  3. Gurux/Python
Gurux/Python
By gilles_de_rais , 3 April, 2023
I have tried to implement gateway functionality in python gurux in Gurux.DLMS.Client.Example
reader = None
settings = GXSettings()
try:
# Handle command line parameters.
ret = settings.getParameters(args)
gateway = GXDLMSGateway()
gateway.networkId = 0
gateway.physicalDeviceAddress = bytearray([0x76, 0x90, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03])
settings.client.gateway = gateway
it did not add my Phy address and increment the wrapper frame size
gurux_dlms version: 1.0.142
gurux_net version: 1.0.20
gurux_serial version: 1.0.20
Authentication: 2
ClientAddress: 0x30
Standard: 0
Security: 48
System title: 41 42 43 44 45 46 47 48
Authentication key: 31 32 33 34 35 36 37 38 39 30 31 32 33 34 35 36
Block cipher key: 31 32 33 34 35 36 37 38 39 30 31 32 33 34 35 36
TX: 17:39:09 00 01 00 10 00 01 00 1F 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 5D FF FF
3 years 5 months ago
Hi, There was an issue with…
There was an issue with the gateway. This is fixed for the version 1.0.143.
gilles_de_rais
In reply to Hi, There was an issue with… by Kurumi
Thank you same thing with…
Thank you same thing with GXDLMS director
