  3. How To Enable Read Object
How to enable Read Object
By ariane , 24 April, 2023
I am connected to a meter and I can Read data from it.
I also want to Read Object on ProfileGeneric but the option is disabled.
How can I enable Read Object?
GXDLMSDirector version is 9.0.2303.2302
Thank you!
3 years 6 months ago
Hi, Read object is not…
Read object is not enabled for profile generic objects becase it will read all attributes and there might be a lots of data in the buffer and you don't want to do that. Also that might cause problems with some meters.
Use read by range and entry to read profile generic buffer.
