  2. Issue Reading ISKRA MT880 From Arduino
Issue reading ISKRA MT880 from Arduino
By Roby Oliver , 8 June, 2023
Gurux.Serial
I try to read a meter MT880 with Arduino example code ,
but the sample program not working.
I think the issue is on init :
Assuming the default password is password
Client.init(true, 1, 172, DLMS_AUTHENTICATION_LOW, "password", DLMS_INTERFACE_TYPE_HDLC);
Using the Director to test, it works correctly by this entry :
COM3:9600:8None1 -c 1 -s 172 -a Low -P password
Is correct to use the 172 also in Arduino code ?
Best regards,
and thanks for any useful hint.
3 years ago
Hi, Your settings look…
Your settings look correct. If you can read your meter with a client example using those arguments, you can read your meter with Arduino if your serial port settings are correct. If you can't read the meter with Arduino can you add a hex trace here so I can compare the bytes?
Roby Oliver
3 years ago
I try to get log and update…
I try to get log and update asap.
Best regards
Thanks !
Roby Oliver
3 years ago
I , i get this log : 7E A0…
7E A0 08 02 59 03 93 9C 87 7E7E A0 1F 03 02 59 73 77 7C 81 80 12 05 01 9A 06 01 9A 07 04 00 00 00 01 08 04 00 00 00 01 CC A27E7E A0 08 02 59 03 93 9C 87 7E7E A0 1F 03 02 59 73 77 7C 81 80 12 05 01 9A 06 01 9A 07 04 00 00 00 01 08 04 00 00 00 01 CC A27E7E A0 08 02 59 03 93 9C 87 7E7E A0 1F 03 02 59 73 77 7C 81 80 12 05 01 9A 06 01 9A 07 04 00 00 00 01 08 04 00 00 00 01 CC A27E7E A0 08 02 59 03 93 9C 87 7E7E A0 1F 03 02 59 73 77 7C 81 80 12 05 01 9A 06 01 9A 07 04 00 00 00 01 08 04 00 00 00 01 CC A27E7E A0 08 02 59 03 93 9C 87 7E7E A0 1F 03 02 59 73 77 7C 81 80 12 05 01 9A 06 01 9A 07 04 00 00 00 01 08 04 00 00 00 01 CC A27E7E A0 08 02 59 03 93 9C 87 7E7E A0 1F 03 02 59 73 77 7C 81 80 12 05 01 9A 06 01 9A 07 04 00 00 00 01 08 04 00 00 00 01 CC A2 7E7E A0 08 02 59 03 93 9C 87 7E 7E A0 1F 03 02 59 73 77 7C 81 80 12 05 01 9A 06 01 9A 07 04 00 0000 01 08 04 00 00 00 01 CC A2 7E7E A0 08 02 59 03 93 9C 87 7E7E A0 1F 03 02 59 73 77 7C 81 80 12 05 01 9A 06 01 9A 07 04 00 00 00 01 08 04 00 00 00 01 CC A27E7E A0 08 02 59 03 93 9C 87 7E7E A0 1F 03 02 59 73 77 7C 81 80 12 05 01 9A 06 01 9A 07 04 00 00 00 01 08 04 00 00 00 01 CC A27E7E A0 08 02 59 03 93 9C 87 7E7E A0 1F 03 02 59 73 77 7C 81 80 12 05 01 9A 06 01 9A 07 04 00 00 00 01 08 04 00 00 00 01 CC A27E7E A0 08 02 59 03 93 9C 87 7E7E A0 1F 03 02 59 73 77 7C 81 80 12 05 01 9A 06 01 9A 07 04 00 00 00 01 08 04 00 00 00 01 CC A27E7E A0 08 02 59 03 93 9C 87 7E7E A0 1F 03 02 59 73 77 7C 81 80 12 05 01 9A 06 01 9A 07 04 00 00 00 01 08 04 00 00 00 01 CC A2 7E7E A0 08 02 59 03 93 9C 87 7E7E A0 1F 03 02 59 73 77 7C 81 80 12 05 01 9A 06 01 9A 07 04 00 00 00 01 08 04 00 00 00 01 CC A27E7E A0 08 02 59 03 93 9C 87 7E7E A0 1F 03 02 59 73 77 7C 81 80 12 05 01 9A 06 01 9A 07 04 00 00 00 01 08 04 00 00 00 01 CC A27E7E A0 08 02 59 03 93 9C 87 7E7E A0 1F 03 02 59 73 77 7C 81 80 12 05 01 9A 06 01 9A 07 04 00 00 00 01 08 04 00 00 00 01 CC A27E7E A0 08 02 59 03 93 9C 87 7E7E A0 1F 03 02 59 73 77 7C 81 80 12 05 01 9A 06 01 9A 07 04 00 00 00 01 08 04 00 00 00 01 CC A27E
Best regards
Roby Oliver
3 years ago
Another question: is there a…
Another question: is there a way to indicate -d Italy to indicate Italy standard
in client.ino code in Client.init ( .. ..... ) ?
2 years 12 months ago
Hi, It looks like you have…
It looks like you have commented on AARQ and AARE messages. Your client is only sending SNRM and received UA messages, but don't send anything else. Check the reason for this.
-d Italy is used to show correct descriptions for the OBIS codes, but Arduino doesn't use that information for anything.
Roby Oliver
Hi, i check the code. Thanks…
i check the code.
Thanks !
Best regards
