  3. Hexing Meter Maximum Demand Apparent Power
Hexing Meter Maximum Demand Apparent power
By sarayumarapana , 26 June, 2023
HI. I have tried to take the values for the 1.0.9.6.0.255 and 1.0.10.6.0.255 under register. This communication in done using high authentication. But cannot obtain the result. While other required parameters such as energy can obtain.
thanks
3 years 4 months ago
Hi, Check what are the…
Check what are the access rights. It might be that you don't have enough access rights to read those values.
sarayumarapana
Thanks for the reply…
Thanks for the reply. Maximum demand was in the extended register, and it reads. But when i try to add 1.0.4.8.1.1 to register it allow to add without any errors but readings are not coming. this are my settings.
  • Victorian | WA 083148835648
