  3. 'Invalid Data Type.' Some Data Got Lost.
'Invalid data type.' Some data got lost.
By bernhard , 1 July, 2023
I was able to extract data from my smartmeter perfectly fine until two months ago.
Now I get the following error:
Jul 01 13:35:20 pi4 smartmeter-datacollector[25003]: DEBUG:smartmeter:HDLC Buffer: 7E A0 84 CE FF 03 13 12 8B E6 E7 00 E0 40 00 01 00 00 70 0F 00 3D F2 A6 0C 07 E7 07 01 06 0D 23 14 FF 80 00 00 02 0B 01 0B 02 04 12 00 28 09 06 00 08 19 09 00 FF 0F 02 12 00 00 02 04 12 00 28 09 06 00 08 19 09 00 FF 0F 01 12 00 00 02 04 12 00 01 09 06 00 00 60 01 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 01 07 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 02 07 00 FF 0F 02 12 00 00 B5 04 7E 7E A0 8B CE FF 03 13 EE E1 E0 40 00 02 00 00 7A 02 04 12 00 03 09 06 01 01 01 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 02 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 05 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 06 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 07 08 80 FF 0F 02 12 00 F0 FE FE FF F8 FE F9 3C 33 33 8B 52 7E 7E A0 3D CE FF 03 13 F2 84 E0 C0 00 03 00 00 2C 37 38 31 31 06 00 00 00 00 06 00 00 17 D4 06 01 C3 CC 9D 06 00 77 19 EC 06 00 39 79 41 06 00 00 B2 30 06 00 45 76 DB 06 01 17 BE 8C 66 43 7E
Jul 01 13:35:20 pi4 smartmeter-datacollector[25003]: WARNING:smartmeter:Failed to extract data from HDLC frame: 'Invalid data type.' Some data got lost.
see here for a more complete log:
https://gist.github.com/kafisatz/892ac0379e97140e3dcd419c40ee83a4#file-…
I am using this software: https://github.com/scs/smartmeter-datacollector
3 years 2 months ago
Hi, I checked the bytes and…
I checked the bytes and there is an issue with your meter.
You need to ask the meter vendor if there is a meter firmware available that fixes this.
I checked the push message manually from the bytes. I believe that will help the meter manufacturer to solve the issue.
0F 00 3D F2 94 0C 07 E7 07 01
06 0D 21 32 FF 80 00 00
02 0B //Structure with 11 elements.
01 0B Array with 11 elements.
02 04
12 00 28
0F 02
12 00 00
02 04
12 00 28
0F 01
12 00 00
02 04
12 00 01
0F 02
12 00 00
02 04
12 00 03
0F 02
12 00 00
02 04
12 00 03
0F 02
12 00 00
//Invalid data start here.
37 38 31 31 06 00 00 00 00 06 00 00 18 FF 06 01 C3 CC 9D 06 00 77 19 4F 06 00 39 79 41 06 00 00 B2 2D 06 00 45 76 DB 06 01 17 BE 8C" />
bernhard
Thanks. So you can confirm…
Thanks. So you can confirm that the data is not encrypted?
bernhard
I will try and reach out to…
I will try and reach out to them regarding a firmware update.
Hi, The data is not ciphered…
The data is not ciphered (encrypted).
