  2. Push Listener Python
By kevin jose minj , 30 May, 2023
when I am run this python push listener example I am getting this data. Why I am not receiving the exact hexadecimaldata?
COM3:9600 8NONE1
Press any key to close the application.
Media state changed. MediaState.OPENING
trace:12:56:47 TraceTypes.INFO Settings: Port: COM3 Baud Rate: BaudRate.BAUD_RATE_9600 Data Bits: 8 Parity: Parity.NONE Stop Bits: StopBits.ONE Eop:126
New data is received. COM3:00
3 years 2 months ago
Hi, You need to change the…
You need to change the trace type from info to Verbose.
kevin jose minj
I changed the trace type to…
I changed the trace type to Verbose and this is command I am now
python main.py -S COM3 -t Verbose
I am getting the same output
COM3:9600 8NONE1
trace:14:53:17 TraceTypes.RECEIVED 00
trace:14:53:18 TraceTypes.RECEIVED 00
kevin jose minj
3 years 1 month ago
I have question regarding…
I have question regarding with push listener. Is there any way to get data from simulated meters to test the push listener example?
Please help me out
3 years 1 month ago
Hi, I just realized that the…
I just realized that the Python example doesn't add the hex trace for the output.
Simulators can't send push messages at this moment. You can only read them.
kevin jose minj
3 years 1 month ago
So is there any issue with…
So is there any issue with python push listener example?
3 years 1 month ago
Hi, No, there is no issue…
No, there is no issue. The example just doesn't add the hex trace.
kevin jose minj
3 years 1 month ago
Hi Mikko, But , I added -t…
But , I added -t Verbose parameter. Why its not giving the hex trace ?
3 years 1 month ago
Hi, Get the latest version…
Get the latest version from the push example. It will add a hex trace if verbose argument is added,
