  3. Dlms Gurux Client
dlms gurux client
Profile picture for user psantosh
By psantosh , 28 July, 2023
I am using the gurux dlms client and i opened the project in vs code,
but it is not compiling , what i need to do, i am new to dlms.
other than vscode is any ide to debug the dlms project.
Regards
Raja
3 years 3 months ago
Hi, Have you copied files…
Have you copied files under development forder to DLMS folder? I believe that is the reason for this. You can also use Visual Studio to debug.
psantosh
Hi Mikko , i copied the…
Hi Mikko ,
i copied the files in the folder , Is there is any reference document to run a client example in vs code , i am new to dlms and vs code , Please do needful
Regards
psantosh
3 years 2 months ago
Hi Raja, Can you use Visual…
Hi Raja,
Can you use Visual Studio? I believe it might be useful to you.
There are lots of tutorials on how to you VS Code. You get a list of command line arguments when you run the app.
I propose that you connect first with GXDLMSDirector. It will show the correct command line arguments to you.
