  2. Gateway Error
Gateway Error
By dlmsDeveloper , 16 April, 2023
Gurux.Net
Dear Gurux Manager
I use gurux C# library for Read my devices with a gateway
when software is server and gateway is client, between connection and meter reading gateway send DataNotification with 0x66 adress and i get Exception "Destination addresses do not match" , how can i handle this?
This happens both at the beginning of reading and in the middle of reading.
3 years 1 month ago
Hi, Your meter is using the…
Your meter is using the different destination address that you are.
Can you add the hex tracehere so I can check what is happening?
