  3. Gurux Ansi C Gateway Protocole
Gurux ansi C Gateway protocole
By dlmsDeveloper , 12 June, 2023
Dear Gurux manager
How can i use Gateway protocole in gurux Ansi C library ?
i try GuruxDLMSDataGateway example , but its not working correctly and it has not gateway protocole.
thank you.
3 years 5 months ago
Hi, Gateway is not…
Gateway is not implemented for the ANSI C because no one of our clients are not using it at the moment. I'll add it to the work list and it can be implemented sometime during the fall.
dlmsDeveloper
Dear kurumi Thank you. Can…
Dear kurumi
Thank you.
Can you guide me to add it to the library so that I can publish it later?
  • Victorian | WA 083148835648
