  3. Redefinition of Uint32_t, Int32_t.
Redefinition of uint32_t, int32_t.
By plotnikov.av , 29 June, 2023
gxint.h makes a problem under *inux system redefining uint32_t, int32_t types to 8-byte types (... long). It works under Windows because it is set as #define. In *inux the types are set through typedef, and #ifndef uint32_t does not work.
I simply comment all definitions in gxint.h, and it works well everywhere.
PS For portable code a good way is to define own types:
typedef uint32_t u4_t
typedef int32_ t s4_t
3 years 4 months ago
Hi, This is constantly…
This is constantly tested with multiple Linux distros and there are no problems. Can you run this and join the output here:
gcc --version
  • Toko Bangunan Mahkota Jaya | WA 083148835648
