  3. Optical Port
Optical port
By labasvakaras , 1 June, 2023
Hello, i am trying to read data through optical port, but i have few questions:
1. Does meters always responds with all OBIS they have, when you write /?!\n\r.
2. Is it possible to read only one parameter instead of all?
I have two meters, both of them are responding everything they have instantly, when I write /?!\n\r
I am testing HDLCWithModeE.
3 years 5 months ago
Hi, When you send /?!\n\r…
When you send /?!\n\r the meter is using IEC 62056-21 Mode A (readout). In readout mode the meter returns some of the register values, but not all.
If you want to read only one value you need to use IEC 62056-21 Mode C or DLMS.
With DLMS you can access the meter better, but it's not as easy as IEC 62056-21 Mode A.
If you want only to get some data from the meter it's the easiest if you get the readout and then parse needed the data. The bad side is that you can't write anything for the meter, for example, update the clock.
labasvakaras
Tried as you said: on first…
Tried as you said:
on first iteration everything is fine.
I am sending /?!\n\r, I get:
2F 43 4C 45 35 5C 57 30 30 31 36 0D 0A
then communication starts with DLMS protocol. After i close socket:
[Debug ] TX: 7E A0 11 03 05 76 C4 7D E6 E6 00 62 03 80 01 00 BD 9B 7E
[Debug ] RX: 7E A0 11 05 03 96 C3 18 E6 E7 00 63 03 80 01 00 2C 0F 7E
[Debug ] TX: 7E A0 07 03 05 53 50 83 7E
[Debug ] RX: 7E A0 20 05 03 73 29 F8 81 80 14 05 02 01 00 06 02 01 00 07 04 00 00 00 01 08 04 00 00 00 01 69 6D 7E
I try to initiate again (with or without sending /?!\n\r), but i get:
is this normal DLMS payload?
Hi, That looks like part of…
That looks like part of the DLMS frame.
Some meters expect that you wait for a while before you can establish the connection again. Try to wait e.g. one minute and re-establish the connection.
  • Toko Bangunan Mahkota Jaya | WA 083148835648
