  3. Trying To Read Values of Dlms Based Energy Meter
trying to read values of dlms based energy meter
By sruthi , 13 April, 2023
hi,
I'm trying to build a modem for my project to read values like energy consumption, real and reactive power, etc, of a dlms based energy meter.
I'm confused as to which code i should use to achive the same.
i do have the following components.
1)esp 32 / esp 8266
2)ttl convertor
3)USB to rj11 convertor cable
My preferred coding platform is arduino ide version(2.0.4)
thank you
Sarah
3 years 7 months ago
Hi, You need the client…
You need the client example to read your meter. You can get it from here:
I propose that you use GXDLMSDirector and use it first with your meter. It will help you to understand the DLMS meters.
sruthi
Sir, Thank you for the fast…
Sir,
Thank you for the fast response,
I would like to ask how GXDLMSDIRECTOR is going to help understand the meter and be useful for my project?
Thank you
Sarah
Hi, GXDLMSDirector will show…
GXDLMSDirector will show the structure of COSEM objects in the UI and it's easier to understand the DLMS meters.
sruthi
Sir, I tried using…
Sir,
I tried using GXDLMSDIRECTOR but i couldn't connect my meter to read any data,
Moreover i tried to compile the client.ino file and encountered
Compilation error: include/gxignore.h : No such file or directory
Thank you
Sarah
Hi, This is the reason why…
This is the reason why asked you to use GXDLMSDirector first. There are multiple parameters in DLMS and the meter doesn't reply if one of the parameters is different that the meter expects. What meter model you try to read?
If you are using ANSI C you need to copy src and include folders under the development folder to dlms folder. You can read more from here:
https://www.gurux.fi/Gurux.DLMS
sruthi
Sir, I'm trying to read a…
Sir,
I'm trying to read a Larsen & Toubro single phase watthour meter
I've attached an image file with all details.
Thank you
Sarah
Hi, You should be able to…
You should be able to read the meter if you select the Indian standard as the manufacturer.
