
Hi, You can get my email…
You can get my email address from here:
https://www.gurux.fi/AboutUs
vivek604
3 years ago
As per your request gxc file…
As per your request gxc file mailed to you. attached file trying to open in gxdirector facing error msg.
